Raptor electrical problem - Yamaha ATV Forum
post #1 of 11 Old 07-10-2002, 05:19 AM Thread Starter
I think my starter relay assy. has gone out or something. When I try to start my quad nothing happens in the motor. The only thing that does happen is a clicking sound coming from inside the starter relay. It happened to me before but fixed itself or something, because the problem went away.
Does anyone out there know what could have caused this. Or is it coming from somewhere else. I know its only a 30$ part but will it be covered by warrenty. Is this a common prob with 01 craptors.
2001 Raptor
quick_660r is offline
post #2 of 11 Old 07-10-2002, 07:05 AM
I would check your battery connection 1st.That could cause that to happen.I have not seen the starter relay go yet.Make sure that your battery is fully charged as well.
01 Raptor B/W
AC nerf bars/LSR +2 A-arms
Carbon fiber wheels/Holeshots F&R
Polished DG aluminum f/bumper/Oil tank
disconnected reverse rev limiter
axcalibar axle +4 /Polished swing arm
Mac Daddy Rear shock
Tag T-2 Polished Handlebars
HVRAPTOR is offline
post #3 of 11 Old 07-10-2002, 11:35 AM
It sounds like a bad ground.
Remove both batt cables & clean them & the terminals, If it still wont start look at where the ground cable attaches to the frame & clean it too.
Electrical probs are a PIA!!
Sand draggin dune runnin 02 blue Raptor
Sparks Stainless X6
My Web Site
My Image Station album
The Compound
THEMOOSE is offline
post #4 of 11 Old 07-10-2002, 09:09 PM Thread Starter
You can say that again.
I don't think it's a bad battery connection, but I'll check. I'll also find the other end of the ground. thanks for the help.
2001 Raptor
post #5 of 11 Old 07-11-2002, 09:56 PM Thread Starter
I went through it and cleaned just about everything. I didn't come across any problems. My battery doesn't appear to be dead because my headlights work fine. I asked a mechanic and he said that my battery was completely fubar. But if this was the case, why would my headlights work+ the meter on the charger says that the battery is good.
What do you guys think? Should I get the relay? It's only thirty bucks. The bad thing is, yamahaoftroy.com doesn't allow returns on electrical equipment.
2001 Raptor
post #6 of 11 Old 07-11-2002, 10:52 PM
Send a message via AIM to Bodezafa Send a message via Yahoo to Bodezafa
Can you try a different battery before buying the part :)5
"01" Blue Raptor
Bodezafa is offline
post #7 of 11 Old 07-12-2002, 02:37 AM Thread Starter
I did.
2001 Raptor
post #8 of 11 Old 07-22-2002, 06:56 AM Thread Starter
Well, I finaly took it too the shop and they said that I needed a new starter relay and battery.
2001 Raptor
post #9 of 11 Old 03-19-2013, 11:25 AM
yenot75's Avatar
Send a message via Yahoo to yenot75
A battery can show correct voltage but still be bad.....even your lights and accessories may still work. You have to load test a battery to check it properly.
yenot75 is offline
post #10 of 11 Old 05-17-2013, 10:24 PM
Need help and need it fast... first my key will not turn my quad on nuthn works.. second my bike just died while riding then make a clicking noise when I try and start it by the battery.... after a few trys it will start up..... the motor turn ovr but will not start........ please help I just brought the bike ita a raptor660 dont no the year
samiah2012 is offline
post #11 of 11 Old 05-20-2013, 08:00 AM
Check the fuse under the seat, if its clicking it could be a loose connection or bad solenoid.
'02 Raptor electrical problem az350x Yamaha YFM660R Raptor (2001-2005) 5 10-29-2008 12:21 AM
Electrical problem? YamahaForever Yamaha YFM660R Raptor (2001-2005) 2 10-07-2008 07:48 PM
Electrical Problem Puck172 Yamaha YFZ450/450R (2004-Present) 1 02-20-2007 11:41 AM
Raptor starter/electrical problem witti Yamaha YFM660R Raptor (2001-2005) 0 02-23-2005 05:50 PM
Electrical Problem chris86_1 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 04-13-2003 02:19 PM
