Raptor oil level check - Yamaha ATV Forum
This is a discussion on Raptor oil level check within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; My owners manual says the motor takes 2 quarts to fill. After I change my oil and add 2 quarts of oil then I check ...
Old 06-11-2002, 05:21 PM   #1
View karnivore660r's Photo Gallery(0)
Default Raptor oil level check
My owners manual says the motor takes 2 quarts to fill. After I change my oil and add 2 quarts of oil then I check the oil level and it is always very low, at least needing another half a quart. I follow the Owners manual and it says to warm the engine up to normal operating level then to shut off engine and let oil seattle for a few minutes then check oil. Is it a misprint in the manual and the raptor actually takes 2-1/2 to 3 quarts of oil? Am I checking the oil wrong? I don't want to overfill it because that is just as bad as under filling it. So what is the deal?
karnivore660r is offline   Reply With Quote
Old 06-11-2002, 05:28 PM   #2
View "1smokinraptor"'s Photo Gallery(0)
yes it takes not quite 2 1/2 quarts on an oil change with filter change. it just barely under 2 1/2 quarts. remember warm the bike up and when checking the oil dont screw the dipstick in the oil tank just stick it in there without screwing it in. hope that helps.
2001 B/W RAPTOR, FMF POWERBOMB PIPE, GYTR CARBON FIBER SILENCER, DG BUMPER, NERFS, COOLANT GAURD, DOUGLAS WHEELS, FAST TREKKER REARS, GYTR GRAPHICS, HEEL PLATES, SHOCKWEARS, RTC CLUTCH LEVER, QUAD SHOP GOODIES, PRM SKIDS, LONESTAR AXLE (THANKS MARTY), PROFLOW W/K&N.
"1smokinraptor" is offline   Reply With Quote
Old 06-11-2002, 05:45 PM   #3
View RAPTOID's Photo Gallery(0)
Mine always takes a little more than 2 quarts as well. The first time or two I thought something was wrong too, but that is just the way it turns out everytime (2 - 2 1/2).
Raptoid 686 ~ Half beast/Half Machine; 102mm Bore/JE 11:1 High Comp Piston; Single 45mm Mikuni Carb; Stage 1 Hotcam/Port & Polish; Sparks Race X-6 Stainless ;+3 LSR Swingarm/+4 LSR Axle; Burgard +2 arms/Works Triples
RAPTOID is offline   Reply With Quote
Old 06-12-2002, 02:35 AM   #4
View quick_660r's Photo Gallery(0)
Same here.
What does over filling do? I neceer over fill it, just curious. Doe's it make it foam or something?
2001 Raptor
quick_660r is offline   Reply With Quote
Old 06-12-2002, 12:04 PM   #5
View breadman30's Photo Gallery(0)
when I first got my Raptor and changed the oil i also had weird oil
readings the very best way to get a good and consiste reading is to check
after it has been rode hard or for a extended time . the tank it self is
just a holding tank for the oil at different times you will get a different readings because there is always oil in the motor some times more some times less do to the oil pump ciruclating the oil thourgh the system. and no having a little more oil in it will not hurt it just as i said the tanks is just a holding tank. I mean the only way you could have to much is if you overfill the tank to the point of it runing over. this is the same basic theroy as race cars use. now if you had all the oil in the crankcase this would not be good but with the tank it recirults its self over and over
so in theroy a little more oil would be good. Anyway hope some of this babble helps!
OTHER SPORTS HAVE BALLS MOTORCROSS
YOU BRING YOUR OWN!
breadman30 is offline   Reply With Quote
Old 06-12-2002, 07:16 PM   #6
View DOM420247's Photo Gallery(0)
2 1/2 is right on here also.how often do you change the oil?my oil seams to hold up very well and for a long time stays clean.i only changed 2 times since last april 01
DOM420247 is offline   Reply With Quote
Old 06-12-2002, 09:17 PM   #7
View YamahaRaptor2002's Photo Gallery(0)
got mine Oct. 16th changed it 4 or 5 times so far did a oil change today
any tips on changing it, it is a pain in the ass any tips welcome
06 Raptor 700 to much to list! The only thing i have left...
02 Raptor LE Sold
98 Honda 300..the whore, back home
2003 Duramax 6" lift rollin on 20/35's.....STOLEN!!!!!!!2-12-09
YamahaRaptor2002 is offline   Reply With Quote
how to check oil level on raptor 660
how to check oil on raptor 660
raptor 660 oil check
how do i check my oil in mt 660 raptor
checking oil 05 660 raptor
where do you check your oil on a raptor 660
2002 yamaha raptor 660 oil check
how to check engine oil on raptor 660
raptor 700 low oil
04 raptor 660 oil level check
how to check oil on 05 yamaha raptor
Raptor carbs, float level and clear tube method explained. Freez Yamaha YFM660R Raptor (2001-2005) 101 11-12-2013 09:28 AM
Raptor Adjusting floats to the right level. BlueWindRider Yamaha YFM660R Raptor (2001-2005) 8 12-11-2003 10:25 PM
jetting for gytr slip on sea level ( raptor) banshee962000 Yamaha YFM660R Raptor (2001-2005) 3 12-01-2002 08:56 AM
what jets for a k&N filter at sea level for a raptor banshee962000 Yamaha YFM660R Raptor (2001-2005) 4 08-31-2002 10:43 PM
help.oil level low in new raptor Dnice Yamaha YFM660R Raptor (2001-2005) 6 12-17-2001 12:33 PM
