cuts out
This is a discussion on cuts out within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; hi all im new here and have a question. my raptor 02runs fine on idle but if i hold the gas on around 3-4000 rpm ...
Old 03-18-2010, 01:36 AM   #1
View mick9912's Photo Gallery(0)
Default cuts out
hi all im new here and have a question. my raptor 02runs fine on idle but if i hold the gas on around 3-4000 rpm its cuts out like u turn the switch off and on again . checked the spark and it cuts out . could the stador or the cpi cause this prob???
mick9912 is offline   Reply With Quote
Old 03-18-2010, 07:59 AM   #2
Does it do it when you are riding or just in neutral?
Old 03-18-2010, 03:21 PM   #3
it does it all the time in neutral or every gear
Old 03-19-2010, 08:11 AM   #4
Most likely the stator, check the stator against the specifications in the manual.
Make sure your spark plug boot is tight on the top of the plug..
Old 03-26-2010, 11:41 PM   #5
View ctraptorken's Photo Gallery(0)
Have you checked the rev limiter connections? If the parking brake is loose at the handlebars or if the reverse light connection on the case is bad, either one can cause this too.
ctraptorken is offline   Reply With Quote
Old 03-30-2010, 02:17 AM   #6
Quadmaniac's Avatar
View Quadmaniac's Photo Gallery(0) Send a message via Yahoo to Quadmaniac
Assuming your reverse light doesn't come on when it shouldn't: Parking brake switch is on or has failed. Just unplug its wires at the connector. White connector, 2 pins, black and black wires coming in one side, green/yellow stripe and black wires other side... hidden up behind the left headlight near the radiator - unplug and leave it unplugged, you don't need it.
QuadManiac
'01 Scrambler 400, K&N
Quadmaniac is offline   Reply With Quote
It just cuts out m4skinner Yamaha YFM350 Raptor/Warrior ('87-Present) 6 05-28-2007 08:33 AM
02 rappy cuts out?? rkelly10953 Yamaha YFM660R Raptor (2001-2005) 1 04-22-2007 02:27 PM
Warrior cuts out? Weekend-Warrior Yamaha YFM350 Raptor/Warrior ('87-Present) 7 04-18-2007 08:50 AM
Warrior cuts out top end Ericbs200 Yamaha YFM350 Raptor/Warrior ('87-Present) 8 04-15-2005 10:38 PM
throttle cuts off sand_demon Yamaha YFM350 Raptor/Warrior ('87-Present) 2 02-07-2003 02:17 PM
