2005 660 BACK FIREING
This is a discussion on 2005 660 BACK FIREING within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; THE RAPTOR HAS SAT FOR OVER A YEAR PUT IN A NEW CLUTCH AND RODE TUES WHEN ITS AT ABOUT 1/4 THROTAL IT BACK FIRES ...
Old 06-24-2009, 07:56 AM   #1
View monroehillbilly's Photo Gallery(0)
Default 2005 660 BACK FIREING
THE RAPTOR HAS SAT FOR OVER A YEAR PUT IN A NEW CLUTCH AND RODE TUES WHEN ITS AT ABOUT 1/4 THROTAL IT BACK FIRES OR WOOPS , I DRAINED THE OLD GAS PUT IN NEW DRAINED THE CARBS AND CHANGEG THE PLUGS CAN YA HELP?
monroehillbilly is offline   Reply With Quote
Old 06-24-2009, 08:09 AM   #2
My guess is from setting that long the pilot jets have gummed up and the engine isn't getting the fuel it needs.
You will probably have to pull the carbs and clean them to fix your problem.
Old 06-24-2009, 08:25 AM   #3
that what i thought to will i need a new gasket or gaskets to reinstall the carb?
Old 06-24-2009, 08:43 AM   #4
No everything has reusable o-ring seals. They did that right!
Old 07-03-2009, 11:30 AM   #5
View ctraptorken's Photo Gallery(0)
disconnect the reverse and parking brake rev limiter and see if that solves the problem
ctraptorken is offline   Reply With Quote
Old 07-11-2009, 04:52 PM   #6
Quadmaniac's Avatar
View Quadmaniac's Photo Gallery(0) Send a message via Yahoo to Quadmaniac
Clean the carbs : disassembe down to the individual jets and clean their orifices with spray carb cleaner and small copper wire, then blow them out with air, until you can see a solid, clear shaft of light coming through them. The pilot jets, especially, have tiny passages that can get plugged up just sitting in evaporating gas for a month or more.
Also try unplugging the Parking Brake switch connector (green with yellow stripe and black wires in a white 2 pin connector up behind the left headlight; and, if your reverse light does NOT work normally, try grounding the green with white stripe wire down near the output sprocket.
QuadManiac
'01 Scrambler 400, K&N
Quadmaniac is offline   Reply With Quote
Old 07-11-2009, 10:40 PM   #7
View 350rider09's Photo Gallery(0)
have you checked your valve timing or clearances
350rider09 is offline   Reply With Quote
Bookmarks
2005 yfz 450 Raptor_Racer_06 ATVs for Sale 0 02-08-2008 03:46 PM
Warrior not fireing 300ex Yamaha YFM350 Raptor/Warrior ('87-Present) 17 05-27-2005 11:44 AM
2005 almost here trxkiller Yamaha YFZ450/450R (2004-Present) 5 06-15-2004 10:26 PM
