This is a discussion on EFFIN BACKFIRE...WON'T IDLE IF CHOKE IS OFF! within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; This effer starts right up and runs/idles strong after warm up BUT the choke has to be half on? Also, when you hit the throttle ...
This effer starts right up and runs/idles strong after warm up BUT the choke has to be half on? Also, when you hit the throttle it sounds like its gonna stall and sputters until you let off the throttle....I got awesome compression...timing is on...but if you turn the choke off it won't idle and dies...Help!!!!!!? Could it be the reverse rev limiter...my reverse light blinks when you rev it to much...Help!!!!???
2002 Raptor - BLUE
ITP Holeshot XCT (front and rear)
ITP Steel Rims
DG A-Arm Guards
AC Racing Frame Skidplate
Armadillo Swingarm Skidplate
Ricky Stator Tie Rods
If you ain't hanging off slidin' you sure as hell ain't ridin'!
if it has to run with the choke on it is probably one of your float needles is stuck. crack the drains at the bottom of each carb and let each one flow at least a cup of fuel out of it. if it doesnt freely flow fuel you have a clogged needle and seat. take apart and clean very well.
lmao, hey cant win'em all, i was pissed and confused as to what was going on and after 2 days of fighting i called the dealer to see what i could get out of it haha when i went to load it i flipped it to the reserve tank and BOOYA
Check the boots between the carbs and intake manifold. Make sure they are well seated, clamps are tight and there are no cracks or leaks. You can spray carb cleaner around them at idle to find leaks. If idle speed changes while spraying, you have proof.
take your carbs apart clean them, if that doesn't work get a rebuild kit. the kit fixed mine.
