Warrior brake light add on?
This is a discussion on Warrior brake light add on? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I have a 2000 Warrior, would it be possible to add the brake light switch from a 02-04 and change the rear tail light + ...
Old 02-22-2012, 12:16 PM   #1
95camaro95's Avatar
View 95camaro95's Photo Gallery(0)
Default Warrior brake light add on?
I have a 2000 Warrior, would it be possible to add the brake light switch from a 02-04 and change the rear tail light + run all wires to make my rear tail light have a brake light too. Around my town your "supposed" to have a brake light to ride on the streets so I'd kinda like to be able to do that w/o the trouble of cops. Or if someone knows another way to do it.
95camaro95 is offline   Reply With Quote
Old 02-22-2012, 01:12 PM   #2
View diggerzmound's Photo Gallery(5) Send a message via AIM to diggerzmound Send a message via Yahoo to diggerzmound
With a little fabrication you should easily be able to make that work. You will have to find a different tail-light or figure out a way to put a dual filament bulb socket in the warrior light. Then find your self a stop brake switch from a street bike. Wire the switch to control the power to the stop filament on the new socket. Find yourself a switched power source so you don't have dead battery problems. It will probably take some welding for the switch tab and a small loop to pull the switch on the rear brake pedal.
If you want to have brake lights with your front brake you would have to find a compatible master cylinder with brake switch.
diggerzmound is online now   Reply With Quote
Old 02-22-2012, 02:41 PM   #3
geeessfore's Avatar
View geeessfore's Photo Gallery(0)
Most people find using a raptor front master with brake switch is easiest. You can also use a universal switch and mount it to the rear pedal assembly.
YFM350.com for all your Warrior Needs
geeessfore is offline   Reply With Quote
Old 02-23-2012, 12:54 PM   #4
95camaro95's Avatar
The rear one I'm not so worried about its more the front brakes I want to have brake lights hooked too, the rear will come later. And I like the raptor master cylinder idea my only concern is the threads inside the master cylinders being different, other than that they both look very similar and would transfer nicely.
Old 02-23-2012, 03:38 PM   #5
taylgabr's Avatar
View taylgabr's Photo Gallery(0)
use a hydraulic switch.. much cheaper and easier. this is what i used, it just replaces your master cylinder's banjo bolt.
Opentip.com: Tusk Hydraulic Brake Switch Nissin Brakes
taylgabr is offline   Reply With Quote
Old 02-23-2012, 08:21 PM   #6
95camaro95's Avatar
Then from there run one wire to the positive source and the other to the brake light? That seems way easier. But doesn't it look funny having wires coming out of the bolt?
edit: Also is that hydraulic switch going to be as reliable as the mechanical one for the front brake lever?
Old 02-24-2012, 11:34 AM   #7
taylgabr's Avatar
yes. No it doesn't look funny at all. does it look wierd to have electrical cables coming off of your clutch? I have had mine on there for three years and it still works great.
Old 02-24-2012, 11:55 AM   #8
95camaro95's Avatar
Good argument. I'll have to give it a shot. Three years for 10 bucks. Seems worth it imo. Thank you very much.
add a brake light to atv
raptor master cylinder on a warrior
change atv tail light to stop light
yamaha warrior brake lights
can i make my 4wheeler tail light a brake light
yamaha warrior brake light wiring
does the taillight on warrior work when braking
add brake light to atv
yamaha warrior brake atv light kit
yamaha raptor brake light switch
yamaha warrior 350 stop light
brake light switch 1997 yamaha warrior
03 yamaha warrior brake light
does a warrior 350 have brake lights
what wiring goes to my tail light on a yamaha warrior
03 warrior 350 brake light wires
yamaha warrior tail light atv
can i put a brake light on my atv
2003 yamaha warrior 350 rear running light
atvhydralicbrake
yfz 450 brake light serento Yamaha YFM350 Raptor/Warrior ('87-Present) 0 01-21-2011 11:08 PM
WTB 04-05 YFZ brake light Kooner69 Wanted 1 04-17-2008 09:56 PM
Do '01's have a brake light? atl03660R Yamaha YFM660R Raptor (2001-2005) 5 04-28-2004 07:53 PM
Tail light/Brake light alternative... TheRaptorKid Yamaha YFZ350 Banshee (1987-Present) 4 01-30-2004 02:54 PM
Brake Light DaIronFist Yamaha YFM350 Raptor/Warrior ('87-Present) 11 05-03-2003 08:21 PM
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
