water pump leak - Yamaha ATV Forum
water pump leak
This is a discussion on water pump leak within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; got a leak coming out of the bottom of the water pump out of the small hole at the very bottom. is there supposed to ...
Old 05-20-2007, 03:23 PM   #1
View motorhead9272's Photo Gallery(0)
Default water pump leak
got a leak coming out of the bottom of the water pump out of the small hole at the very bottom. is there supposed to be a hole there? is there a check valve in there or something? i just thought i would ask before i drained all my coolent
02 raptor 660
itp gncc rears, fmf powerbomb header, fmf ti-4 s/o wiseco 11:1 piston, hotcams stage 2 cam with springs, dynatech programable ignition, dial a jet atomizers, uni air filter, wicekd arms +2, 450 shocks, ims roll shifter
motorhead9272 is offline   Reply With Quote
Old 05-20-2007, 07:57 PM   #2
Quadmaniac's Avatar
View Quadmaniac's Photo Gallery(0)
That is called the "weep" hole, and it allows any fluid that gets past the seal on the water pump shaft to exit the pump. If you are seeing more than a drop or two, it probably means that the water pump's shaft seal is leaking. Replacement will likely be necessary.
The seal MAY be available alone. It is Yamaha part number 11H-12438-10-00.SEAL, MECHANICAL. Moto-services.net shows it available for about $20, or check with your dealer. You probably should replace the oil seal at the same time, just to make sure that you never leak any coolant into your block. It's - 93101-12173-00, OIL SEAL
It doesn't look like too tough a job, but I haven't done it myself, so can't tell you for sure.
Good luck!
QuadManiac
'01 Scrambler 400, K&N
Quadmaniac is offline   Reply With Quote
Old 05-20-2007, 09:39 PM   #3
yea i took it apart right before i saw ur post and its very easy i think 4 parts all together. as long as you have snap ring plyers.
02 raptor 660
Old 05-21-2007, 12:30 AM   #4
Mind has dripped a few times. I would just go riding for a day and it would quit. Seems letting it sit over the winter caused it. after the first ride it would quit.
Old 05-21-2007, 08:47 AM   #5
yea im just gonna replace the seals its easy work.
02 raptor 660
Old 05-21-2007, 12:37 PM   #6
Super Moderator
wreckless123's Avatar
View wreckless123's Photo Gallery(0)
When mine went bad, the parts guy said I had to replace the aluminum over and the whole assembly! It was only $40 so I did it, but I am sure you can get just the seals if you wanted to look harder.
2007 Blue/White Raptor SE
wreckless123 is offline   Reply With Quote
Old 05-21-2007, 12:58 PM   #7
yea to change the seals takes about 10 minutes and thats it so im just gonna do that it was only 10 or 15 bucks
02 raptor 660
Old 05-21-2007, 03:48 PM   #8
Quadmaniac's Avatar
Make sure to check the shaft where the seals rub. If it's rough you need to smooth it up with some VERY fine grit sandpaper or crocus cloth and then clean it thourougly before assembly. Else, the leak will visit you again shortly!
QuadManiac
Old 05-25-2007, 04:47 PM   #9
well i just got everything fixed and it was a major pain in the ass. the water seal is a press fit and you have to get that out to change the oil seal. just thought i would let everyone know. and if you are goin to change a seal just change them all it will save you alot of time
02 raptor 660
raptor 660 water pump leaking
raptor 660 leaking from water pup
2002 yamaha raptor 660 water pump
what is the hole on the bottom of my water pump on a raptor 660
03 660 raptor water pump assembaly
2001 yamaha raptor 660 water pump
660 raptor weap hole leak coolant
yamaha raptor 660 weep hole leak
yamaha raptor 660 water pump seal
raptor 660 water pump leaking into coolant
raptor 660 replacing water pump
all my coolant came out the weep hose yamaha rhino
MORE WATER PUMP IFO bluedogrider Yamaha YFZ450/450R (2004-Present) 2 11-05-2003 10:08 PM
Water Pump Leak injun89 Yamaha YFM660R Raptor (2001-2005) 2 04-24-2003 06:52 AM
water pump RxRaptor02 Yamaha YFM660R Raptor (2001-2005) 0 03-02-2003 05:10 PM
Water pump? OCR Yamaha YFM660R Raptor (2001-2005) 0 10-04-2002 04:00 PM
Water Pump Leak mvolosin Yamaha YFM660R Raptor (2001-2005) 1 01-21-2002 08:35 PM
