what chain lube is best?? - Yamaha ATV Forum
post #1 of 27 Old 01-09-2002, 09:12 AM Thread Starter
whats best to use on a raptor stock chain?is chain wax any good?what do you guys recommend...
2002 blue raptor.
Dnice is offline
post #2 of 27 Old 01-09-2002, 09:17 AM
ive always used maxima chain wax. seems to work well. im sure it is highly recommended by others. leaves a little film around chain area but it cleans right off with a wire brush.
raptor660r is offline
post #3 of 27 Old 01-09-2002, 09:22 AM
Send a message via MSN to Joker
Yes chain wax is the best in my opinion. It's what I use. It's clean and it doesn't fly off all over your clean bike.
"2nd place is 1st place LOSER"[img]http://groups.msn.com/_Secure/0PwALCGcXKej*el!AsjhikDEeu0TFypTTFenGyOpYusix*cNwX e7EJHA87Dgh65tzF2sXtdKexrcpWtGFRy!g*wuNFLvsV7wG/smallr.jpg[/img]
Joker is offline
post #4 of 27 Old 01-09-2002, 11:34 AM
too much sand on the trails I ride for wax products, the sand really sticks to the wax and wears down my chain and sprockets. I switched to a did x-ring atv chain and use silkolene synthetic, I try to clean and oil the chain every 2 rides which is probably overkill
Raptor 660R (686cc) w trinity-port, 102mm high comp piston, webcam race profile can w/valve springs, Big Gun exhaust,pro-flow k&n no lid, durablue eliminator, full skids, beadlock & racing rims GYTR grafix, ELKA suspension, you name it it's on there
vraptor is offline
post #5 of 27 Old 01-09-2002, 12:31 PM
MFR. It doesn't build up at all. Dirt and sand don't stick to it and it cleans the chain when you spray it on.
yambike is offline
post #6 of 27 Old 01-09-2002, 01:17 PM
Send a message via AIM to Atvman8351
yea i use maxima chain lube it seems to work real good
Nick
2004 Mx Yfz
2002 flattrack banshee
03 xr 50
93 300ex-beater
Atvman8351 is offline
post #7 of 27 Old 01-09-2002, 01:26 PM
I use maxima chain wax no problems w/ sand
labrat660r is offline
post #8 of 27 Old 01-09-2002, 02:23 PM
Send a message via AIM to Ouch Send a message via Yahoo to Ouch
i like chain wax. sprays on, dries. nothin sticks to it and it holds up in water sand mud and all that good stuff
Ouch is offline
post #9 of 27 Old 01-09-2002, 06:08 PM
Sidewinder P-51 is said to be the best (I sound like I write for a magazine). Check it out at http://www.sidewindersprockets.com/p51chainlube.htm They make a pretty convincing argument, and they do make the best chains and sprockets. I got a can of BelRay I bought because I was desperate and it was all they had, and it attracts dirt with the quad sitting still.
_________________
01 Blue Raptor, AC ProPegs, ProDesign/K&N, Stage 2 jet kit, Denton billet stabilizer, Trailtech
95 Warrior, WB E-Series, PRM's, Raz'rs, FST Oil Cooler, K&N, Jetted
<font size=-1>[ This Message was edited by: dmp437 on 2002-01-09 17:11 ]</font>
dmp437 is offline
post #10 of 27 Old 01-09-2002, 07:16 PM
I use P-51 also..Kinda gets all over everything but works good....best was to put it on is: lift rear wheels and put into 1st, apply with wheels spinning slowly (idle). then wipe excess with rag before riding.
RaptorRidinOut is offline
post #11 of 27 Old 01-10-2002, 12:58 AM
Maxima.
2002 Cannondale Speed.
Simply Awsome.
Chicago Family is offline
post #12 of 27 Old 01-10-2002, 02:52 AM
Send a message via MSN to 1FastRaptor
I use PJ1 or Silkolene. I don't like the waxes because I ride in sandy conditions and the sand seems to stick to the wax.
-2005 Blue YFZ450
-2004 Shift Red R1
1FastRaptor is offline
post #13 of 27 Old 01-10-2002, 10:55 AM
I use maxima chain wax about 99% of the ime, but sometimes i use belray chain lube(i got that as a back up, just incase i run outta maxima chain wax) I have had no problems with maxima chain wax it orks great and doesnt flinng!!!
BlueBlast is offline
post #14 of 27 Old 01-10-2002, 01:17 PM
I tried chain lubes and did'nt like them. I like good 'ol fashioned penetrating oil. I use dura-lube spray. It is a little messy, but it works awsome. I've got about 6000 miles on my streetbike chain and there's almost no wear!I've only had to adjust it once in 6000 miles! I used maxima chain lube on my banshee, and it's only got 5 tanks of gas run through it, and the chain is already getting sloppy.I had to adjust it twice already.
blk02banshee is offline
post #15 of 27 Old 09-22-2002, 11:30 PM
Send a message via MSN to 02NY660R Send a message via Yahoo to 02NY660R
True, but I am pretty sure that there is more stress on your quad chain than on your street bike chain.
Yamaha 2002 660R Raptor, DMC Alien Exhaust, Pro-Flow K&N Kit, DynoJet Jetting, No Snorkel, EHS Racing Lid, Lonestar +4" Swing Arm, Trail Tech Bar Clamp, T.M. Designworks Rollers, Jaws Bumper, Armadillo Out-N'-BackRack, APC Blue LED Lights
02NY660R is offline
post #16 of 27 Old 09-23-2002, 09:27 AM
klj
I used to use Maxima chain wax. It worked fine but it seemed to attract sand and dust, tended to buildup, and was messy. It was difficult to clean. I switched to Bel Ray Super Clean chain lube (goes on white). It's not as messy and seems to work good. Much easier to clean than the chain wax and looks good when it goes on...looks like a factory lube like when it was new.
klj is offline
post #17 of 27 Old 09-23-2002, 01:57 PM
Torqo works great with no mess, ya get the lubrication of a chain lube and no mess like wax
Somewhere in AZ
Rapp dude is offline
post #18 of 27 Old 09-23-2002, 03:43 PM
Send a message via Yahoo to SpecWarrior
HP Honda Chain lube. I like that stiff because it comes in a spray can so there is little mess. It is a teflon spray that leaves little film and is designed to help protect the o-rings. My chain is 2 years old and still looks like new. It's good stuff
-=Tug Hill 2004 Veteran=-
2004 YFZ450.LE
*Big Gun Racing Exhaust (Full system ceramic coated)
*SRP Metals steering dampner
*Custom Aluminum ORV Plate
*Dynojet Jetted
*Shark Teeth Graphics
*AC Racing Nerfs
SpecWarrior is offline
post #19 of 27 Old 09-23-2002, 06:21 PM
chain wax
I hate chain wax it turns everything brown and is a pain in the A$$ to get off, pj makes a pretty good lube
velociraptor is offline
post #20 of 27 Old 09-23-2002, 08:00 PM
solder seal farm equipment & chain lube--i was in a pinch and bought what they had at meijers, but don't see any problems
---Michriders---
NitrousGuy says: " i am easily twice the size as R4Race, but he rides his rappy so smoothly. when i ride mine, it feels like i am really working the quad physcially, but he looks like he rides it effortlessly. you look at him, and he is a skiny guy on this big raptor, but he is so smooth that you have to do a double take. he is not slow by any means. just smooth. "
R4RACE is offline
chain lube? cgreen69 Yamaha YFZ450/450R (2004-Present) 26 01-08-2004 07:13 PM
What are you using to lube the chain? raygun Yamaha YFZ450/450R (2004-Present) 5 08-17-2003 08:53 PM
What chain lube do you use? bigmackloud Yamaha YFM350 Raptor/Warrior ('87-Present) 4 04-20-2003 10:25 PM
Best Chain Lube? Wall Street Yamaha YFM660R Raptor (2001-2005) 6 04-12-2003 12:44 PM
