? about timing marks..flywheel and cam - Yamaha ATV Forum
This is a discussion on ? about timing marks..flywheel and cam within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; im finally gettin around to puttin my topend back together..i should have put the motor on topdead center b4 i started the disasemble but i ...
Old 01-09-2005, 06:00 PM   #1
View DiRTdiGGn660's Photo Gallery(0)
Default ? about timing marks..flywheel and cam
im finally gettin around to puttin my topend back together..i should have put the motor on topdead center b4 i started the disasemble but i didnt think of it. my question is..which mark on the flywheel is for TDC??ive seen like 2 diffrent marks, but i didnt go all the way around to look for more because i was stumped...i saw one that looked like a I..and it had another mark almost right beside it which was just a straight mark. so i put it on that mark and shined a light down in the sparkplug whole and the piston is all the way up(or so it looked)so does anyone know what EXACTLY the right mark is suposed to look like??and my other question is about the marks on the cam..i see 2 dots..both directly across the gear from eachother...i kno that once the cam is in, the 2 dots should be directly across the top of the head with the motor on TDC. I know it might sound confusing but thats the best i could think to describe it. so please, i need answers from people that have DONE THIS BEFORE...thanks alot, Chris
04 Rapta Rap: Fresh topend, Shortened WB r-4, XCR Rears, Tag x5 Bars, Smith Gel Grips, AC pro pegs, AC grab bar, Dynojet jet kit, k&n filter
DiRTdiGGn660 is offline   Reply With Quote
Old 01-09-2005, 06:12 PM   #2
View darrengee's Photo Gallery(0)
i think you need to go by the line and not the"I" or "H" mark. I think that the "I" or "H" is used to check your timing with a timing light when the engine is running.
darrengee is offline   Reply With Quote
Old 01-09-2005, 09:44 PM   #3
see the sticky above about adjusting your valves. it'll show you which line to go by.
Old 01-09-2005, 09:59 PM   #4
rookie's Avatar
View rookie's Photo Gallery(0)
Yeah, it is the single line mark, not the I or H.
The cam has three dots, when at TDC there will be two directly across from each other and another straight up at 12 o'clock. The third (top) dot is covered up by the little metal bracket on the cam bolts though.
2007 700R SE (White/Blue) PCIII/Barker's/FCI/Hotcam 2/Dynatek PIM
2006 700R - PCIII/LTE's/GYTR intake - SOLD
Stage 2 Craycraft 660R - SOLD
rookie is offline   Reply With Quote
Old 01-10-2005, 12:08 AM   #5
Old 01-10-2005, 12:51 PM   #6
thanks alot rookie...yeah i was confused when i was lookin at the cam gear and only saw 2 dot and i knew there was three
660 raptor cam timing
raptor 80 tdc
yamaha timing marks
2010 yamaha raptwr 90cc timing marks
cant find third dot on raptor camshaft for timing
where is timing marks on flywheel of a yamaha raptwe 90cc
2001 yamaha raptor 660 timing marks
yamaha grizzly 80 timing marks
how to check timing on a raptor 50
show how to set the timing on a yamaha 80 raptor
2004 raptor 660 timing diagram
04 yamaha raptor 660 cam timing
Flywheel timing mark on yfz 450 iluv2fly Yamaha YFZ450/450R (2004-Present) 1 12-12-2009 01:42 PM
Flywheel strap for installing flywheel DavidBeebe Yamaha YFM660R Raptor (2001-2005) 2 07-13-2007 03:04 PM
Two Marks on Flywheel? warrior-man Yamaha YFM660R Raptor (2001-2005) 4 11-21-2006 05:45 PM
Flywheel timing marks pwostrel Yamaha YFZ450/450R (2004-Present) 6 09-01-2005 10:50 AM
? about timing marks superfastyfz450driver Yamaha YFZ450/450R (2004-Present) 2 04-06-2004 03:10 PM
