Can you get a stator wet without runining it? - Yamaha ATV Forum
post #1 of 4 Old 03-18-2007, 02:44 PM Thread Starter
Can the stator get wet? My problem is I put my stator cover in the sandblaster thinking I had the stator covered properly but of course a shotload on bead got in the stator and bearing. I want to know if I can flush with h20 without ruining the stator and wiring. Thank you.
remainincognito is offline
post #2 of 4 Old 03-18-2007, 07:00 PM
It wiring won't be harmed by the water. What you could or should do is put it in the oven for an hour or so at low a temperature to be sure it's dry. I'd thing 150 degrees would be ok.
The real problem may come from the shot scratching the varnish insulation on the wires, it may short out if the wires were hit with any force.
The bearing, clean it well and then do it again.
When it comes to putting motor parts in the oven, it'll be easier to beg forgivness than it is to ask permission.
firstraptor is offline
post #3 of 4 Old 03-19-2007, 03:36 AM
I would clean it off with carb cleaner. Actually the best cleaner would be electronic cleaner from Napa. You could probaby get it at any place that sells the CRC Brand of arisol cleaners. It is made for fine electronics. The stator is designed to run in oil. so it is going to be chemical resistant. I would not put it in the oven ethire. The stator is made to get hot from engine oil but the plugs on the end of the wiring harness are not. You would probably melt them.
Here is a link to the stuff I am talking about.
http://www.crcindustries.com/auto/co...x?PN=05102&S=N
Josh
03LimitedEditionRaptor is offline
post #4 of 4 Old 03-19-2007, 08:30 PM
Originally Posted by 03LimitedEditionRaptor
I would clean it off with carb cleaner. Actually the best cleaner would be electronic cleaner from Napa. You could probaby get it at any place that sells the CRC Brand of arisol cleaners. It is made for fine electronics. The stator is designed to run in oil. so it is going to be chemical resistant. I would not put it in the oven either. The stator is made to get hot from engine oil but the plugs on the end of the wiring harness are not.
Josh
That is a better idea,
200watt stator question,is resistance less on a stock stator rob the painter Yamaha YFZ350 Banshee (1987-Present) 5 04-13-2007 08:28 PM
Stator help please Inmonodus Yamaha YFM350 Raptor/Warrior ('87-Present) 8 02-06-2007 06:03 PM
STATOR HELP bbradst01 Yamaha YFS200 Blaster ('88-Present) 1 11-29-2004 01:40 PM
bad stator thumpinhard25 Yamaha YFZ350 Banshee (1987-Present) 2 11-12-2002 05:46 PM
Stator Help rzbanshee Yamaha YFZ350 Banshee (1987-Present) 1 11-06-2001 08:38 PM
