keep blowing fuse - Yamaha ATV Forum
post #1 of 8 Old 07-05-2009, 10:44 AM Thread Starter
keep blowing fuse
I haven't ridden my raptor in a couple years so I just got a new battery and cleaned out the gas tank. But when I put it in neutral and tried to start it there was no green light and no crank. So I checked the fuse and one was blown and every time I kept putting one in it would blow even a 30 amp instead of the 20 trying to get this running asap so any help would be great.
03 blue raptor xcellerator pipe with k&N filter
01 F150 with 6inch lift and 35s
nick660r is offline
post #2 of 8 Old 07-06-2009, 08:16 AM
phucker's Avatar
Send a message via Yahoo to phucker
you have a dead short somewhere, look to see where the mice have been living.
phucker is offline
post #3 of 8 Old 07-06-2009, 09:05 PM
cwall31's Avatar
If you cant pinpoint where the mice have been dinning then with your ignition switch OFF, if the fuse is blowing immediately upon inserting it then your Rectifier is shorted or your Neutral Indicator light or circuit is shorted. Next, make sure your head lights are off then turn on the ignition switch then turn your lights to low then to high. If it still doesnt blow and you havent found grounded out wires then unfortunately its probally your CDI. It shouldnt be your fan cause you have a circuit breaker in line with your fan which SHOULD be tripping if there is a short in your fan. Let me know what you find or if you want a copy of the Raptors Electrical Schematic. GOOD LUCK !!
cwall31 is offline
post #4 of 8 Old 07-06-2009, 09:31 PM
leveldrummer's Avatar
just out of curiousity, have you made sure the positive and negative are correct on the battery?
leveldrummer is offline
post #5 of 8 Old 07-08-2009, 03:50 PM
Quadmaniac's Avatar
Send a message via Yahoo to Quadmaniac
Make sure battery is connected properly
Turn key off, see if fuse still blows - tells you where to start looking for short. If not blowing with key off, then turn run/stop switch off, then key on.. does it blow? further narrows down where short is.
Report back with results.
QuadManiac
'01 Scrambler 400, K&N
Quadmaniac is offline
post #6 of 8 Old 09-03-2009, 12:35 PM Thread Starter
yep i was an idiot the battery wasn't quite the right one so i had it in the wrong way.
nick660r is offline
post #7 of 8 Old 10-21-2013, 08:49 AM
Hi, Im new to the forum and came across your answer. Have the same problem. The ignition fuse keep blowing. It blows as soon as I turn the key to on. When I take out the ignition fuse and replace with higher A the main fuse blows. Have switched light switch to high or low, still same problem. Have switch kill switch to either on or of still same problem.
In my case I was riding all day. Stopped bike and then forgot to take key out ignition. So was in the on position (No not the lights on position) for about 3 hours. Then when wanted to go riding again, thought the battery ran dead. After trying to jump start bike with car realized fuse was blown. Then replaced and kept blowing fuse from there on.
Any suggestions will be greatly appreciated.
iswoes is offline
post #8 of 8 Old 10-22-2013, 03:39 PM
I can't imagine that leaving it on would ruin anything.
Disconnect the battery and hook a set of jumper cables one side to your raptor battery wires and the other to a 12v battery in a vehicle that isn't running. You will be using the vehicles power only to power your electrical system. Turn the key on with a new fuse and see what happens. If it blows the fuse, there is something on the quad shorted. If it doesn't blow the fuse your battery is screwed.
If it blows the fuse, unplug major components one at a time to see which one is shorted, ie stator, CDI, regulator, headlight switch, etc...
Fuse problem Blksnshn Yamaha YFM660R Raptor (2001-2005) 6 11-16-2007 12:23 PM
anyone else ever blow a fuse? bmcdowell40 Yamaha YFZ450/450R (2004-Present) 12 07-02-2005 07:52 AM
BLOWN FUSE warrior_king Yamaha YFM350 Raptor/Warrior ('87-Present) 9 06-02-2004 10:08 AM
Fuse PimpinRaptor66OR Yamaha YFM350 Raptor/Warrior ('87-Present) 8 12-15-2003 06:23 PM
Warrior blowing it's fuse! CATFISH33 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 05-27-2003 05:05 PM
