How do I calculate CC's ? - Yamaha ATV Forum
This is a discussion on How do I calculate CC's ? within the Yamaha YFM660R Raptor (2001-2005) forums, part of the Performance /Technical category; What is the formula for figuring out my displacement? My motor is bored out .020 over in case anyone already knows....
Old 12-06-2001, 12:04 AM   #1
View ultim8warrior's Photo Gallery(0)
ultim8warrior is offline   Reply With Quote
Old 12-06-2001, 04:15 AM   #2
screamin96's Avatar
You gained maybe 3-4 cc's.
Old 12-06-2001, 06:41 AM   #3
View yamahauler's Photo Gallery(0)
radius squared, multiply by pi, and then multiply that by your stroke, you can then multiply that number by number of cylinders. Thats it!
yamahauler is offline   Reply With Quote
Old 12-06-2001, 09:54 PM   #4
View offroadgeek's Photo Gallery(0)
B x B x 0.7854 x S x N
B = BORE cm
S = STROKE cm
N = NUMBER OF CYLINDERS
offroadgeek is offline   Reply With Quote
Old 12-07-2001, 02:47 AM   #5
View badercarma's Photo Gallery(0)
cc's stands for cubic centimeters, couldnt you just fill it with water then peasure how much water? I dont think its a great idea to fill you engine with water thoe, maby use gas.
`95 honda 400cc 4x4
`06 tw200
`86 bw200
Loud pipes close trails.
badercarma is offline   Reply With Quote
Old 12-07-2001, 03:12 AM   #6
hmm, interesting formula, but its unique, thats why I use logic, and it always works, thats why I say:
- *pi(r)^2* <-formula for area of a circle
times stroke, will give you area of the cylinder,
times number of cylinders of course.
Its easy to remember, so you never have to look it up! Just remember the area of a circle and your fine!
Old 12-07-2001, 06:22 PM   #7
It's the same formula.
r = 1/2 bore
pi = 4 x .7854
We know the bore and stroke, so we don't need to measure the radius. Remove the logic and it's Engine cc's for Dummies. ;)
Old 12-08-2001, 12:40 AM   #8
I tried badercarma's suggestion and I almost got smashed by my own 4-wheeler. HOLY CRAP that thing was hard to flip over to get the water out back out.
92 warrior, Wiseco +.040, ALBA pipe, K&N, 36MM round slide carb,Ti valve springs, Maier plastic, 14 tooth sprocket, Bandits, Douglas .190's, Fly alum. bars, DG bumpers and nerf bars,oil cooler by Mascman
04 KFX 400
Old 12-08-2001, 02:31 AM   #9
They actually do that suggestion in some sancioning bodies of drag racing to confirm that you have the displacement you say you do. You dont turn the quad over of course, you just leave the plug out and crank it over... I'm not sure what they use to fill it with, though.
Old 12-08-2001, 03:00 AM   #10
View Warriorwisely's Photo Gallery(0)
take the height of your shatf and divide it by 2.21 then add the numbers of tries your scooter has and then thats it......make sure that you change your bumber oil and lube your hammerrod rod 10w40!
Warriorwisely is offline   Reply With Quote
Old 02-11-2002, 06:05 PM   #11
View gman's Photo Gallery(0)
another "less scientific way" is to take the number of lugnuts on your bike divided by the number of links on your chain. mltipy this by the length of your swingarm and then add to the combined number of inches of travel your front shocks offer. subtract this number from your date of birth and add your current age. you now have your answer. wasn't that easy??!! :)20 :)20 :)20 :)20 :)20 :)20 thanks for the info there. obviously, yours is more informative than mine.
gman is offline   Reply With Quote
Old 02-11-2002, 08:02 PM   #12
View RaptorBrad2's Photo Gallery(0)
pi * radius^2 * bore
All the measurements must be in CM if you want CCs
a raptor is 100mm bore and 84mm stroke
so change it to cm:10cm bore and 8.4 cm stroke
radius = 1/2 the bore, or 5 cm
3.1415 * 5^2 * 8.4=
3.1415 * 25 * 8.4 = 659.715cc
Now .020" over = 0.5080mm
so the equation is:
100.508mm bore
84mm stroke
convert to cm
10.0508cm bore
8.4cm stroke
plug into the above formula
3.1415 * 5.0254^2 * 8.4=
3.1415 * 25.255 * 8.4 = 666.444
So on a raptor the displacement change is 666.444 - 659.715 = 6.729ccs larger
that's just a little over 1% larger than stock..
damn.. and I just noticed you have a warrior.. not raptor
83 bore x 64.5mm stroke
same numbers apply
348.97 cc stock
353.26 bored .020 over
difference of 4.29ccs
<font size=-1>[ This Message was edited by: RaptorBrad2 on 2002-02-11 18:05 ]</font>
RaptorBrad2 is offline   Reply With Quote
Old 02-11-2002, 08:12 PM   #13
View RAPTORMEAN's Photo Gallery(0)
my brain hurts now
01 RAPTOR DMC alien pipes
K&N power kit and filter
gyt-r-skids,heel guards,grab bars
trail tech bar clamp and panoram computer
original Maxxis Razr's on all corners
RAPTORMEAN is offline   Reply With Quote
Old 02-12-2002, 12:40 PM   #14
View vraptor's Photo Gallery(0)
pi*(r*r)*stroke divide by 1000, r is the radius of your piston
Raptor 660R (686cc) w trinity-port, 102mm high comp piston, webcam race profile can w/valve springs, Big Gun exhaust,pro-flow k&n no lid, durablue eliminator, full skids, beadlock & racing rims GYTR grafix, ELKA suspension, you name it it's on there
vraptor is offline   Reply With Quote
how to determine displacement on a atv engine
how to calculate displacement of banshee motor
how to figure up the cc of your yfz 450 after mods
yamaha quad 2400cm what size is it in cc
how to determine cc of an rhino engine
how to find ccs in atv
84mm how many cc
how do i calculate displacement banshee
how to tell what cc your atv is after a bore
how to measure cc of atv engine
what's the cubic inch of a banshee bored 100 over
how to measure stroke of 02 raptor 660
Legal cc's for racing johnnymaddog Yamaha YFZ450/450R (2004-Present) 7 08-11-2004 09:55 AM
bore->cc's YamahaWarrior_350 Yamaha YFM350 Raptor/Warrior ('87-Present) 16 04-07-2004 10:10 AM
cc's bigair450 Yamaha YFZ450/450R (2004-Present) 3 03-27-2004 07:23 AM
Will Yamaha up the cc's on the Yfz? 5150HARVEE Yamaha YFZ450/450R (2004-Present) 20 02-07-2004 11:03 PM
how to get more cc's on warrior... warrior90 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 01-16-2002 06:00 PM
