Float height adjustment - Yamaha ATV Forum
This is a discussion on Float height adjustment within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; I recently put in a k&N air filter and an exhasut and noticed gas overflowing everywhere. So i followed the clear tube method explained by ...
Old 06-19-2005, 03:41 PM   #1
View crankenstein88's Photo Gallery(0)
Default Float height adjustment
I recently put in a k&N air filter and an exhasut and noticed gas overflowing everywhere. So i followed the clear tube method explained by freez but the fuel line was at 4-5 mm above the split instead of 3. What could happen if it is above 3mm by a little? I noticed a little throttle studder as i was climbing some hills and when i was sideways on a hill gas dumped out of the over flow tube on the right side(the low side). does a stock machine spill gas out of the tubes during hill climbs and stuff like that, i just never thought to check? what do you suggest is going on? alright thanks
2004 limited edition raptor
Trinity stage 4 exhaust
Dynojet kit
K&N air filter and drilled air box
Cobra bumper and grab bar
crankenstein88 is offline   Reply With Quote
Old 06-19-2005, 09:34 PM   #2
View kewlrichie's Photo Gallery(0)
well according to the manual its suppose to be 3mm below the split but if you read the post freez answers that question after adjusting my floats cause i was having an overflow and gas spilling its pretty damn impossible to get it around 13mm float level and have a clear tube of 3mm below.
so i adjusted 3mm ABOVE the split and have a float level around carb#1=15mm and carb#2=16mm or visa versa it made the clear tube 3mm above...anyways it runs beautiful and if you read on it the post i think he said if your doing wheelies it will spill alittle bit, it shouldnt do it if your normally riding up hills, i believe you have to be at a nice angle for it to start spilling if properly adjusted i would say anything past 10 - 11 and def straight up (if your thinking about the the angles as a clock, u know what i mean)
2003 Raptor 660R - DG front bumper, DG thick nerf bars, DG rear skid plate, DG chassis skid plate, GYTR a-arm guards, GYTR oil cooler, Tag metal handlebars, Billet raptor bar clamp, vito racing clutch lever, ITP wheels, Maxxis razr tires, yamaha shock covers, parking brake eliminator
kewlrichie is offline   Reply With Quote
yamaha warrior 350 float adjustment
yfm350 float height
warrior 350 float
setting yfz450 float
yamaha raptor 660 float level adjustment
yamaha banshee float height
what is the float level height on a 2004 yamaha bruin 350
raptor 660 float height
yamaha warrior 350 float adjustment spec
04 yamaha 400 kodiak float adjustment
2005 yamaha warrior float set
yamaha kodiak 450 float level adjustment
Raptor Float Height for wheelies BlueBreadTruck Yamaha YFM350 Raptor/Warrior ('87-Present) 6 06-23-2004 08:37 AM
Stock peg height vs. X-Factor Pro-Peg height screamin96 Yamaha YFZ450/450R (2004-Present) 14 04-26-2004 04:32 PM
float level adjustment with carbs off of bike? Jerry02Raptor Yamaha YFM660R Raptor (2001-2005) 13 10-27-2003 11:44 AM
Float adjustment? Raptorfool Yamaha YFM660R Raptor (2001-2005) 10 07-26-2003 12:02 AM
carb float adjustment for dumbasses tundraotto Yamaha YFM660R Raptor (2001-2005) 3 03-14-2003 08:25 PM
