Tip over switch?
This is a discussion on Tip over switch? within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; Seems like when I have my 660 at any type of incline and try to back up the rev limiter kicks in WAY to soon. ...
Old 06-19-2009, 08:08 PM   #1
Baileygunns's Avatar
View Baileygunns's Photo Gallery(0)
Default Tip over switch?
Seems like when I have my 660 at any type of incline and try to back up the rev limiter kicks in WAY to soon. It wants to stall before the rev limiter kicks in becase it isn't making any power... I end up having to slip the Clutch like crazy or quickly "pop" it and sorta rock the Quad back. I was in some mud the other day and I just killed it and dragged it out... Tonight at the car wash I couldn't get it to back up the little slope into the coin-op pressure washing bay... Might it be the parking break rev limiter somehow getting tripped from pulling in the clutch lever? Or is there some kind of an incline senser/tip-over switch? I unloaded it off the truck when I got home and it ripped in reverse on the flat drive way. It will spin the tires... I'm waiting on a perch and a block off plate to get here so I can dump all the E-brake junk. What kind of switch is it? Open or closed? Tie the wires togeather or leave them apart? I assume tie them togeather.
Thanks in advance for any insight.
Baileygunns is offline   Reply With Quote
Old 06-19-2009, 08:56 PM   #2
leveldrummer's Avatar
reverse? who needs reverse? ride a yfz for a while, you will remember how to avoid reverse...
Old 06-19-2009, 10:19 PM   #3
The clutch lever has 2 sensors, one for the parking brake, and one for the safty clutch start. You unplug the one sensor and the other sensor on the raptors wireing harness you plug the 2 bullit conectors in to each other.
03 Limited Edition Raptor Hot Rods 720cc Stroker, Stage 2 cam, Sparks 6X Exhaust
dj160/165 needles on 3rd clip, 27.5 Pilot, Fuel Scews 2 turns out
03LimitedEditionRaptor is online now   Reply With Quote
Old 06-20-2009, 09:11 AM   #4
I have it, I'll use it... Did you say you wanted to trade? I'ld be more than happy. Especially cuz this Raptor only cost me 450 one dollar bills.
Old 06-20-2009, 01:41 PM   #5
haha, just givin ya a hard time, i was really used to having reverse when i got my yfz, and it was worrying me, but i use to ride quads before they even had reverse, and it was never a big deal back then, after a short time, you get use to it again, worse part is getting hung up deep in the woods, you have to get off, drag the ass around, then your good again.
Old 06-20-2009, 02:04 PM   #6
It's good, I should have used more of these cleaver faces and better punctuation to show my sarcasm ... I remember the days of 250R 3wheelers and 4wheelers... Dragging my ass or my friends ass out of snow and mud... My many years on 2 wheels too...
I was in the market for a 450 of some sort when this Raptor fell in my lap. I thought, I really want a 450 but how can I pass up $450??? My brother-in-law had 660 a few years ago so I knew a little about them.
My other thought is to build a killer 660 and keep it. I'll be into it way less than picking up a stock 450. I would like to get into some local racing hence my only other thread about race classes. I think I would have an easier time fitting into a class with a 450.
So any how, I unplugged clutch sensor and plugged it back into itself and I unplugged the parking brake sensor... That one does't need to be jumped? I haven't ridden it yet cuz It's hotter then the Devil's stew in the garage right now and I still need to button up the the fenders.
Old 06-22-2009, 08:39 AM   #7
Just leave the brake unplugged..
diggerzmound is online now   Reply With Quote
Old 06-28-2009, 06:14 PM   #8
View Swansonator's Photo Gallery(0)
You are probably going to want to do the reverse rev limit bypass.
2006 YFZ450 WORCS#71
2003 Raptor BITD#616
2001YZ250
2009 Sponsors: Recovering from broken femur and wrist
Swansonator is offline   Reply With Quote
Old 06-29-2009, 05:13 AM   #9
I think I need too aswell... Still searching for good directions on it...
When in doubt... Throttle out.
Old 06-29-2009, 08:13 PM   #10
All you have to do is ground the wire that goes to the reverse switch (down by the sprocket).
2001YZ250
Old 07-03-2009, 11:25 AM   #11
View ctraptorken's Photo Gallery(0)
just take the wire for the reverse light by the sproket and run it to the negative post on the battery. No more reverse limiter. My 03 would do this randomly till i moved yhis wire, now no more problems.
ctraptorken is offline   Reply With Quote
Old 07-17-2009, 01:59 AM   #12
View jhayson002's Photo Gallery(0)
I have it and i'll used it... Did you say you wanted to trade? I'll be more than happy..
jhayson002 is offline   Reply With Quote
Old 07-21-2009, 10:46 PM   #13
The clutch lever has 2 sensors, one for the parking brake, and one for the safty clutch start. You unplug the one sensor and the other sensor on the raptors wireing harness you plug the 2 bullet connectors in to each other. It's good, I should have used more of these cleaver faces and better punctuation to show my sarcasm ... I remember the days of 250R 3wheelers and 4wheelers... Dragging my ass or my friends ass out of snow and mud... My many years on 2 wheels too
took key switch off p8nt Yamaha YFS200 Blaster ('88-Present) 6 02-09-2005 08:16 PM
Gunnar Kill Switch (An NO Switch) FurBallz Yamaha YFZ450/450R (2004-Present) 2 06-05-2004 09:08 AM
Fan switch? fasterblasteryfz450 Yamaha YFM660R Raptor (2001-2005) 1 03-30-2004 05:35 PM
fan switch travisutley10 Yamaha YFM660R Raptor (2001-2005) 2 12-15-2003 12:42 AM
No Key or Run Switch on Banshee Just Kill Switch??? FMF_Banshee Yamaha YFZ350 Banshee (1987-Present) 6 08-05-2002 08:57 PM
