how & what to set camber on new +2 a-arms - Yamaha ATV Forum
This is a discussion on how & what to set camber on new +2 a-arms within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; Hi I just got a set of Laeger +2 A- arms how & what should I set the camber to ? also what is a ...
Old 02-18-2007, 02:57 PM   #1
View chasmat's Photo Gallery(0)
Default how & what to set camber on new +2 a-arms
Hi I just got a set of Laeger +2 A- arms how & what should I set the camber to ? also what is a good setting for toe? This is on my Raptor 660. Thanx for any info! Charlie
chasmat is offline   Reply With Quote
Old 02-19-2007, 09:53 AM   #2
Anyone? should I use an angle finder on the end of the spindle to find camber?
Old 02-22-2007, 07:13 PM   #3
View 660RS27's Photo Gallery(0)
Angle finder with a straight edge on your wheels works good, 2 degree angle is a good all around point to start. No more than 1/4 inch toe in, no less than 0.
Mark
660RS27 is offline   Reply With Quote
Old 02-22-2007, 09:36 PM   #4
View ChuckZilla's Photo Gallery(0)
Here's a tip for setting up the front end. Make sure you have hard pack tires on (no paddles) air them ALL to 10 psi, exactly 10 psi or more, as long as they are all the same, this will make sure that the bike sits even all the way around. I used a cheap angle finder I bought at Harbor Freight, and I set the camber at one degree for each tire. Even at 10 PSI there will still be a slight bulge at the bottom of the tire where it contacts the ground, make sure you are not taking your angle off this bulge, move your straight edge to just in front of or behind the bulge. Hope this helps, I had a hard time getting my Alba front end set up until I knuckled up and did it this way. As far as toe goes, I think anywhere from 1/8 to 1/2 of an inch is typical, I set mine to 1/4". Good luck.
ASA
CORVA
Never ride alone
GPS, money well spent
If you leave trash, you are trash
ChuckZilla is offline   Reply With Quote
camber and toe on a 03 660r
660 raptor camber settings
how to set atv camber
raptor 660 easy way to set toe
what camber setting atv raptor 660
camber setting atv
why is the camber off on my 2001 660 raptor
older style laeger a arms camber
how much camber on raptor 350
how to adjust tire angle on a 2005 raptor 660
atv 2 a arms camber set up
camber bgmac Yamaha YFM660R Raptor (2001-2005) 1 02-18-2007 08:06 PM
camber raptor warrior Yamaha YFM350 Raptor/Warrior ('87-Present) 14 10-18-2004 10:02 AM
is there any way to adjust camber WarriorRyder Yamaha YFM350 Raptor/Warrior ('87-Present) 18 05-03-2004 10:29 PM
Camber and Toe-In Magnum660 Yamaha YFM660R Raptor (2001-2005) 1 04-07-2004 07:47 PM
Camber settings THEMOOSE Yamaha YFM660R Raptor (2001-2005) 6 03-15-2003 01:07 PM
