Changing Brake Rotor - Yamaha ATV Forum
post #1 of 22 Old 07-20-2004, 04:15 PM Thread Starter
Send a message via MSN to BushManRebel
Hello,
Can anyone tell me whats the best/easy way to change the brake Rotor?
I removed the right rear tire and was trying to take the hub off to see if I can slip on the new brake rotor...I couldn't get off the center nut which holds the hub on and in the process broke my socket wrinch.
I was looking at the 2 big O-nuts that are on the axle..is that the best way to go instead of removing the hub?
Im limited on tools and don't have a big enough wrinch for that size o-nut..my friend is suppose to help me in a few hours after he finishes work.
Dean V.R. Chance
CEO Double Deuce Transport.
Philipsburg, St.Maarten.
Netherlands Antilles.
BushManRebel is offline
post #2 of 22 Old 07-20-2004, 04:16 PM
Send a message via AIM to WhiteBrosRaptor Send a message via MSN to WhiteBrosRaptor
theres no way to change it without taking the hub off...
Tommy
2002 Yamaha Raptor w/ some junk.
2008 Yamaha Grizzly 700 EPS. 14" motosport's and 27" swamp lites.
WhiteBrosRaptor is offline
post #3 of 22 Old 07-20-2004, 04:20 PM Thread Starter
Thanks for the quick reply....are you sure i don't need to take off the 2 o-nuts?....it seems that the inner curcumferance of the rotor might not pass over those o-nuts.
Dean V.R. Chance
post #4 of 22 Old 07-20-2004, 04:24 PM
well, if i remember its a 17mm nut. so its not rare to find a socket and 3/4" ratchet. it comes off hard but it will come off. when my rotor bent, this is what i did... it was easy.
Tommy
post #5 of 22 Old 07-20-2004, 05:29 PM
You need some tools first take off the hub then take a 2.5 allen wrench to loosen the first nut and to take it off use a 2 inch wrench the the second nut will just turn off its two bolts for the caliper and four bolts holding the rotor and your done.
03 Yamaha Raptor, Yoshimura TRS Pro-Series Pipe, Pro Design K&N, 165-170 Main Jets, 25 Pilot Jets, Needle Jet 4th Clip, Tusk Drilled Brake Rotor, Armidillo Swingarm Skid
YoshiRap03 is offline
post #6 of 22 Old 07-20-2004, 05:43 PM Thread Starter
I am trying really hard to get that hub nut off, and all I suceeded was to bust up my hand.....I assume that this nut comes off as any other nut...counterclockwise right?
Dean V.R. Chance
post #7 of 22 Old 07-20-2004, 05:49 PM
Are u talking about the one on the end of the hub with the pin in it or the one on the axle.
post #8 of 22 Old 07-20-2004, 05:58 PM Thread Starter
Yes the one that has a pin in it...outer part of the hub
Dean V.R. Chance
post #9 of 22 Old 07-20-2004, 06:00 PM
I used an air ratchet to get it of what tools do you have at your disposal
post #10 of 22 Old 07-20-2004, 06:04 PM Thread Starter
I had a socket but that also broke in the process. I have a adjustable wrench, but thats not helping much either....am I correct that it's counterclockwise to remove the nut?
Dean V.R. Chance
post #11 of 22 Old 07-20-2004, 07:02 PM
Cantcatchme's Avatar
Send a message via AIM to Cantcatchme
take an adjustable wrench that will fit on the 2 axle lock nuts. put a pipe on the end of the wrench and it will turn w/ no problem.. but make sure u take the lock screws out of the nuts before u go turning anything.
Tyler\Cantcatchme
03 686cc raptor
102mm CP Piston 11:1/P&P Head/Kenz Custom Grind Cam/Kibble White Springs/3 angle/Barker Duals/+2+1 alba a-arms/Elka Triple Rates/Streamline/etc.
Cantcatchme is offline
post #12 of 22 Old 07-20-2004, 07:29 PM Thread Starter
im burning up big time
I managed to get the hub off finally with a pressure wrench.
Thinking everything else will go smootly, the damn allen screws that hold the rotor in placed are seized like a mofo All 4 of em!
I've tried so hard by tapping the screws to get them to unfreeze and after trying to unloose any of them with the allen keys that they are practically rounded out. I give the fuk up
Dean V.R. Chance
post #13 of 22 Old 07-20-2004, 07:50 PM
allen head screws/bolts should not round out... u must be using the wrong size allen wrench. spray some PB penetrating into it and let is soak...
Tommy
post #14 of 22 Old 07-20-2004, 07:54 PM Thread Starter
I used the correct allen head...It seems that those screws are not the strongest quality around..I put some wd-40 thats all I have at the moment.
Going to smoke a Jay and try again later tonite.
Dean V.R. Chance
post #15 of 22 Old 07-20-2004, 08:57 PM
Those allens srtip very easy im telling you air ratchet and a socket allen it will make your life a lot easier.
post #16 of 22 Old 07-20-2004, 09:30 PM Thread Starter
No Luck Guys...im leaving the old one on.
Dean V.R. Chance
post #17 of 22 Old 07-20-2004, 10:42 PM
I'm betting the screws have loctite on them, they will require heat to loosen them before they can be removed.
I found this out on the axle lock nuts, the allan screws were loctited & I ruined 2 allan wrenches trying to get them off!!!
With red loctite (or whatever the factory uses) you will not get them off with out destroying the screws, wrenches, nuckles, etc without heat!!
A good heat gun should be enough to warm them up, just get them good & warm & they should come loose.
Sand draggin dune runnin 02 blue Raptor
Sparks Stainless X6
My Web Site
My Image Station album
The Compound
THEMOOSE is offline
post #18 of 22 Old 07-20-2004, 11:34 PM
When I changed mine the allen screws were impossible to remove without destroying until I heated them. Get an oxy-acetylene torch and heat the heads up. When they turn cherry red, they come out real easy!!
Just remember to reapply Loctite when you are done
slick250 is offline
post #19 of 22 Old 07-20-2004, 11:38 PM
Send a message via MSN to DREWS SHEE Send a message via Yahoo to DREWS SHEE
Beer helps too
2001 Orange Raptor
2002 motor
DREWS SHEE is offline
post #20 of 22 Old 07-21-2004, 12:50 AM
Danger, Danger!!!!
Get rid of the cheap Tiwanese sockets & use the adjustable wrench as a hammer!!!!
Cresent (adjustable) wrenches are only for emergancy use & none of them work as well as a real wrench!!
Do yourself a favor & get some real tools!!
Home Depot, Lowes & Sears have have good tools & have sales all the time, you can get a nice set of basic hand tools with a lifetime warranty without breaking the bank.
Cheap tools will destroy fasteners & cause huge gashes in your knuckles.
You don't have to spend a fortune to have nice tools (unless you must have Snap-On!! LOL)
Sparks Stainless X6
My Web Site
The Compound
THEMOOSE is offline
how can i get off my brake rotor? atvugteammember Yamaha YFM350 Raptor/Warrior ('87-Present) 5 07-28-2004 08:51 PM
brake rotor won't come off atvugteammember Yamaha YFM350 Raptor/Warrior ('87-Present) 5 07-02-2004 10:45 AM
Brake Rotor boomersooner Yamaha YFM660R Raptor (2001-2005) 4 10-20-2003 03:42 PM
changing rear brake rotor outkastjoe Yamaha YFM350 Raptor/Warrior ('87-Present) 3 08-20-2003 09:51 PM
Brake Rotor Hub Thumper 660R Yamaha YFM660R Raptor (2001-2005) 0 04-04-2003 01:43 PM
