Raptor timing need help ASAP - Yamaha ATV Forum
This is a discussion on Raptor timing need help ASAP within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; Ok I just put a new timing chain on my raptor 660. There is a little mark on the timing chain gear connected to the ...
Old 05-08-2005, 01:44 PM   #1
View fast03660's Photo Gallery(0)
Default Raptor timing need help ASAP
Ok I just put a new timing chain on my raptor 660. There is a little mark on the timing chain gear connected to the crank, and there is a mark on the case beside it, if I line these two up does that mean it on TDC. The reason I said this is because it soundS like it is missing, can or wil it even run if it is out of time..... [/b]
fast03660 is offline   Reply With Quote
Old 05-08-2005, 02:06 PM   #2
View airraptor760's Photo Gallery(0)
no the mark on the crank cam gear is to aligh tbe gear to the slot on the crank.
to instal the cam you need to have the flywheel installed.
then install the side cover.
now put a breaker bar and 3" extension on a 19mm socket. turn the crank till the timing mark lines up with the mark in the timing plug on the side cover.
now hole it there with the breaker bar. put the chain on the cam gear as close as you can with the three dots on the upper cam gear showing.
two cam dots 180 degree's apart will go horizontal with the top of the head and the middle dot 90 degree's to the top of the head(perpendicular to the other two dots)
now install the cam with the cam lobes pointing down and two holes on the cam should be pointing up.
install the cam into the cam gearby slipping the gear on to the cam.
install bolts hand tight. install chain tensionor and check for TDC,and the three dots as described above if of then pull the chain tensionor out and install rest of the cam weights.
7? hp raptor 320 lbs on gas
airraptor760 is offline   Reply With Quote
Old 05-08-2005, 08:36 PM   #3
oops.....Might need to take it back apart and change that. Thanks for the help.
I got another question my buddy has a z440 he just got done rebuilding, all mine has done to it is yoshi pipe and a k&n filter should i be able to beat him and if not what should i do so i can
Old 05-09-2005, 04:23 AM   #4
i cant really say. i havent seen any z400 bored over and built up. allot depends on the porting carbs cams and so on. i am leaning toward him beating you though. the yoshi full Ti is the best single pipe out there but its still hurting you on the top end. if not wanting to go into the engine i would look at stage one hot cam,35mm fcr's and lte's or barkers dual set up. for around 50 rwhp
how to time a 660 raptor
how to time a raptor 660
2001 yamaha raptor 660 timing marks
how do you time a 2002 yamaha raptor 660
how to set timing on raptor 660
raptor 660 timing off
timing a 660 raptor
timing chain marks 2001 yamaha raptor 660
how to set timing chain on raptor 660
how to put a raptor 660 in time
how to set timing 03 yamaha raptor 660?
raptor timing chain 2strokerip Yamaha YFM660R Raptor (2001-2005) 1 01-20-2007 06:52 PM
timing chain raptor rebuild tido450 Yamaha YFM660R Raptor (2001-2005) 5 01-14-2004 12:48 PM
Timing box for raptor may Yamaha YFM660R Raptor (2001-2005) 4 08-27-2003 10:51 PM
broke my timing chain in my raptor today ........ RAPTORracer Yamaha YFM660R Raptor (2001-2005) 8 04-21-2003 11:59 AM
Raptor Timing Advance Hi Velocity Raptor Yamaha YFM660R Raptor (2001-2005) 14 11-14-2002 08:11 PM
