Unsticking a Clutch? - Yamaha ATV Forum
post #1 of 3 Old 05-18-2012, 07:43 AM Thread Starter
wontacceptthis's Avatar
The motor that I used in my frankenquad project has been sitting unused in its prior frame since the end of last summer. I got it into its new frame, wired up, and running, but my clutch is stuck engaged. The clutch cable is way too easy to pull, and it is currently adjusted for its full range. Its not disengaging at all. I know this is most likely caused by it sitting for so long, missing a quart of oil for part of it. I've already tried rocking it, and I've tried riding it briefly, with no success in freeing the clutch. I've only taken it in 1st and 2nd gear, and only on soft gravel.
Does anybody have some advice? I know I can just pry the clutch plates apart, but I'd rather do it the fast/easy way. I may try running it down the road and getting on the gas, brake, and clutch simultaneously, or just goosing the gas a lot going up a paved hill with the clutch held.
If anybody has some words of wisdom or warning, I'd appreciate it.
1988 motor/2001 frame, 353cc wiseco 10.25cr piston, k&n filter, white bros e-series, rear skid plate, soon to have custom hood to accommodate front mount computer + lights
1996 warrior, stock, utility rack
wontacceptthis is offline
post #2 of 3 Old 05-18-2012, 02:24 PM
push start it with another quad that you are tied to, once it starts have the rear quad slow down to a stop and giver her hell!!
post #3 of 3 Old 05-20-2012, 08:53 AM Thread Starter
Sounds dangerous but fun. I may try that, or something similar.
Dp clutch install help, spring plate on stock clutch? zekemz3 Yamaha YFM660R Raptor (2001-2005) 4 09-02-2010 04:20 PM
Clutch change, clutch won't disengage Towlieee Yamaha YFM660R Raptor (2001-2005) 4 05-18-2007 07:46 AM
Trick to removing clutch cable from stock clutch lever? Dan660R Yamaha YFM660R Raptor (2001-2005) 2 01-15-2007 03:00 PM
Raptor Problem. Pull in clutch axle spins...let go of clutch banshee17b Yamaha YFM660R Raptor (2001-2005) 24 11-12-2004 06:24 PM
clutch slipping w/ hydro clutch.... thornestar Yamaha YFM660R Raptor (2001-2005) 24 06-05-2003 11:34 PM
