Engine#? Is it in the VIN? - Yamaha ATV Forum
This is a discussion on Engine#? Is it in the VIN? within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; I just got my raptor back after 4 months at a shady? bike shop. They were supposed to replace the bad gears in the tranny. ...
Old 01-18-2005, 04:05 PM   #1
View old man R's Photo Gallery(0)
Default Engine#? Is it in the VIN?
I just got my raptor back after 4 months at a shady? bike shop. They were supposed to replace the bad gears in the tranny. I supplied the gears and gaskets. It's not fixed. My question is... Is the engine number the same as the serial number or any part of it? I question whether they swapped engines on me. It's just that something doesn't seem right about the bike now. He had two or three raptors torn down when mine was there.
Frame VIN:jy4amo1391c015032
Engine# m301e-020300
Any help would be appreciated.
old man R is offline   Reply With Quote
Old 01-18-2005, 07:07 PM   #2
View 04raptor04's Photo Gallery(0)
In some states like California the engine number is on the pink slip ... I am not sure if that is true where you live
04raptor04 is offline   Reply With Quote
Old 01-19-2005, 04:23 AM   #3
I have no pink slip, can anyone else help out?
Old 01-19-2005, 04:51 AM   #4
View Jocke72's Photo Gallery(0)
Where did U find the serialnumber on the engine? I only found one at the front of it: 3FY01, sounds more like the modelnumber of something.
I can check mine when I get the chance, if U don't get a reply before that.
/J
Nr 33-Team Boive Racing - Raptor 660/GG 450
Sponsored by:
www.denadaoffroad.se
www.indell.net
www.verktygsboden.se
Jocke72 is offline   Reply With Quote
Old 01-19-2005, 07:30 AM   #5
View 03 raptor's Photo Gallery(0)
mine is the same as my vin number for the last 6 numbers
i think im supposed to write something here
03 raptor is offline   Reply With Quote
Old 01-19-2005, 08:55 AM   #6
Are you looking on the top back of the engine? kind of below the air box on top of the transmission? Just behind the starter, in the center from side to side? That's where I'm finding the above mentioned number. If it's supposed to match the last 6 of the vin, they swapped engines. Starting to sound bad!
Old 01-19-2005, 12:24 PM   #7
View pike1346's Photo Gallery(0)
I would beat some A$$ if they did that to me
2004 Raptor
K&N proflow kit
LRD full exhaust
Dynojet 148/150
no lid
WB Nerfs
ITP C Series
YFZ 450 front shocks
Tusk bars
pike1346 is offline   Reply With Quote
Old 01-19-2005, 03:13 PM   #8
View Raptor660-cg's Photo Gallery(0)
Call this number, (800) 962-7926, Monday - Friday, 8:30 AM and 5:00 PM PST. It's Yamaha's number for ATV information. They should be able to help you figure it out. Given the VIN, they should be able to tell you the engine number that should be on your machine.
03 Raptor (Red/Black) - Full Yoshi system, K&N pro-flow intake (no lid), Razr 2's all around
05 CBR1000RR (Black/Silver)
Raptor660-cg is offline   Reply With Quote
Old 01-19-2005, 03:57 PM   #9
View RidingBlind's Photo Gallery(0)
I can't even imagine my shop pulling that with me.. I'd pull one of the Big Gun pipes off the wall and beat him with it
05 Raptor
Current mods:
'05 YFZ Shocks
Dynojet Needle
Yoshi Full System
L&A Airbox Adaptor
Stage 1 HotCam
Wheel Spacers
Jetting @2500ft:
Mikuni 165/170
Pilot Jets 27.5
3.0 turns on air screws
"Evil will always Triumph over Good, because Good is Dumb"
-Spaceballs
-RidingBlind
RidingBlind is offline   Reply With Quote
Old 01-19-2005, 04:12 PM   #10
View thompy001's Photo Gallery(0)
Id BE PISSSSSED holy shit id flip and id demand to have the names of the other Owners of the bikes cuasee itPRob happened to them to
Im More Affraid Of Being Nothing..... Then Getting Hurt....(Days Of Thunder)
03 Raptor, 686 stage 2 hot cams, KW springs, Sparks exhuast, K&N with pro design, white Maier Plastics Renthal Fat bars, dr.d Reverse, Hole shot xc's Tires
thompy001 is offline   Reply With Quote
Old 01-19-2005, 05:24 PM   #11
View WhiteBrosRaptor's Photo Gallery(0)
not to be a dick, but thats why you do your own shit. if you want it done right do it yourself.
Tommy
2002 Yamaha Raptor w/ some junk.
2008 Yamaha Grizzly 700 EPS. 14" motosport's and 27" swamp lites.
WhiteBrosRaptor is offline   Reply With Quote
Old 01-19-2005, 05:30 PM   #12
View jeeper33's Photo Gallery(0)
The VIN is on the frame, left hand side, (front is to your left, back is to your right) it is located on the very bottom of the frame, almost right under the shift lever. (my frame is powder coated and i had to sand off that area to find mine) the engine number on the top is a referance number, not the technical VIN...hope this helps...
2002 Raptor 660. "Built" 2000 YZ426F. 2006 Kawasaki 650R. 1975 Jeep CJ5.
jeeper33 is offline   Reply With Quote
Old 01-20-2005, 04:58 PM   #13
Thanks for your replies. So far I only have one telling me what I want to here, and he's in Australia! Thanks for the phone number! I want to burn this man so bad, legally. The Raptor still acts the same in 2nd gear, kind of like a worn out sprocket with a loose chain, it jumps and jerks. Was wondering if it could be a bent shifter fork? If I listed all the things that this man did wrong, or didn't do, it would take forever. Anyway, thanks guys.
Old 01-21-2005, 09:07 AM   #14
I'll check my engine number against my VIN tonight (if I remember). But, I don't think any part of it has to match the VIN. I think each manufaturer numbers their engines differently. I'm pretty sure Honda's engine number is exactly the same as the VIN on certain machines. Anyway, use the phone number and you will find out for sure.
yamaha grizzly vin decoder
yamaha raptor engine number location
were to find the serial numbers on a 125 yamaha breeze
are yamaha engine and vin number the same?
yamaha warrior 350 engine numbers
special number for yfz 450r in serial number
2004 raptor 660 vin number location
how to identify what year yfz 450 motor
yfz450 engine vin number
atv vin starts with r
will a yamaha atv engine serial number match the vin
1988 warrior 350 vin on motor match frame
engine # rockey Yamaha YFM660R Raptor (2001-2005) 1 09-19-2011 12:14 PM
What should I do to my engine? mx350warrior Yamaha YFM350 Raptor/Warrior ('87-Present) 6 03-09-2005 08:57 PM
engine oil YFZ450NF150 Yamaha YFZ450/450R (2004-Present) 9 09-20-2004 08:51 PM
1 Blaster engine builder steels another engine builders work criminalpoet Yamaha YFS200 Blaster ('88-Present) 90 08-23-2004 09:38 AM
engine oil ? jbrim Yamaha YFM660R Raptor (2001-2005) 7 10-01-2002 04:11 PM
