Clutch cover gasket - Yamaha ATV Forum
Clutch cover gasket
This is a discussion on Clutch cover gasket within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; I just did my 686/cam install and at the end of the weekend my clutch cover gasket blew. I am in the process of replacing ...
Old 03-21-2007, 03:46 PM   #1
View rupp49er's Photo Gallery(0)
Default Clutch cover gasket
I just did my 686/cam install and at the end of the weekend my clutch cover gasket blew. I am in the process of replacing it and was wondering if most people installed the gasket dry or with some gasket sealer? Is it common to blow more gaskets with the higher compression?
07 700R
Lonestar LT A-arms
TCS Long Travel Fronts
Elka Dual rate rear
Tag +1 Steering Stem
Denton Stabilizer
Lone Star +3 axle
Pro Taper CR-mid bars
AC Nerf bars/grab bar
IMS/Roll Foot Pegs/Heel guards/bumper
Bug Gun full exhaust
Alba/Dobeck/Programmer
GYTR Skids/Graphics
Keystone Powered
2004 Raptor 660
11:1 686
Hot Cams Stage 1
Big Gun Exhaust
Pro Design/K&N intake
Alba,GYTR,Terrycable,Renthal
For sale
rupp49er is offline   Reply With Quote
Old 03-21-2007, 05:28 PM   #2
phucker's Avatar
View phucker's Photo Gallery(0)
if you are going to use anything only use aviationg grade permatex on that gasket, absolutely no rtv or silicone. i just put them on dry normally
www.barkersexhaust.com
phucker is offline   Reply With Quote
Old 03-21-2007, 07:17 PM   #3
View UBETRUN's Photo Gallery(0)
Why would a clutch cover gasket "blow"? It's not holding any pressure.
Sometimes the thin section of a stock gasket falls inside on the bottom but won't leak right away. There are better options out there for clutch and stator cover gaskets than stock, I just replaced both sides with a style I hadn't seen before. I think they are Cometic and I got them from Craycraft Racing. They are thick, stiff, and have a thin pebble grain finish that seems to be soft plastic. They are nothing like the stock gaskets, these things are stout and reusable.
"I don't play well with others, it seems others have a problem with losing!"
UBETRUN is offline   Reply With Quote
Old 03-21-2007, 07:57 PM   #4
txraptor's Avatar
View txraptor's Photo Gallery(0)
Yep Cometic makes a darn good gasket.
Just a slow banshee
txraptor is offline   Reply With Quote
Old 03-21-2007, 08:32 PM   #5
phucker's Avatar
ya that is what i have on my engine, i have had the cover on two different engines and off like 3 or 4 different times.
Old 03-22-2007, 10:00 AM   #6
I just finished replacing it and I agree, the stock gasket is crap. I tore one getting it in, they are paper thin, and had to buy another one. The old one had definitely blown, it was dumping oil at an alarming rate. I think I will hunt down a Cometic one and keep it around for the next time I have to get in there.
07 700R
Lonestar LT A-arms
Elka Dual rate rear
Denton Stabilizer
Lone Star +3 axle
GYTR Skids/Graphics
Keystone Powered
2004 Raptor 660
11:1 686
Hot Cams Stage 1
Big Gun Exhaust
For sale
Old 03-22-2007, 06:39 PM   #7
blackoutraptor's Avatar
View blackoutraptor's Photo Gallery(10)
COMETIC ...... their side cover gaskets are great. They have an aluminun center with a rubberized/foam type of material srrounding the aluminum. I just had to get into my side covers again , and I re-used the Cometics with no problems. They pop right off....The paper gaskets always tear and get stuck to either the crankcase or the side cover, then you have to scrape all that crap off before installing a new.. Go with Cometic
720 Stroker, 13.1 piston, MegaCycle X4 cam,
+1 valves, Barker duals, 39mm FCR's
P & P,+4 Eyeball swingarm, Ohlins shocks
Wicked A-Arms, Dura Blue axle......etc.etc.
blackoutraptor is offline   Reply With Quote
where do the copper washers go on the raptor 660 clutch cover
raptor 700 side cover gasket fitting
yamaha raptor 2005 350 crankcase gasket glue
yamaha moto 4 200 have side cover gaskets or use rtv
660 raptor side cover gasket replacement
yamaha rhino 660 clutch cover housing gasket
banshee clutch cover install
brute force stator cover install with rtv or dry?
banshee clutch cover installation gasket
clutch cover gasket yamaha warrior
can u use rtv instead of yamaha bond crankcase raptor 660
reusable banshee clutch cover gasket
clutch gasket gone bad extreme660 Yamaha YFM660R Raptor (2001-2005) 0 10-23-2003 05:39 PM
Cam Mod Valve cover gasket? wgarrett Yamaha YFZ450/450R (2004-Present) 2 08-06-2003 01:59 AM
Removing old gasket from clutch cover. fitzrida Yamaha YFM350 Raptor/Warrior ('87-Present) 2 07-29-2003 07:30 PM
clutch gasket JBanshee Yamaha YFZ350 Banshee (1987-Present) 0 06-10-2003 02:59 AM
Clutch Gasket 96YZF350 Yamaha YFZ350 Banshee (1987-Present) 2 12-03-2001 03:25 AM
