rev limiter bypass - Yamaha ATV Forum
rev limiter bypass
This is a discussion on rev limiter bypass within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; HAS ANY ONE BOUGHT A LIMITER BYPASS, WHAT DOES IT LOOK LIKE, AND WHERE DOES IT PLUG IN. I CANCELLED THE REVERSE LIMITER BY GROUNDING ...
Old 06-19-2003, 12:09 AM   #1
View racershaun's Photo Gallery(0)
Default rev limiter bypass
HAS ANY ONE BOUGHT A LIMITER BYPASS, WHAT DOES IT LOOK LIKE, AND WHERE DOES IT PLUG IN. I CANCELLED THE REVERSE LIMITER BY GROUNDING OUT THE GREEN WIRE THAT COMES FROM BEHIND THE GEAR SHIFTER, BUT THEN I HAVE NO REVERSE LIGHT. I HAVE TRIED SEVERAL THINGS AND CANT KEEP THE LIGHT ON AND CUT THE LIMITER AT THE SAME TIME. ANYONE KNOW HOW?
03 660 rapture. 4 inch extended swingarm, lowered 2 inches, kn, dynojet kit, 22 inch 8 blade taller haulers on 8 inch wheels, 14/39 gearing, the ultimate hillclimbing machine.
racershaun is offline   Reply With Quote
Old 06-19-2003, 12:15 AM   #2
View BadRap's Photo Gallery(0)
Default Try BLUETRAXX!
http://www.bluetraxx.com/review_raptor_bypass.htm
It's pricey, but looks like a high quality mod.
2003 660r Raptor LE (De-Flamed)
Carbon Fiber Warning Labels | Red Shockwears
IMS Direct Shifter | GYT-R Filter Adapter
Scott's Reusable Oil Filter
BadRap is offline   Reply With Quote
Old 06-19-2003, 12:18 AM   #3
View Wraptor's Photo Gallery(0)
I like mine a lot. I leave it off most of the time for safety, and flip the switch if i think I need it.
Wraptor - 02 Blue / Yoshi full / DynoJet/ K&N ProFlow / LE Carbon Fiber Grill / Blue GYT-R Shockwears / GYTR Skids / GYTR Heel plates / Polished Armadillo XC front bumper / Polished 6-pack / Pro Design shitter / Frame Guards / Elka triple rate piggyback rezzys ssd fully adj / +2+1 CHROME upper Blue Transparent Lower Arms / Galfer Stainless Brake Lines / HotCam Stage I / Next = JE 11:1 686 piston and Port & Polish
02 Raptor 80
04 YFZ 450 White & Red
Wraptor is offline   Reply With Quote
Old 06-19-2003, 12:23 AM   #4
THANKS FOR THE SITE, BUT I WOULD JUST LIKE TO KNOW WHERE IT PLUGS IN. IT CANT BE HARD, JUST KNOWING WHICH WIRES TO CROSS OVER.
Old 06-19-2003, 09:00 PM   #5
View NitrousGuy's Photo Gallery(0)
ive got the one that they reviewed on here.
its $80. but its the only way to go if you want a clean, professional looking install
The Original Michrider
Tug Hill Veteran '03, '04
NitrousGuy is offline   Reply With Quote
Old 06-19-2003, 09:13 PM   #6
View Redrap03's Photo Gallery(0)
i did mine for under two bucks and it works just as good
'03 red/black Raptor:
for sale!!!!!!!!!!!!! buy it!!!!!!!
Redrap03 is offline   Reply With Quote
Old 06-19-2003, 09:17 PM   #7
ok, let me rephrase. my reverse light works NO MATTER if im in bypassed mode or not :)
Old 07-03-2003, 11:48 PM   #8
View kdhumphrey's Photo Gallery(0)
you have pm
2002 Limited Edition Raptor wife ride,she wont give it up..
2001 Blue Raptor very nice stock machine/FOR/SALE,JUST BOUGHT 02 LE
2000 Blue Banshee
1985 FL350R Odyssey/need a good rear axle assembly
NEED ENGINE PARTS 4-A-89 TRX-250R-CT 350-STROKER-KIT.
kdhumphrey is offline   Reply With Quote
Old 07-05-2003, 09:51 AM   #9
View warrior007's Photo Gallery(0)
My buddy bought a kit off ebay for $15 and he got just a damn wire..
I checked out the schematics and wiring and did it with just one 12 ohm resistor between the green/white stripe wire and black/tan wire at the CDI.
Alot of the kits just hook the green/white wire to ground, the reverse sensor down on the motor has a current limiting resistor of 12 ohms.
2001 raptor - gytr slip on
1986 TRX250R BEAT
warrior007 is offline   Reply With Quote
yamaha raptor 50 rev limiter bypass
660 raptor rev limiter
yamaha raptor 50 governor bypass
yamaha rhino rev limiter bypass
how to bypass rev limiter on yamaha rhino
yamaha rhino governor bypass
how to bypass rev limiter on 05 yamaha raptor 50
rhino 660 governor
yamaha yfm 400 rev limiters
yamaha 50 raptor governor
Who knows how to bypass the reverse rev limiter? pistolpete Yamaha YFM660R Raptor (2001-2005) 7 05-26-2005 08:00 PM
rev limiter bypass ?'s Raptor660R02 Other Models/Brands 1 02-20-2004 02:37 PM
rev limiter bypass psycho Yamaha YFM660R Raptor (2001-2005) 9 12-18-2003 09:26 PM
Raptor new rev limiter bypass Jarrett Yamaha YFM660R Raptor (2001-2005) 14 07-10-2003 08:07 PM
Bypass the Rev Limiter w/ No Kit BadRap Yamaha YFM660R Raptor (2001-2005) 10 12-17-2002 07:54 AM
