Hose routing question - Yamaha ATV Forum
This is a discussion on Hose routing question within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; The small hose that comes off the T fitting between the carbs....Which way does it go? And, what is it for? If anyone has some ...
Old 05-04-2007, 08:13 PM   #1
View ironworker3's Photo Gallery(0)
Default Hose routing question
The small hose that comes off the T fitting between the carbs....Which way does it go? And, what is it for? If anyone has some pics of it I'd appreciate it. Tore the sucker apart 3 months ago and now I'm scratching my head. Didn't plan on having it apart that long but stuff happens and you cant get to those little projects sometimes
ironworker3 is offline   Reply With Quote
Old 05-04-2007, 09:27 PM   #2
View firstraptor's Photo Gallery(0)
Carb over flow, don't know where the factory routed it but I extended mine and ran it back away from the exhaust and airfilters.
firstraptor is offline   Reply With Quote
Old 05-04-2007, 11:16 PM   #3
View 1stWarrior95's Photo Gallery(0)
I think that's a vent hose. There's a piece of the frame that sticks up, (I think it's the front support for the seat/rear support for the fuel tank?). That hose runs up under that piece of frame through a couple holders and then just hangs there.
It's been quite awhile since I've had mine apart so you'll have to bear with me in my description...LOL
03 Raptor Bone stock... Honest!
03/04 Raptor built from parts.
It's stock too of course...
1stWarrior95 is offline   Reply With Quote
Old 05-04-2007, 11:56 PM   #4
^ That is where it belongs.
Maybe it's ment as a vent, but if you route it towards the back and stand the quad on end it leaks.
Maybe I should put it back where it belongs.
Old 05-07-2007, 05:31 PM   #5
Thanks guys!
Old 05-07-2007, 07:50 PM   #6
Quadmaniac's Avatar
View Quadmaniac's Photo Gallery(0)
it has two threaded brackets which sit inside both sides of the rear metal support for the tank and rubber carb protector. Two bolts go through the rubber, through the support and thread into these brackets to hold everything together. the hose snakes up one side, over the top and down the other, forming a trap... this keeps gas from leaking out when the bikes tipped back as in wheelie or steep hill
QuadManiac
'01 Scrambler 400, K&N
Quadmaniac is offline   Reply With Quote
2001 raptor 660 carb air line placement
yamaha banshee hose routing
2003 yamaha 660 raptor fuel line routing
96 yamaha warrior 350 carburetor hose schematic
350 wolverine carburator hose routing
does vent hose from gas cap go to carb on yamaha warrior 350
2005 yamaha atv 400 carb hose routing
where do all the hoses go on a 03 400ex
big bear 350 vacuum line
grizzly bear 350 fuel hose hook up
2003 yamaha warrior 350 vacuum hose
breather hose diagram for the 2004 yahama big bear 400
engine noise / crank case hose / carb hose raptorman686 Yamaha YFM660R Raptor (2001-2005) 3 06-15-2005 09:40 PM
cable re-routing??? trevor_cr125 Yamaha YFM660R Raptor (2001-2005) 0 07-09-2004 01:22 AM
hose question JiM417 Yamaha YFM350 Raptor/Warrior ('87-Present) 2 06-28-2004 08:30 PM
Crank case breather hose question madmax Yamaha YFM660R Raptor (2001-2005) 14 07-05-2003 08:51 PM
Quick hose question!!! SubyRex Yamaha YFZ350 Banshee (1987-Present) 3 05-09-2003 01:33 AM
