Replacing rear axle bearings - Yamaha ATV Forum
This is a discussion on Replacing rear axle bearings within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; How do I best remove the rear axle bearing from the bearing carrier. I see what I think everyone refers to as "the spacer", about ...
Old 06-28-2008, 09:09 PM   #1
View DavidBeebe's Photo Gallery(0)
Default Replacing rear axle bearings
How do I best remove the rear axle bearing from the bearing carrier. I see what I think everyone refers to as "the spacer", about 6 inches long, between the two. It turns with the bearings. I've read in other threads to use a press and push them out. I'm cautious about this because there must be a maximum depth to which you can push a bearing in from each side? I'm just taking caution before I make another expensive mistake. Anybody an expert at this?
DavidBeebe is offline   Reply With Quote
Old 06-28-2008, 10:36 PM   #2
motorhead's Avatar
View motorhead's Photo Gallery(6)
Just pry out the seals with a screwdriver and move the spacer to one side and use a long punch to drive out the bearings on the inner race. When installing the new bearings, drive them in just enough so the outer seals fit flush with the carrier. I neverseize everything during install and pack the housing full of grease to prevent corrision. You need a BIG socket or spacer to fit the race to drive the bearings in so no damage will occur.
Trailtech flywheel
Trinity stage IV Exhaust
motorhead is offline   Reply With Quote
Old 06-29-2008, 01:34 PM   #3
View redrocker's Photo Gallery(0)
remove seals heat up housing around
bearings and smack it on a piece of
wood and the bearings will fall out
hope this helps
redrocker is offline   Reply With Quote
Old 06-29-2008, 02:33 PM   #4
screamin96's Avatar
http://www.bluetraxx.com/tech/axle_bearing.htm
Old 06-30-2008, 05:02 AM   #5
Cantcatchme's Avatar
View Cantcatchme's Photo Gallery(0)
I used an old bearing press at an arbor equipment company to get the bearings in but if u want them out, you can use a sharp punch to get the old bearings out. Never tried the socket way.. but sounds like a good idea.
Tyler\Cantcatchme
03 686cc raptor
102mm CP Piston 11:1/P&P Head/Kenz Custom Grind Cam/Kibble White Springs/3 angle/Barker Duals/+2+1 alba a-arms/Elka Triple Rates/Streamline/etc.
Cantcatchme is offline   Reply With Quote
Old 06-30-2008, 05:53 PM   #6
Thanx everybody. I used motorhead's suggestions most closely. The tech thread was a bit incomplete when it came to the spacer. Not sure if the banshee has the spacer or not. The spacer took a little more effort than I anticipated, but once it was free enough to push aside, then I used a brass drift to bang the bearings out. Bangin' on the inner race was okay cuz i'm not gonna reuse them anyway. I don't like the heat idea just because the bearing carrier is cast aluminum and I'm sure the material density is not evenly distributed. Makes me worry about distorting the shape. I know you didn't say make it glow, but it bothers me none the less. Anyhow i got them out. Not that difficult with the spacer pushed aside.
Old 07-01-2008, 02:10 PM   #7
Bama's Avatar
View Bama's Photo Gallery(0)
red rockers method works pretty good! just enough heat to make the metal expand and pop them out
If you cant ride desert you cant ride anything!
2004 660R
2002 CR250R
2000 XR650R
1990 CR500(sold).....Dinosaurs still rule the earth
Yeay, though I ride through the desert valley in the shadow of death, I shall fear no evil, for i ride the biggest, baddest bike in the valley!!"
Bama is offline   Reply With Quote
2002 yamaha kodiak 400 how to change rear axle bearing
how to change rear wheel bearings on yamha kodiak 400
replacing rear bearings on 2000 kodiak 400
raptor 350 axle bearing seal installation
yamaha blaster swing arm spacers to fit yamaha raptor 350
kodiak 400 rear end bearing replacement
how to change bearing on a yamahavtt
axle bearings raptor 660 forum
rear wheels hard to turn after replacing rear axle bearings on 2005 raptor 660
yamaha kodiak 450 rear axle removal
put new rear axle bearings in my 2005 raptor 660 and the rear wheels are hard to turn now
2000 yamaha kodiac rear axle bearings
Removing rear axle bearings??? sjd78 Yamaha YFM660R Raptor (2001-2005) 7 08-26-2005 05:59 PM
Rear axle bearings Wheeljack Yamaha YFM350 Raptor/Warrior ('87-Present) 4 02-21-2005 08:09 AM
Rear axle bearings are a pain sto'stimemachine Yamaha YFM660R Raptor (2001-2005) 4 07-30-2004 06:57 PM
How hard is it to install rear axle bearings?? cobbstg2wrx Yamaha YFM660R Raptor (2001-2005) 10 09-03-2003 07:51 PM
I'm going to change my rear axle bearings. Any tips or help. jont717 Yamaha YFS200 Blaster ('88-Present) 7 05-24-2003 11:56 AM
