decompression system install help on new cam ???? - Yamaha ATV Forum
This is a discussion on decompression system install help on new cam ???? within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; well i finally got my decomressions spring int he mail today after a month of ordering it, but now i forgot onhow to realy install ...
Old 02-01-2004, 02:52 PM   #1
View kfickel's Photo Gallery(0)
Default decompression system install help on new cam ????
well i finally got my decomressions spring int he mail today after a month of ordering it, but now i forgot onhow to realy install it, does the spring go in before the little in or the pin first???
kfickel is offline   Reply With Quote
Old 02-01-2004, 03:27 PM   #2
View sto'stimemachine's Photo Gallery(0)
Mine was spring over small pin, small pin through hole in cam, push small pin up with small phillips screwdriver and insert decompression shaft through end of cam.
Coal Shed Racing
sto'stimemachine is offline   Reply With Quote
Old 02-01-2004, 10:44 PM   #3
View sixsixt's Photo Gallery(0)
Spring first
02 RAPTOR LE
sixsixt is offline   Reply With Quote
Old 02-02-2004, 06:13 PM   #4
ok i looked a the blown picture int he repar manual and it shows as if the the pin then the spring, but what keeps them in the cam when it rotates??? is seems like they fall out easily?
Old 02-02-2004, 11:52 PM   #5
i see so many post on cams someone had to do it on their own and know something for me, id really like to get this bike finished by spring
Old 02-03-2004, 09:51 AM   #6
I already told you. You put the spring in then the pin and then slide the rod in the cam while your pushing on the pin thru the bigger hole on the back side of the cam.
If it's together right the pin should come out when you turn the rod and retact when you release the rod as long as you don't rotate the rod to far off of the flat spot for the pin.
02 RAPTOR LE
Old 02-03-2004, 11:08 AM   #7
ok still have me stumped lol
so u put the spring first int he BIG hole, let it fall all the way down, the put the pin in rounded end first... and push ont he pin though the BIG hole and slide the end thing in and rotate it till it sits on the flat spot of th end thing..... do i got u right on that or am i wrong??
Old 02-03-2004, 08:50 PM   #8
By Joe I think you got it.
02 RAPTOR LE
yamaha rhino decompression
yamaha rhino decompressor
raptor 660 decompression pin
rhino 660 decompression
rhino 660 decompression pin
660 rhino decompression system
decompression lever on cam 06 rhino 660
where is the decompression pin on a rhino 700 forum
cam install on yamaha rhino
wr250 decompression camshaft installation
660 rhino decompression problems
how to install grizzly 660 decompression
sheared off decompression pin CRAPTOR Yamaha YFM660R Raptor (2001-2005) 6 04-06-2005 11:04 PM
getting the decompression plug out WoodzRider01 Yamaha YFZ450/450R (2004-Present) 13 03-31-2005 08:55 PM
Hotcam decompression pin? witti Yamaha YFM660R Raptor (2001-2005) 5 01-03-2005 09:43 AM
Hot Cams decompression pin Rider 414 Yamaha YFZ450/450R (2004-Present) 11 12-30-2004 12:15 PM
Hotcam install, how do I reinstall decompression pin?? Skyllz Yamaha YFM660R Raptor (2001-2005) 3 12-08-2003 10:54 PM
