Best Way To Change Rubber - Yamaha ATV Forum
This is a discussion on Best Way To Change Rubber within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; Which is the best way to take the rubber off a rim and put new rubber on.(Big screwdriver pry bar etc.) I have never done ...
Old 04-24-2003, 07:51 AM   #1
View shmoo's Photo Gallery(0)
Default Best Way To Change Rubber
Which is the best way to take the rubber off a rim and put new rubber on.(Big screwdriver pry bar etc.) I have never done this before as this is my first ATV so any tips would be gretly appreciated.Cheers
2002 Raptor
Big Gun Slip On
Pro Design Foam Filter-No Lid
160/165 Mains-25 Pilots
Stock Needles On 3rd Slot
Air/Fuel-2 3/4 Turns Out L & 3 Turns Out R
GYTR Heel Guards,Front Bumper,Side Guards
DG Nerfs
shmoo is offline   Reply With Quote
Old 04-24-2003, 11:12 AM   #2
View Rapterror's Photo Gallery(0)
IMO It is not worth the effort and the risk of damage to your rims/tires to take them off and mount them yourself. Haul'em down to the local tire guy and have him mount your new skids.
2003 LE Raptor- GYT-R skids - Outerwears - Denton Stabilizer - Trail Tech X Bars & Clamp - Trail Tech HID's - PRM grab bar - AC Racing bumper - Yoshimura Comp full system - GYT-R Jet Kit - GYT-R adaptor plate - K&N High Flow w/GYT-R pre-filter.
Rapterror is offline   Reply With Quote
Old 04-24-2003, 11:22 AM   #3
Yeah. I think that's what I'm gonna do.
2002 Raptor
Big Gun Slip On
DG Nerfs
Old 04-24-2003, 11:28 AM   #4
View legs_of_steel's Photo Gallery(0)
IMO Before i had owned my repair shop i used to let all the air out of the tire and break the bead off the rim with the bucket of my bobcat, you can also do this by placing the tire next to you car tire and running over it SLOWLY!! the bead will eventually come off
once the bead is broke get a set of tire irons froma tire or parts store "usaually about 12 bucks a set" and work the tire off the rim then vice versa when putting on the new tire, You can use a big screwdriver but you risk damagiing the bead of the tire or the rim wich will cause the tire to leak so if you must use this wrap the end of the screwdriver in duct tape a few times and that will help
Last Setting beads
this can be tricky so here are your choices
1 Take them to a tire shop and pay to have your beads popped back on
2 Air them up yourself and just maybey the tire bead will set itself
3 my least favorite and worst case scenerio spray a LITTLE BIT!! of stareting fluid in the tire on the rim, light it from a distance and WHAMMO the fuel burns and blows the beads onto the rim
*this is damgerous and even though ive done it a thousand times with bigger tires and car tires etc. i woul use it as a last choice on atv tires but i have done it and it does work
You could have it done but if you are like me you want things done now and if i have a set of rims ,new tires and no money to have them mounted of course ima gonna do them myself
good luck
Keep the Rubber Side Down
legs_of_steel is offline   Reply With Quote
Old 04-24-2003, 11:46 AM   #5
View Wraptor's Photo Gallery(0)
D@mn. I think a shop would be safer at the very least.
the lighter fluid method is Kinda like dropping rocks on a 7mm magnum shell to fire it when you are 13. Not a good idea, and lucky to live through teen angst...
Wraptor - 02 Blue / Yoshi full / DynoJet/ K&N ProFlow / LE Carbon Fiber Grill / Blue GYT-R Shockwears / GYTR Skids / GYTR Heel plates / Polished Armadillo XC front bumper / Polished 6-pack / Pro Design shitter / Frame Guards / Elka triple rate piggyback rezzys ssd fully adj / +2+1 CHROME upper Blue Transparent Lower Arms / Galfer Stainless Brake Lines / HotCam Stage I / Next = JE 11:1 686 piston and Port & Polish
02 Raptor 80
04 YFZ 450 White & Red
Wraptor is offline   Reply With Quote
Old 04-24-2003, 12:34 PM   #6
screamin96's Avatar
Take them somewhere, it's WELL worth it. I have NEVER had luck with that.
Breaking the bead from the old tires and getting them off is the hardest part, but putting the new tires on can be pretty easy.
Old 04-24-2003, 01:20 PM   #7
View bobby bo's Photo Gallery(0)
i had to take mine to a bike dealer,,, cost me 40 bucks just to mount 2 rear tires,,, no other tire place had the machine for such a small rim.. but i found out wal-mart sells and mounts atv tires so u might wanna check there first...
bobby bo is offline   Reply With Quote
Old 04-24-2003, 01:31 PM   #8
View mdraptor's Photo Gallery(0)
Default rubber & rims
worked for hours on mine back a few years, got tired of that real quick......shop down the street won't do it anymore, safety he says...so now I just buy mounted from rckymtn, yea I do have a lot of rims and tires around......wanna buy a few used ones??
mdraptor
It's not so much your age....as your mileage...
mdraptor is offline   Reply With Quote
Old 04-25-2003, 08:11 AM   #9
View MXATVRACER23's Photo Gallery(0)
Yamaha wanted $50 to pull them off and mount new ones. local tire shop $15. check around
2002 LE raptor. Houser longtravel, Elka, Yoshi, Hotcam stage 1, Kibblewhite springs, port/polish, JE 10.75
MXATVRACER23 is offline   Reply With Quote
Old 04-25-2003, 08:22 AM   #10
DSly660R's Avatar
View DSly660R's Photo Gallery(0)
I could use some extra rims...
DS
'03 Blue Raptor:
FLY Blue handlebars
Blue Clear Guards
HMF slip-on, GYTR jet kit, and K&N filter w/GYTR adapter plate
ALBA nerf bars
Blue Tusk shifter
Maxxis Razrs front and rear
DSly660R is offline   Reply With Quote
Old 04-25-2003, 09:43 AM   #11
View TowelsRnotHats's Photo Gallery(0)
Cut the old ones off then....the new ones are easy to put on....
Lots of Soap and water.....
.:Tampa Fl, USA:.
.:Quad Movies:.
TowelsRnotHats is offline   Reply With Quote
Old 04-25-2003, 08:34 PM   #12
View raptorjoe660's Photo Gallery(0)
hey guys changing tires is a snap! i would do it all day long for $20 a tire!!!the hardest part is breaking the bead. all you need is to break it down with a deasil pick-up truck. when i get to the seating the bead part i go straight for the ether can. i like blowing chit up though!! its not raelly that bad thuogh. 30 minutes and i can have em both done.
raptorjoe660 is offline   Reply With Quote
Old 04-25-2003, 08:50 PM   #13
raptor8's Avatar
View raptor8's Photo Gallery(0)
nah just take em to wallymart, or buy a set of tires on the rims from RMATV. either way, you save yerself time danger and blood.
i kept my stockers on the rims so i could use em for sand. they are ready to go...
i've seen that starting fluid thing happen, and while it sounds cool, there aint enuf beer on the planet to get me to do that! LOL
01 raptor, 69 atc90, 81 atc110, 80 atc185, 03 xr50r and helmetcam. working on friends' rides, things like that. Retired now...
raptor8 is offline   Reply With Quote
Old 04-25-2003, 10:22 PM   #14
PPL you make it sound like me and raptorjoe are tellin shmoo to go blow up his garage, i feel i was fair with the warning about setting beads with ether BUT in the real world sometimes its not as easy as getting it done at a shop, what if you need your tires like now on your bike for a race tomorow, than it might just be worth the risk and to be honest if you are careful its not really dangerous at all, just my 2 cents i will never pay to have anything done i can do myself
Old 04-25-2003, 10:52 PM   #15
raptor8's Avatar
aw heck no steel, i'n not slammin ya. its just that for a younger with little experience this can be pretty dangerous thats all.
the kids often dont know the explosive capability of aerosols, etc, and if he uses too much and the whole deal comes apart, whats gonna happen next?
LIke I said, ive seen it done, and i wouldnt do it. but perhaps like you said, someday you may find yerself in a position where there is no alternative.... peace!
Old 04-25-2003, 11:02 PM   #16
View lilsherm89's Photo Gallery(0)
i take em up to goodyear, they didnt even charge me for em!
FOR SALE--1989 Red/Black Banshee--FOR SALE!!!!
T5s-K&N-new plastics-billet and more!!!
lilsherm89 is offline   Reply With Quote
Old 04-28-2003, 08:13 AM   #17
its faster for me to do it myself! i live 30 minutes from town one way. but i love it out in the sticks of mo
Old 04-28-2003, 09:17 AM   #18
View TR_Blaster01's Photo Gallery(0)
My local shop was charging me 15 per tire (take one off, put one on) 10 just to put on. I figured it would be easier to due it myself so i went out and purchased a motorcycle tire changer from rocky mountain atv for 89.99 and a couple tire irons. I have done many for friends for 5 bucks a pop and that paid for the equipment, plus all the money i saved from DIY.
Awesome Blaster Part For Sale
TR_Blaster01 is offline   Reply With Quote
Old 04-28-2003, 10:41 AM   #19
View Yama-bro's Photo Gallery(0)
We bought a ATV tire bead breaker from JC whitney for $30 or so. It makes it pretty easy compared to what some of you guys are talking about. You still have to put some muscle into getting the bead off. Putting the tires back on is easy. Just put some soapy water in a spray bottle and spray a little on the bead and it slips right on.
'03 Blue Raptor
Yama-bro is offline   Reply With Quote
Old 04-28-2003, 10:42 AM   #20
View crslt01's Photo Gallery(0)
anti freeze works very good to seal them, I tried using my truck to break the bead....it just broke my 2x4
05 yfz 450 Sand shark paddles, and holeshot xcr tires.
artic cat 650,27in 589m+s, warn winch
crslt01 is offline   Reply With Quote
use soap and water to mount atv tire
what would cause a front tire to freeze up on my yamaha 4 x 4 atv
Rubber Covers?? raptur Yamaha YFM660R Raptor (2001-2005) 10 01-01-2005 03:05 PM
Rubber intakes mod Freez Yamaha YFM660R Raptor (2001-2005) 14 01-27-2004 10:42 AM
hard rubber red ore Tires & Wheels 11 07-25-2002 08:05 PM
