Leaking Oil - Yamaha ATV Forum
Leaking Oil
This is a discussion on Leaking Oil within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; The other night i went to a track, and after we got home, we noticed that there was oil on the trailer. I looked at ...
Old 05-08-2005, 12:44 AM   #1
View 03raptor660's Photo Gallery(0)
Default Leaking Oil
The other night i went to a track, and after we got home, we noticed that there was oil on the trailer. I looked at my machine and noticed a bit of oil around the shifter. It has been in the garage for two days and no oil has accumulated on the ground. What do you guys think?
2003 Yamaha Raptor - MSR Handlebars, Motion Pro Twist Kit, Baffles Removed, DG Alloy Nerfs
1987 Yamaha Warrior- Baffles Removed, 25's on the rear. SOLD!!!!!.......Finally
03raptor660 is offline   Reply With Quote
Old 05-08-2005, 01:03 AM   #2
View OneCar60Mexicans's Photo Gallery(0)
around the shifter.... check your drain screw.... or it could be the pipe... or the case leaking. Look at your pipe and then make sure your drain screw is tight. If its the case.. then either it needs a new gasket or it is damaged somewhere and it has a leak from the damage...
Blue 2003 660 Raptor
YFZ: Hopefully coming soon!
OneCar60Mexicans is offline   Reply With Quote
Old 05-08-2005, 09:47 AM   #3
View raptorracervt's Photo Gallery(0)
I had the same problem, i thought it was coming from the shifter but the oil was running down from the drive shaft, there is a seal there and a o-ring that i have to replace.....it just pops out with a flat head screw driver....
03' Yamaha Raptor, 11:1 wiseco, stage 1 cam,
full yoshi. exhaust, prodesgin filter (k&n),
elka front shocks, lonestar DC4 a-arms +3, elka dual rate rear shock, +4 lonestar axle, AC nerfs, AC bumper, kenda klaw rear tires, Razr mx front, douglas .190 all around, T2 bars, k and k graphics, barnett clutch, srp rev box, galfer brake lines, etc.....
05' REV 600HO... FLY BARS+ 4" RISER
raptorracervt is offline   Reply With Quote
Old 05-08-2005, 01:05 PM   #4
yeah i forgot about that.. a friend of mine had that happen.. check that too...
Old 05-08-2005, 03:08 PM   #5
View Rappy77's Photo Gallery(0)
Yep this is pretty common. It is a countershaft seal. You remove the sprocket, and it is right there. It cost about 7 bucks at your local stealership.
2004 Raptor
Rappy77 is offline   Reply With Quote
Old 05-08-2005, 03:47 PM   #6
lol yeah but mine would have to order it... because my dealership has NOTHING in stock at all... assholes
Old 05-08-2005, 09:04 PM   #7
would the countershaft seal cause it to leak only when running? I cleaned it up tonight and couldn't find anything leaking. Nothing has leaked in a few days. It hasn;t been driven since but i would like to get it fixed. Pretty sure it isn't the case or the line or the screw. So that leaves me with the shifter seal or the countershaft seal. I will check tomorrow and maybe find something. Any other suggestions? BTW what size is the sprocket nut?
Old 05-08-2005, 09:11 PM   #8
pretty sure its 1 1/4''
Old 05-09-2005, 09:30 AM   #9
Yes it is the countershaft seal. It shouldn't leak unless oil is flowing through there(motor running). My leak looked like it came from behind the sprocket, and run down on the bottom of my case all over my belly skid plate. Like I said, it is pretty common.
2004 Raptor
Old 05-10-2005, 09:53 AM   #10
well i got it out, and if it wasn't wqrecked before, it is now. But anyway i ordered a new one which is going to take a week to get here. Guess i will just have to get the warrior going. Thanks for all the help.
Old 05-10-2005, 07:10 PM   #11
take the front sproket off and start it, you will see the oil start to seap through the bad seal.... just pry the old one out with a flathead and replace it...
Old 05-10-2005, 07:20 PM   #12
ya it is out. New one on the way.
yamaha warrior countershaft seal
why is my 2003 yamaha raptor leaking oil from drive shaft
06 raptor 700 counter shaft seal
my raptor is leaking oil from bottom of motor
660 raptor shock leaks oil
countershaft oil seal yamaha warrior
yamaha raptop oil leak shaft
what size shift shaft seal raptor
shift shaft seal raptor size
raptor 700 counter shaft oring replacenet
raptor yamaha front shock leak
yamaha raptor countershafy seal
oil leaking!!! louis@660 Yamaha YFM660R Raptor (2001-2005) 3 11-23-2004 04:23 PM
Oil leaking all over!! WTF yamrap03 Yamaha YFM660R Raptor (2001-2005) 1 09-13-2004 07:58 AM
LEAKING GAS njwarrior350 Yamaha YFM350 Raptor/Warrior ('87-Present) 13 08-04-2004 10:34 PM
leaking fasterblasteryfz450 Yamaha YFM660R Raptor (2001-2005) 8 05-07-2004 11:46 PM
Gas Leaking PAVERY1500 Yamaha YFM660R Raptor (2001-2005) 2 06-06-2003 11:10 AM
