Disconnect the Reverse Rev Limiter
This is a discussion on Disconnect the Reverse Rev Limiter within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; Do you really need this thing?...
Old 05-31-2009, 10:39 PM   #1
View RaptorJet's Photo Gallery(0)
pissed Disconnect the Reverse Rev Limiter
2002 Raptor - BLUE
ITP Holeshot XCT (front and rear)
ITP Steel Rims
DG A-Arm Guards
AC Racing Frame Skidplate
Armadillo Swingarm Skidplate
Ricky Stator Tie Rods
If you ain't hanging off slidin' you sure as hell ain't ridin'!
RaptorJet is offline   Reply With Quote
Old 06-01-2009, 12:42 AM   #2
View Swansonator's Photo Gallery(0)
No. there are tons of posts on disconnecting it. Just ground the wire to the reverse switch and you are good to go.
2006 YFZ450 WORCS#71
2003 Raptor BITD#616
2001YZ250
2009 Sponsors: Recovering from broken femur and wrist
Swansonator is offline   Reply With Quote
Old 06-06-2009, 09:58 AM   #3
phucker's Avatar
View phucker's Photo Gallery(0) Send a message via Yahoo to phucker
yep, just be careful when in reverse. i did it to mine and my brother rolled it in reverse the next time he rode it. 2nd gear in reverse is kinda fast.
www.barkersexhaust.com
phucker is offline   Reply With Quote
Old 06-10-2009, 09:17 PM   #4
Default What are the colors of the wires for the reverse rev limiter?
What are the colors of the wires for the reverse rev limiter when you disconnect it? I want to make sure I cut and ground the correct wire<s>?
2002 Raptor - BLUE
ITP Steel Rims
DG A-Arm Guards
Old 06-10-2009, 10:05 PM   #5
motorhead's Avatar
View motorhead's Photo Gallery(5)
I tkink its green/white
686 JE 12:1 Ceramic coated piston/head
Trailtech flywheel
Powerbomb header/DG Xccelerator
motorhead is offline   Reply With Quote
Old 06-25-2009, 04:02 PM   #6
View Tommygunn's Photo Gallery(0)
just follow the wires down from the clutch perch. it will be around a bunch of other connecters. i just did this on mine and i almost flipped it over in reverse. lol
Tommygunn is offline   Reply With Quote
Old 07-03-2009, 12:28 PM   #7
View ctraptorken's Photo Gallery(0)
take the wire that has the plug type connector down by the sprocket and connect it to the negative post on the battery and no more problems.
ctraptorken is offline   Reply With Quote
Bookmarks
Reverse Rev limiter ? Raptor GTX Yamaha YFM660R Raptor (2001-2005) 25 05-03-2009 04:50 AM
Reverse limiter gone AND keep the reverse light Quadmaniac Yamaha YFM660R Raptor (2001-2005) 5 05-10-2007 12:02 PM
Reverse Limiter Chris4x4gill2 Yamaha YFM660R Raptor (2001-2005) 5 04-12-2005 06:37 PM
rev limiter and reverse limiter short out 02MXRaptor Yamaha YFM660R Raptor (2001-2005) 0 12-13-2001 09:42 PM
