02-22-2012, 09:40 AM
99 Warrior Top End Help
So I tore apart my top end after hearing a slight knocking, wanted to nip it in the bud before it got bad. Turns out my rod bearings are bad. But how can I get this connecting rod off myself?!? Is it worth even trying?
02-22-2012, 10:14 AM
well everything has to be pulled off, then the case split, crank removed, pin pressed out, new rod and bearing put it, crank trued then put it back together
JE 366, Curtis sparks, ASR, Works, Web .440, Deadlast, Blingstar, GYT-R
02-22-2012, 01:18 PM
You have to have a press and a jig to change the rod bearings. You are better off buying an aftermarket crank if you want to do the work yourself. HotRods makes a drop in stock replacement.
02-22-2012, 08:58 PM
So yall are sayin I should probably try and get my money back out of this thing before the knockin gets noticeably loud.
02-22-2012, 09:32 PM
No if your gonna sell it sell it as a warrior with a bad rod bearing
02-27-2012, 10:35 PM
Think I'm gonna just get a hot rods stroker crank for it. I read that if I do I also need the hotrods piston. Is this true? If so, why? Thanks for the help
02-28-2012, 09:01 AM
yes thats a good kit and the pin is in a different spot on the piston
02-29-2012, 10:14 PM
Alright appreciate the help.
help putting crank shaft in a yamaha warrior, super atv, 99 warrior top end, yamaha warrior shuts off once hot, 350 warrio knocking/, how to remove connecting rod from a 350 raptor, 2000 yamaha warrior top end knocks, yamaha warrior 350 symptoms of a bad rod
