What's the best set up for air filteration? - Yamaha ATV Forum
This is a discussion on What's the best set up for air filteration? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; What do you guys recommend is the best set up for a new air filter system? I'm thinking a K&N Air Filter with an outerwear ...
Old 08-10-2012, 09:42 PM   #1
View JakeBloom's Photo Gallery(0)
Default What's the best set up for air filteration?
What do you guys recommend is the best set up for a new air filter system? I'm thinking a K&N Air Filter with an outerwear screen instead of the airbox lid. But without the air box lid, I don't think the filter will stay in place properly... how do I get around this? Has anyone tried this setup? Do most people also use an outerwear pre filter on the K&N filter itself in addition to the screen in place of the air box lid? Or is it a better idea just to get the lid vents? Any help is greatly appreciated, as I'm a noob to this kind of stuff.
Edit: looks like there's an adapter kit from pro design... one comes with a foam filter and one comes with a k&n... which do most people use?
JakeBloom is offline   Reply With Quote
Old 08-12-2012, 01:27 PM   #2
BEASTLYWARRIOR228's Avatar
View BEASTLYWARRIOR228's Photo Gallery(0)
Foam filter i learned the hard way last weekend used a fabric filter with outerwares it let a bunch of dirt by and blew my new motor
Lonestar, Ohlins, American Star Racing, Houser, Fasst Flexx, PRM, Yoshimura, Omf, GBC, Wiseco
BEASTLYWARRIOR228 is offline   Reply With Quote
Old 08-12-2012, 11:20 PM   #3
Dang... what brand was the filter?
Old 08-13-2012, 08:13 AM   #4
View kevinsranger's Photo Gallery(0)
YUP!! k & n and all fabric filters flow more air and also let ALOT more dirt by, oiled foam is the best way to go to protect your engine, the extra hp gains by using a k & n are going to cost you with more frequent rebuilds
kevinsranger is offline   Reply With Quote
Old 08-13-2012, 12:49 PM   #5
Gyt-r
Old 08-13-2012, 04:49 PM   #6
nekrofilliak's Avatar
View nekrofilliak's Photo Gallery(0)
x2 for BEASTLYWARRIOR228
Foam filter !
nekrofilliak is offline   Reply With Quote
Old 08-13-2012, 07:06 PM   #7
Immortal_ATV's Avatar
View Immortal_ATV's Photo Gallery(0)
Best flow, K&N, but you need to keep them clean and oiled properly, I have ran these for 20+ years with no problems in MX, sand, dusty... but you have to keep them clean:
Modquad Air Flow System with K&N Filter Yamaha Raptor 350-Immortal ATV
For the maintenance impaired, foam:
Pro Design Pro-Flow Uni Intake System Yamaha Raptor 350-Immortal ATV
Immortal_ATV is offline   Reply With Quote
Old 08-13-2012, 09:40 PM   #8
What are your suggestions for frequency and technique of cleaning and oiling fabric filters like the K&N ones?
Old 08-13-2012, 10:03 PM   #9
polariford's Avatar
View polariford's Photo Gallery(1)
I clean it after every ride. Soap and water rinse repeat. Takes 5 minutes then a good liberal oiling the next day and ready to go.
polariford is offline   Reply With Quote
Old 08-14-2012, 02:37 AM   #10
View Chipnrail's Photo Gallery(0)
my 06 banshee has the double filter changed over to a single k&n with an outer wear and the lid removed. It's had no trouble at all. And I have over 100 hours with it. The only problem I've had is if you apply to much oil to the filter, the cotton swells up and starves the engine for air.
06 350 Banshee
91 200 Blaster
Chipnrail is offline   Reply With Quote
Old 08-14-2012, 11:14 AM   #11
K&N makes a cleaner and the oil and they suggest how to use it. If super dusty I will clean/oil every ride, most of the time I just inspect the filter and only clean the outerwear(BTW, no lid on mine). Motors last a long time if maintained properly, too clean is better than too dirty. If you think you might lag on the maintenance then I'd suggest foam, but either way a dirty filter robs performance and eats your motor!!
Old 08-14-2012, 05:54 PM   #12
I cleaned mine every ride
Old 08-15-2012, 08:27 AM   #13
View camper4lyfe's Photo Gallery(0)
Cleaning a K&N after every ride isn't a good thing. The K&N's actually filter better once they get dirty. Until then, they'll let me dirt and grit through than a standard foam filter.
camper4lyfe is offline   Reply With Quote
Old 08-18-2012, 03:59 PM   #14
View sportbika's Photo Gallery(0)
i ran a open k&N filter due to me adding a yfz 450 rear shock, works great with a jet kit. i did make a bracket to help support the filter and carb
sportbika is offline   Reply With Quote
banshee air filter same as warrior
has anyone tried using a prefilter instead of a screen on a john deere 4020
do i install outerwear filter over my foam pre filter
best way to clean pro flow foam filter
no lid banshee
outerwear or no lid banshee
how does warrior quad air filter attach
is modquad proflow k&n good in dust
what does an air filter look like for warrior 350
raptor 350 outerwear
warrior 350 k&n or uni?
foam filter with outerwear no lid
