Fuel dripping from carb drain hoses - Yamaha ATV Forum
post #1 of 8 Old 06-30-2004, 09:59 AM Thread Starter
Hey,
I have a 2001 Raptor that has an intermittent problem. With the gas petcock on, and the motor off, gas dripps from both carb drain tubes.
When the motor is running it does not drip. This does not always happen.
I can stop the drip by shutting off the gas petcock.
What is wrong?
Hopefully the video is rolling when the excess gas that had build up on my skid plate ignites while I am hauling ass at the dunes....
That would be a sight to see.
Rob.
2001 660R Raptor
660Raptor is offline
post #2 of 8 Old 06-30-2004, 10:20 AM
Have you had your carbs jetted. If not, your floats are probably sticking causing your fuel level to be higher than normal. I had this same problem when I jetted my 02 Raptor with Dynojets. I left the fuel on overnight at the shop and my gas tank emptied into the floor and filled my
air box up. I took the bottom of the carbs off to get to the floats and then started to clean everything up. I also adjusted the float level. I think I seen a Sticky that explains how to do the proceedure. Good luck, I wish we had Dunes here in Kentucky. My 686 raptor would love that.
mclean raptor is offline
post #3 of 8 Old 06-30-2004, 10:24 AM Thread Starter
Hey,
I rejetted a couple of years ago, dynojet stage2. I did not adjust the fload though. I'll have to give it a try. I hate to take the carbs off though,
it's a pin in the ass.
Rob.
2001 660R Raptor
post #4 of 8 Old 06-30-2004, 01:25 PM
Send a message via AIM to nitrotmann Send a message via Yahoo to nitrotmann
I had the same problem. Take off the float bowls and pull off the floats. Pull out the little pointed piece that opens and closes with the floats. I had a piece of t shirt fuzz in there. That should be all there is to it.
You're a Gentleman & a Scholar... And there's damn few of us left.
2003 LE Raptor
Images not allowed in signatures
nitrotmann is offline
post #5 of 8 Old 06-30-2004, 02:08 PM Thread Starter
Hey!
Do I need to remove the carbs to take off the float bowls?
2001 660R Raptor
post #6 of 8 Old 06-30-2004, 02:19 PM
Send a message via AIM to NitrousGuy
Originally Posted by 660Raptor
Hey!
unelss you have super duper small hands, than yes, you will have to remove the carbs to remove the float bowls
The Original Michrider
Tug Hill Veteran '03, '04
NitrousGuy is offline
post #7 of 8 Old 06-30-2004, 02:24 PM Thread Starter
Thanks for the input.
I'll tear it up this weekend
Rob.
2001 660R Raptor
post #8 of 8 Old 06-30-2004, 03:41 PM
Send a message via AIM to WhiteBrosRaptor Send a message via MSN to WhiteBrosRaptor
when that happened to me, i just tapped the bowls and they stopped leaking.
Tommy
2002 Yamaha Raptor w/ some junk.
2008 Yamaha Grizzly 700 EPS. 14" motosport's and 27" swamp lites.
WhiteBrosRaptor is offline
Fuel not getting in carb thecort Yamaha YFZ450/450R (2004-Present) 16 09-02-2005 09:24 PM
carb drain hose help? kcraptor Yamaha YFM660R Raptor (2001-2005) 0 02-21-2005 09:20 PM
No fuel in carb?? Help please Todd 54 Yamaha YFZ450/450R (2004-Present) 5 12-30-2004 04:09 PM
Fuel dripping from vent tubes 660Raptor Yamaha YFM660R Raptor (2001-2005) 11 03-17-2004 11:42 AM
Gas Leaking From Carb Vent hoses breadman30 Yamaha YFM660R Raptor (2001-2005) 8 03-26-2002 07:52 PM
