Sometimes water gets in their and rusts up the carrier and makes it almost impossible to get it out. Try heat, PB blaster a rubber mallot. I had to beat on mine for about an hour before it finally broke loose. Luckily I was replacing the axle anyway because it was jacked up when I finally done. :s96: :s96: One of the most frustrating hours of my life!!! A torch and a good amount of heat is what finally made her break loose.... Good Luck!
Well i did break a chain adjuster bolt of i dont know if that would be the prob because i dont think its that deep inside and the bolt is hollow because i drilled it out to put a new bolt in.
Have you thrown a heat torch on it?? That is what finally did it for me...Used a block of wood and a mallot to finaly get her to give...There is no other magic formula to do it other then heat, lubricant and brute force. :s96:
