cutting out in reverse - Yamaha ATV Forum
This is a discussion on cutting out in reverse within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; My 04' 660 is cutting out in reverse, when I try to back up. sometimes it won't even run good enough to move back. It ...
Old 03-28-2008, 12:59 PM   #1
View Raptor-Dad's Photo Gallery(0)
Default cutting out in reverse
My 04' 660 is cutting out in reverse, when I try to back up. sometimes it won't even run good enough to move back. It runs great except for when it's in reverse. It has just started doing this. Any ideas what it could be? Why did it just staart doing it ?
Thanks in advance !
Greg
'04 Red and White Raptor 660
'00 Honda 440 EX
'96 Yamaha Blaster
'01 Kasea 150 Skyhawk
Raptor-Dad is offline   Reply With Quote
Old 03-28-2008, 02:19 PM   #2
View jlraska's Photo Gallery(0)
try cleaning the green white wire behind the countershaft sprocket. sometimes chainlube dirtys it up. some have grounded it a number of ways some that lose the light or keep the light.
05 raptor
06 ltz250
05 grizzly 125
05 lt80
jlraska is offline   Reply With Quote
Old 03-28-2008, 05:53 PM   #3
Quadmaniac's Avatar
View Quadmaniac's Photo Gallery(0)
What raska says is pertinent, but only if you have this problem when NOT in reverse.
In your case, although the 'poor running' may seem to have just started, it likely has done it all along. The Rappy has a reverse RPM limiter which is turned on when you put the bike in reverse. This limits RPM in reverse to limit your backwards speed to what Yamaha deemed a 'safe' value.
Unless your reverse switch was somehow stuck in the closed (not in reverse) position, and suddenly became unstuck, you should have always seen the limiter kick in the moment you shifted into reverse. An indicator that the switch had been stuck would be non operation of the reverse light with a return to operation now.
If you wish to eliminate the reverse limiter, simply connect the green/white-stripe wire, which leads from the reverse switch to the CDI, to a good, clean ground on the frame or engine. The CDI will now be fooled into never seeing when you put the bike in reverse. Your reverse light will not work as a result, but perhaps, a small price to pay for being able to have viable power when backing up?
QuadManiac
'01 Scrambler 400, K&N
Quadmaniac is offline   Reply With Quote
Old 03-28-2008, 07:22 PM   #4
petedog9's Avatar
View petedog9's Photo Gallery(0)
nicely put... +1 what quadmaniac said /\ /\ ............
'06 RF Raptor 700 Ltd Ed. LTE / PCIII / K&N /RF built 11:1 / Web stg. 3 / springs / P&P / Elkas / Flexx bars/ Rox risers / lots of bling
'04 raptor red / white full Yoshi pipe GYTR jet kit 160/165 K&n with outerwear (wifes ride)
petedog9 is offline   Reply With Quote
Old 03-28-2008, 08:17 PM   #5
I realize it has a reverse limiter to keep the rpm's down, but mine won't hardly keep running enough to move. Especially in the sand. I just think theres something else going on. Maybe the reverse switch is bad? Can you clean them ?
Thanks,
Greg
'00 Honda 440 EX
'96 Yamaha Blaster
Old 03-28-2008, 10:25 PM   #6
phucker's Avatar
View phucker's Photo Gallery(0)
good call quad maniac, now i dont have to type all of that
www.barkersexhaust.com
phucker is offline   Reply With Quote
Old 03-29-2008, 12:50 AM   #7
Quadmaniac's Avatar
Dad, I have seen times when one can barely make the bike move and others when there is at least a little power evident... seems to sometimes depend on the phase of the moon? I suspect it's more situation dependent - sand vs. dirt, minor uphill vs. downhill. Regardless, if it causes you headaches, you may as well try disabling it.
IF you want, you can simply add a toggle switch that, when thrown, grounds the green/white wire, disabling the limiter. When the toggle switch is returned to it's original, open-contact position, the limiter and light will operate as normal... this way you have an over-ride which is only used when you really need it.
Good Luck!
QuadManiac
raptor 660 cutting out in reverse
660 raptor cuts out in reverse
02 yamaha raptor cuts out when trying to back up
yamaha grizzly 660 cuts out in reverse
my yamaha grizzly four wheeler cuts out when in reverse
yamaha kodiak keeps cutting out
2005 yamaha grizzly 660 cuts out in reverse
yamaha 660 cuts out in revers
yamaha grizzly 660 cuts out in revres
yamaha raptor 660 loses power when on reverse
05 yamaha 350 raptor how to put in reverse
Reverse limiter gone AND keep the reverse light Quadmaniac Yamaha YFM660R Raptor (2001-2005) 5 05-10-2007 12:02 PM
cutting out in reverse!!! 2004Raptor660R Yamaha YFM660R Raptor (2001-2005) 2 03-16-2007 02:03 PM
cutting out??? csmall06 Yamaha YFM660R Raptor (2001-2005) 0 09-28-2003 04:16 PM
Cutting Out? gw2k_101 Yamaha YFS200 Blaster ('88-Present) 4 08-14-2003 12:53 AM
raptor reverse light coming on and cutting out raptor_riders Yamaha YFM660R Raptor (2001-2005) 2 07-06-2003 01:05 AM
