Oil smells like gas? - Yamaha ATV Forum
This is a discussion on Oil smells like gas? within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; Why does my oil smell like gas? Second I am leaking oil and dont know why. I am about to change the O-ring on the ...
Old 03-21-2003, 10:36 PM   #1
View 02RaptorLE's Photo Gallery(0)
Default Oil smells like gas?
Why does my oil smell like gas? Second I am leaking oil and dont know why. I am about to change the O-ring on the hose that goes to the bottom of the oil resevoir. If that doesnt fix the leak then what could be, a crack in the resevoir?
02RaptorLE is offline   Reply With Quote
Old 03-21-2003, 10:52 PM   #2
View THEMOOSE's Photo Gallery(0)
The most likley reasons your oil smells like gas is,
1 you are waaaay rich & the gas is washing down the cylinder & getting into the bottom end.
2. your float highth is too high & gas is getting into the cyl flooding it washing it down
3. you crashed your quad & it sat on it's side or upside down & gas flooded the cyl.
4. your rings are shot, check your compression
1 through 3 is an easy fix, 4 is gonna be harder!
The Raptors oil tanks have been known to crack, usually by the drain plug.
Sand draggin dune runnin 02 blue Raptor
Sparks Stainless X6
My Web Site
My Image Station album
The Compound
THEMOOSE is offline   Reply With Quote
Old 03-21-2003, 11:25 PM   #3
1. You are probably right because I just got a slip-on and rode it for a little bit just to see what is like with the slip-on and I have not rejetted yet.
2. Ealborate more(I am new to this stuff)
3. I crashed a long time ago but everything has been fixed.
4. God I hope not.
Sorry for my stupidity on #2.
Oh and THE MOOSE how do you like your sparks exhaust?
Old 03-22-2003, 12:54 AM   #4
4. God I hope not.
1. if you put on a slipon without rejetting your lean not rich
2. if you've ever had your carbs off & bumped them your floats could be off or if you have some trash in your carb it could cause your carb bowles to over fill.
To check your float highth get a clear piece of plastic tube that'll fit on your carb drain (the one with the screw next to it) open up the drain & hold the tube next to the carb, the gas should come up to just 3mm-4mm below the mating surface.
3. was this the first oil change since the crash?
Has your oil smelled like gas for more than 1 oil change?
4. LOL I hear ya but check your compression to be safe.
how many hours do you have on your engine??
My sparks Rocks!!
Looks & sounds great & gave me a big seat of the pants HP gain!!
Sparks Stainless X6
My Web Site
The Compound
Old 03-22-2003, 03:38 PM   #5
This would be the third oil change all together. I wrecked it before the first oil change(actually a friend did but that is another story). All in all my raptor only has about fifty to sixty hours on it.
How do you check the compression? I would like to check that just to be safe.
Oh and MOOSE thanx.
Matt
Guns are as responsible for killing people as the spoon is for making Rosie O' Donnell fat
Old 03-22-2003, 04:01 PM   #6
View R4RACE's Photo Gallery(0)
to check compression you will need a compression guage (should be able to find one at any auto-parts store) then remove spark plug and grounde the plug wire install the gauge in place of the spark plug crank it over a few revolutions (hold the start button about 4-5 seconds) read gauge
"standard compression pressure (at sea level) 1,250 kPa (12.5 kg/cm2, 181 psi)
---Michriders---
NitrousGuy says: " i am easily twice the size as R4Race, but he rides his rappy so smoothly. when i ride mine, it feels like i am really working the quad physcially, but he looks like he rides it effortlessly. you look at him, and he is a skiny guy on this big raptor, but he is so smooth that you have to do a double take. he is not slow by any means. just smooth. "
R4RACE is offline   Reply With Quote
Old 03-22-2003, 09:58 PM   #7
In addition to what R4Race said make sure you hold the throttle wide open when you crank it & if you can hook a batt charger up to the batt to help it crank over faster.
At the very least make sure your batt is fully charged when you crank it to check the compression.
Sparks Stainless X6
My Web Site
The Compound
4 wheeler oil smells like gas
yamaha 4 wheeler gas in oil
gas in oil engine what does it mean
getting gas in my oil on 4wheeler
why does my banshee stink like gas
atv gas in oil fix
why would gas mix woth oil on a quad
four wheeler has gas in the oil
why does oil in banshee350 smell like ruber?
why is oil getting into the gas in my four wheeler
raptor 660 oil smell alittle like gas
4 wheeler getting gas in the oil?
Changed oil....smells of Gas?! shawn7 Other Models/Brands 6 09-11-2004 04:37 AM
Need help ASAP oil smells like gas Jamie Yamaha YFZ450/450R (2004-Present) 7 11-03-2003 09:03 PM
