Battery Upgrade? - Yamaha ATV Forum
post #1 of 8 Old 01-03-2009, 11:22 AM Thread Starter
Battery Upgrade?
My battery in my 02 went south on me. I was thinking about trying to replace it with a higher cca battery. Anyone know what other battery will fit? The old one often had trouble cranking since the install of the 11:1.
Stars n Stripes is offline
post #2 of 8 Old 01-03-2009, 12:15 PM
yfznutt's Avatar
Send a message via Yahoo to yfznutt
Try battery stuff.com.They have a Yuasa w/ 200cca for 79 $ shipped.Or they have a Scorpion for 58$ shipped w/ 200cca.They have an ad in the review section here at BT, check them out.
yfznutt is offline
post #3 of 8 Old 01-03-2009, 05:52 PM
200 cca is the stock rating.
I have herd of people running a Yuasa HD Grizzly battery. It is rated at 320 cca. I think you have to rebend the battery hold down bracket and maybe make a longer Pos batter cable from the starter relay to the battery. Shouldnt be to tough though.
That is the battery I am going to get when mine goes out.
josh
03LimitedEditionRaptor is offline
post #4 of 8 Old 01-03-2009, 08:30 PM
motorhead's Avatar
Deka makes a battery that will fit the raptor 660 with no mods that is 430 cca. I have one in my machine to turn over a 12:1 with no decompression. www.dekabatteries.com Put
etx14 in their search box.
Trailtech flywheel
Trinity stage IV Exhaust
motorhead is offline
post #5 of 8 Old 01-03-2009, 09:00 PM
I dont know where your getting your information from but acording to deka's tech sheet the etx14 is rated at 200 cca at 0 deg F. The highest rating powersports battery they have is only 365 and that battery is 6 5/8"long x 5 3/16"wide x 6 7/8 or 7 3/4 Tall there is no way that battery will fit.
Check it out for your self. The spec chart is at the bottom of page 2
http://www.dekabatteries.com/assets/base/0278.pdf
post #6 of 8 Old 01-04-2009, 06:46 PM
motorhead's Avatar
No, No, No They are way underated to cover their ass. When I bought this battery at a (battery only) store the counter person said It will crank over harleys with ease, He proceded to test in frt of me and it made 434 cca's. I work at a dealer and have my own tester. A year later it still tested 430 cca's on my OWN tester. Its awesome, I would never steer any one the wrong way. I only buy the good shit!!
Trailtech flywheel
post #7 of 8 Old 01-04-2009, 09:52 PM
What you seen was Cranking amps. CCA stands for Cold Cranking Amps. The standard for the test is to be conducted with the battery at 0 deg F. and cranking for 30 seconds. Any battery is going to test better at a hoter temperature.
By the way the grizzly uses the same battery as the harly so a standard batter would be able to start a harly since that is what they come with.
I run an Odyssey PC535 battery. The company rates it a 535cca for 5 sec but it is only rated at 200 CCA. You can make numbers look big for show but when it comes down to it CCA amps is what matters.
http://www.odysseybatteries.com/batteries.htm
post #8 of 8 Old 01-04-2009, 11:06 PM
motorhead's Avatar
Yeah I know what cca stands for after being an auto technician the last 14 years,Lol . Anyways their tester and my $500 rotunda tester must be faulty? You cant test a battery while your cranking, there are too many variables, like engine size, resistance in cables to starter,and temp like you said. The tester ask if over/under 32 deg and componsate.
Trailtech flywheel
YFZ 450 battery upgrade? YFZ 450 Quadaholic Yamaha YFZ450/450R (2004-Present) 3 08-25-2008 08:33 PM
Battery chargers? Was reading about yfz battery being 13.5V maddog05 Yamaha YFZ450/450R (2004-Present) 7 08-15-2004 12:38 AM
450r battery or no battery JBPLAYFZ450 Yamaha YFZ450/450R (2004-Present) 17 11-19-2003 07:41 PM
Upgrade??? kidd324 Yamaha YFS200 Blaster ('88-Present) 8 03-27-2003 08:11 PM
Upgrade? HaroBoy Yamaha YFM350 Raptor/Warrior ('87-Present) 6 03-09-2003 07:01 PM
