No spark problem/solution?
This is a discussion on No spark problem/solution? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; OKay ive read that if your fuse is blown or by passed it possibly wont spark cause that, well i'd loveeeeee to know where this ...
Old 02-22-2012, 02:23 AM   #1
View Leeland94's Photo Gallery(0)
cry No spark problem/solution?
OKay ive read that if your fuse is blown or by passed it possibly wont spark cause that, well i'd loveeeeee to know where this fuse is located, cause if its where i think it might be, the people before quick fixed it by by-passing it by crimping the wire together and ripping the rubber hold off so if you can pleaseeeeeee take a pic and show me. much thanks to who ever helpss.. so depressed :(
Leeland94 is offline   Reply With Quote
Old 02-23-2012, 11:33 AM   #2
View dodgewarrior's Photo Gallery(0)
I'd be careful with that the fuse is there as a safety if incase a wire shorts and sends current through the system. Potential hazard is a fried Cdi I just replaced mine. The guy I bought it from had done this and my Cdi was no good If I where you I'd try and find another Cdi and cross check that but your fuse should be located off the battery inline on a power wire also test your stator I forget but you should get 300+ ohms
dodgewarrior is offline   Reply With Quote
Old 02-23-2012, 05:05 PM   #3
The thing is im not good with electric so i dont know what wires to test and ya i just put an inline fuse back in it cause they took it out.
Old 02-23-2012, 05:53 PM   #4
I'm not sure of the colour of the wires but you have two plugs coming off the stator a three prong and four prong, when you test it with your multimeter you wanna cross top left to bottom right so to speak on one side you should have 300+ ohms on the other side should be 500 ohms... Don't really remember which is the pick up coil. You can also check and see if your getting power to the ignition coil with the multi by checking the orange wire for power if you got power there then it's your coil. If not then its prolly the Cdi, if your stator test out... Sorry it's kinda all over the place I've been learning as I go I had a no spark issue as well and electrical is not my best area
Old 02-23-2012, 09:44 PM   #5
Thanks for breaking it down for me. Uhm i tried the ignition thing like you previously stated a day ago and nothing checked out so i was thinking that its the cdi... but thing is where do i find a new one for cheap :(
(why dos electrical be a pain in the a** and nothing but money)
Old 02-24-2012, 12:16 AM   #6
I got a coil CDI and stator for under 300 (CDN) shipped to my door from RM stator
Old 02-24-2012, 01:57 PM   #7
ya i checked the stator it came out to be around 150 for both each time i tried it and the triangular plug came out 1.5 on every one. so i believe its the stator . and RMSTATOR has a whole kit for 139.00 which ill get if it is.
Old 02-24-2012, 03:40 PM   #8
That's the one I got lol be careful with the plugs mine where loose and came out on the female side but it fixed my problem once I got the wires straightened out lol on a side note they don't colour match their wires to factory
Old 02-25-2012, 01:16 PM   #9
So do they match up like the should though??? thats dumb
Old 03-01-2012, 02:32 PM   #10
No they didn't i had to call rm
yamaha banshee no spark
atv no spark problem
no spark on a yamaha banshee
no spark on yamaha banshee
common problems with yamaha banshee 350cc
no spark atv forum
how to fix yamaha banshee when it isnt getting a spark
yamaha banshee spark troubleshooting
what would cause no spark on atv
inline fuse 01 warrior?
atv spark problems
how to test a banshee stator
poosible causes of no spark on yamaha grizzly
atv no spark things to test
no spark troubleshooting fj cruiser
03 banshee no spark
02 warrior 350 no spark problem.
what causes a yamaha banshee to have no spark
what is a common problem when an atv doesnt have spark
Warrior spark problem? Warriorrider 86 Yamaha YFM350 Raptor/Warrior ('87-Present) 0 03-16-2008 03:19 PM
spark problem Y2JRaptor Yamaha YFZ450/450R (2004-Present) 7 09-14-2005 12:39 PM
Big Problem, no spark sometimes, help! Inmonodus Yamaha YFM350 Raptor/Warrior ('87-Present) 2 03-29-2005 02:38 PM
no spark problem davesgarage02 Yamaha YFM350 Raptor/Warrior ('87-Present) 15 12-23-2004 04:35 PM
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
