YFZ rear brakes?
This is a discussion on YFZ rear brakes? within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; Will a dual piston rear caliper from a yfz work on the 660? If so is it a bolt on or do I need more ...
Old 11-04-2009, 10:27 AM   #1
View xeqshnr's Photo Gallery(0) Send a message via Yahoo to xeqshnr
Default YFZ rear brakes?
Will a dual piston rear caliper from a yfz work on the 660? If so is it a bolt on or do I need more parts from the yfz? I looked thru old threads and never got a solid answer. Anybody know if this works for sure?
'03 Raptor 660LE,Carbon Yosh pipe, pro design air filter setup, IMS shifter, stainless expanded metal radiator guard, AC bumper, GYT-R heel guards, X Factor propeg nerfs, Pro taper contours, odi grips, custom flame graphics, Elka front shocks with rezzy, RPM Dominator axle, +2 LSR swingarm(broke for the third time! JUNK!), Elka rear shock
xeqshnr is offline   Reply With Quote
Old 11-04-2009, 04:56 PM   #2
I dont know why you need more rear braking. I can lock the back tires up with the factory setup.
03 Limited Edition Raptor Hot Rods 720cc Stroker, Stage 2 cam, Sparks 6X Exhaust
dj160/165 needles on 3rd clip, 27.5 Pilot, Fuel Scews 2 turns out
Old 11-06-2009, 01:57 AM   #3
View Swansonator's Photo Gallery(0)
It is not a bolt on. You will have to make a caliper mount for it. I am going to attempt this, its just gonna be awhile. To many other projects to finish first.
The front yfz calipers are a direct bolt on for the front you just have to trim the plastic guards a little. And they make a huge difference.
I see in your signature you have been having problems with you LSR swingarm, I can feel your pain I bought 2 JD Performance swing arms and they cracked all over the place, $1800.00 of junk and one of them was an updated version. Anyway I have an Eyeball Engineering swingarm on it now and it is holding up great, just thought I would share that with ya.
2006 YFZ450 WORCS#71
2003 Raptor BITD#616
2001YZ250
2009 Sponsors: Recovering from broken femur and wrist
Swansonator is offline   Reply With Quote
Old 11-06-2009, 10:07 PM   #4
Hell if your running an Aftermarket swing arm with a Round house carrier why not just get a YFZ brake calipar bracket. Then it should bolt right on.
Old 11-11-2009, 02:48 AM   #5
Thanks for the info guys! I'm in the process of puttin on yfz fronts now. Also switchin to a 700 master cylinder. I need a new swingarm anyway so I might as well get the yfz bracket with it.
Yeah Swansonator i'm not impressed with the Lonestar swinger. Was lookin at eyeball, but i think I'm gonna go with one from SLC Quad customs. You can checkem out here.....SLC Quad Customs Home Page, talked to the owner on the phone and he said he's made 2000 swingarms and hasn't had one come back and the price aint bad so I figured it was worth checkin out.
Old 11-21-2009, 07:19 PM   #6
The stock one will not work, It is thicker and is not clocked properly. I havent seen an aftermarket one.
2001YZ250
Bookmarks
Rear Brakes thompy001 Yamaha YFM660R Raptor (2001-2005) 4 08-22-2005 09:23 PM
REAR BRAKES?? sinister450 Yamaha YFZ450/450R (2004-Present) 7 04-26-2005 08:15 PM
No rear brakes.... jeremys Yamaha YFM660R Raptor (2001-2005) 12 11-05-2004 09:39 PM
rear brakes going out davidmroberts Yamaha YFM660R Raptor (2001-2005) 4 10-05-2004 10:43 PM
Rear Brakes! Warrior03 Yamaha YFM350 Raptor/Warrior ('87-Present) 11 06-01-2004 05:21 PM
