How much does it cost?
This is a discussion on How much does it cost? within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; Well my Warrior doesn't start very well when hot and it feels like it's a little down on power compared to a new one so ...
Old 07-03-2002, 06:10 PM   #1
View 350_Warrior_PoWeR's Photo Gallery(0)
Default How much does it cost?
Well my Warrior doesn't start very well when hot and it feels like it's a little down on power compared to a new one so I was wondering how much a rebuild costs. Are most dealers or engine builders the same?
2005 Yamaha YFZ
1997 Yellow/Black Warrior
350_Warrior_PoWeR is offline   Reply With Quote
Old 07-03-2002, 08:02 PM   #2
View BlueRooster's Photo Gallery(0)
Default No
I would shop around. Do as much of the work yourself as you feel comfortable. Some guys and dealers will take you to the cleaners. Be careful.
2001 Blue Raptor,DG Nerfs,GYTR Skids and front bumper, Yamaha Shock Covers, 12tooth Front Sprocket, White Bros E series, K&N air Filter, Nacs oil filter cover and parking brake blockoff, Works clutch lever and perch, Roll design shifter and brake lever
BlueRooster is offline   Reply With Quote
Old 07-04-2002, 12:57 AM   #3
screamin96's Avatar
A simple rebuild (piston, rings, gaskets) will cost ya about $100 in parts, depending which route you go. A shop charges about $55 an hour (here) for labor, and they will probably charge you a minimum of 3 hours labor.
Old 07-05-2002, 03:16 AM   #4
View quick_660r's Photo Gallery(0)
My brother had a P.O.S. shop do a full rebuild(botom and top end) on his motor and it cost like 1800 dollars.
At a real place it would have cost like 3400!!
I don't think a new piston, rings and gaskets would be hard to do put in yourself though. If you have the tools. Plus with the money you save on labor, you can mod your engine while it's apart.
2001 Raptor
quick_660r is offline   Reply With Quote
Old 07-06-2002, 11:58 AM   #5
View BLKnREDwarrior's Photo Gallery(0)
on a warrior i would do the top end work myself because with a clymer manual its very easy to do (as long as you take the motor out of the frame, other wise its a real B!TCH n a 1/2), i've tore apart my top end and i only regret leaving the motor in the frame because of the position of the head, you'll know why if you try the same.
93 Warrior, 500cc FST, black & red cut fenders, HMF pipe, K&N, realtors, kenda fronts, AC mudscreen, green headlights, polished covers, modified cluth perch, dominator bars, WB block off SOLD!!!
BLKnREDwarrior is offline   Reply With Quote
how much does a quad cost
how much does it cost to rebuild a yfz 450
how much does it cost to rebuild an atv engine
how much to they charge to clean a carb on a quad
how much does atv cost
how much dose a transmission cost for atv
how much does a new starter cost for a 450 r
how much should it cost 660 grizzly motor rebuild
how much will it cost to have the carburetor rebuilt on a 2005 polaris predator
how much does it cost to rebuild yfz450 shocks
how much does it cost to have a carburetor rebuild on an atv
how much does 500cc cost
Need more acceleration at low cost.. Raptor GTX Yamaha YFM660R Raptor (2001-2005) 2 07-30-2007 08:07 PM
What does a dyno run cost??? dheil Yamaha YFM660R Raptor (2001-2005) 3 08-21-2003 08:07 AM
How much would Paddles cost? JakeZ400 Yamaha YFZ450/450R (2004-Present) 4 08-05-2003 02:53 PM
How much do Predators cost? AKrider Other Models/Brands 5 06-04-2003 02:28 PM
