87 Warrior won't start on button but will push start - Yamaha ATV Forum
This is a discussion on 87 Warrior won't start on button but will push start within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; My 87 Yamaha Warrior originally thought it wouldn't run at all, after a few tests and a push test it runs, and it runs just ...
Old 02-02-2012, 04:56 AM   #1
95camaro95's Avatar
View 95camaro95's Photo Gallery(0)
Default 87 Warrior won't start on button but will push start
My 87 Yamaha Warrior originally thought it wouldn't run at all, after a few tests and a push test it runs, and it runs just great. However I can't get it to start by using the push button, only by push/pull starting it? Anyone have any idea what it could be? I can post a vid if it helps anyone. One way clutch (starter clutch) or something else?
95camaro95 is offline   Reply With Quote
Old 02-02-2012, 08:55 AM   #2
View camper4lyfe's Photo Gallery(0)
Does it to ANYTHING when you hit the starter button?
camper4lyfe is offline   Reply With Quote
Old 02-02-2012, 01:30 PM   #3
95camaro95's Avatar
Yes, starter is working spinning trying to start it.
Old 02-02-2012, 09:19 PM   #4
carsonmx114's Avatar
View carsonmx114's Photo Gallery(0)
One way bearing behind the flywheel. You'll need the replace the gear as well that the bearing locks onto. If I remember right the last one I fixed was around $500 parts and labor. I tried to talk the customer out of fixing it because the unit was rough. And now it's sitting in my warehouse about a year later...with $300 worth of new parts in it.
carsonmx114 is offline   Reply With Quote
Old 02-03-2012, 04:18 AM   #5
95camaro95's Avatar
Not starter clutch, thats what your talking about. Crankshaft spins, piston moves, already ruled that one out.
Old 02-03-2012, 09:20 AM   #6
Most likely low compression then. I thought you meant the starter was turning but the engine was not. How is your air filter? Check your intake valve clearance. If it runs good once you pull it off, meaning it doesn't smoke, you probably have tight intake valves. Take the tappet cover off, turn the engine through until the intake valve opens and closes, the next time the piston is at TDC you should have .003 valve clearance +/- .001. If you don't have clearance the valve is held open and the fuel/compression is blown back out of the carb disrupting everything that needs to happen for the engine to run. When you pull it off the engine turns fast enough to overcome this, then once the engine is hot the valve head expands enough to create a small amount of clearance. hope this helps you.
Old 02-03-2012, 04:36 PM   #7
95camaro95's Avatar
Air filter is decent, smell a bit of fuel on it but not huge amount but is clean. No it does not smoke.l Thanks for the info! Now thats an arguable point. I'll regap valves tonight and let you know how it goes. Maybe I goofed last time I gapped them. My guide says .06 - .10 for intake valve clearance though. It still does it when the engine is warm but still a good possibility. Now what if the valve has clearance, whats your next best bet?
Old 02-04-2012, 10:06 AM   #8
You could have an issue with voltage in the ignition system. I've seen situations where the electrical system will supply enough voltage to either spin the motor or produce a spark but not both at the same time. I would use a spark tester or a timing light if you have one and make sure the unit is firing when you're turning it over with the starter. Your settings are correct on the valve clearance. I quoted standard numbers, your numbers are metric, same clearance. Let me know what you find.
Old 02-08-2012, 01:43 AM   #9
95camaro95's Avatar
Decided to check intake valve clearance, my friends brother suggested it too. Turns out the valve was fully tightened. Durr moment. Haven't been able to try it yet as to when I tried to start the starter shelled out. But its definitely looking like it would be fixed now. I'll update when the new starter comes in.
Old 02-08-2012, 09:18 AM   #10
That's good news! I don't know if you have a service manual or not but in case you don't a good trick is to remove the tappet cover, turn the motor the direction it normally turns with a socket on the crankshaft (if you turn it the wrong way you'll hear the one way bearing turning the starter), watch the intake valve until it goes down (opens) and then back up. Now turn the crank until the piston comes to TDC. this will be TDC on the compression stroke and this is where you have to have it to set valve clearance.
Old 10-24-2012, 01:07 PM   #11
pmenag's Avatar
View pmenag's Photo Gallery(1)
Is that an expensive fix? I have the same issue I can't get it to start by using the push button, only by push/pull starting it
pmenag is offline   Reply With Quote
yamaha warrior wont start
my yamaha warrior wont start
350 warrior wont start with start button#gsc.tab
warrior 350 push starts but wont start with button
yamaha warrior 350 wont start with push button
how to push start yamaha warrior
03 warrior 350 has to be pull started
how do i push start a yamaha warrior
my 350 warrior only push start
why wont my yamaha warrior start
yamaha warrior will only pust start
yamaha warrior engine will not crank
Raptor won't start from push button racingstangger Yamaha YFM660R Raptor (2001-2005) 36 05-09-2013 10:36 AM
Warrior won't start when I push in button shipdadip Yamaha YFM350 Raptor/Warrior ('87-Present) 16 10-25-2012 03:45 PM
NO PUSH BUTTON START sharpie469834 Yamaha YFM350 Raptor/Warrior ('87-Present) 10 05-25-2012 12:27 AM
Warrior will not start with push button HELP? davefan1516 Yamaha YFM350 Raptor/Warrior ('87-Present) 9 03-26-2011 10:31 PM
start button on warrior Cencalwarrior350 Yamaha YFM350 Raptor/Warrior ('87-Present) 3 12-19-2010 03:57 PM
