No Power To Coil - Yamaha ATV Forum
No Power To Coil
This is a discussion on No Power To Coil within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; 01 Warrior. Have replaced the pick up coil and the source coil. I ohmed the originals and they were way out of spec. Still not ...
Old 06-01-2011, 10:08 PM   #1
View 90notch306's Photo Gallery(0)
Default No Power To Coil
01 Warrior. Have replaced the pick up coil and the source coil. I ohmed the originals and they were way out of spec. Still not getting power to the coil. Tried different regulator rectifier and a different cdi box. The wire is not broken. Have cleaned all connections and grounds. Battery is fully charged. What tells the cdi box to send a signal to the coil to spark. What am i missing?
90notch306 is offline   Reply With Quote
Old 06-02-2011, 09:26 AM   #2
The CDI is a complicated mystery, there is no testing the damn thing and its a mystery to most what its doing and how. How was the trigger coil? The trigger coil works with the CDI to time the spark. DId you ohm the ignition coil? You cannot really test for power to the coil, it either sparks or it doesn't. Check your plug boot and make sure you have a new spark plug in it.
Old 06-02-2011, 09:48 PM   #3
Which one is the trigger coil? I replaced the pick up and source coil. They are from RMStator. Ive tried a test light and a multi meter on the orange wire and i get nothing at all. Ive replaced the entire ignition coil also. Will try a new plug but the plug in it was good not too long ago. How exactly do you ohm the ignition coil?
Old 06-03-2011, 10:02 AM   #4
The manual will tell you which wires are for the trigger coil. As for coil testing again refer to the manual.
WARRIOR TECH Thread :: Links To Important Topics
Old 06-20-2011, 09:54 AM   #5
Finally got around to trouble shooting the ignition system. Switches, pick up coil, source coil are all in spec. Ignition coil had some different readings then what the manual specs so I swapped the coil from my raptor and still had no spark. I've cleaned all the grounds I could find and all connectors. The only thing left is the cdi box. I swapped it with another one that I had but still no spark. Possible both are bad? Any other ideas before I order an ignition coil and cdi from RMstator?
Old 06-24-2011, 01:03 PM   #6
Any opinions?
Old 09-24-2011, 11:03 AM   #7
Ok I am still fighting this problem. I've replaced pick up coil, source coil, cdi box, and ignition coil with all new parts from rmstator. The plug is good. The switch for the run is good. The cdi is getting power and I believe it is getting a signal from the pick up coil cuz when I put my power probe on the wire and crank it it pulses a ground signal. I sent power to the coil numerous times and only saw one faint spark. What the Hell am I missing? I've checked and cleaned all connectors and grounds. Does anyone know the actually functions of the ignition system? Like what does whY and when kind of thing? Or if anyone is around the waterford Michigan area that has a 97-01 warrior that I.could test parts on would be great.
Old 09-27-2011, 09:17 PM   #8
View mohiggy101's Photo Gallery(0)
Sorry no advice to help your problem but maybe you will have some for me. I am waiting for my pickup coil to get here and still cannot find anything on how or where to change it out. Could you elaborate on this for me?
mohiggy101 is offline   Reply With Quote
Old 09-28-2011, 07:42 PM   #9
The pick up coil will be in your left side engine case. It's the one that's not attached to the stator. Be very careful with the screws the hold it in there. They strip very easy. And I finally found my problem to the no spark issue. I mounted the pickup cool upside down. Now I have it backfiring through the carbon like timing is off
Old 09-29-2011, 10:39 PM   #10
Ok finally got this Damn thing fixed. Switched the pickup coil wires around and fired right up. It runs great!!
yamaha warrior ignition coil test
yamaha warrior no power
yamaha warrior no power to coil
what are the colors of the wires going to the cdi pickup coil on a 2000 yamaha wolverine
yamaha bear tracker not getting spark
what will make a 2005 yamaha bruin 350 not get fire
how to test a cdi 2000 grizzly 600
what does it mean if there is no juice going to the coil on a warrior 350
how to test the coil on a 2004 bruin
05 raptor 350 no power at coil
no power coming out cdi box on atv
what powers a coil pack on a atv
coil dirtrider596979 Yamaha YFM350 Raptor/Warrior ('87-Present) 0 12-22-2007 12:26 AM
Coil Warrior King Yamaha YFM350 Raptor/Warrior ('87-Present) 5 01-02-2005 04:14 PM
Where's coil johnnymaddog Yamaha YFZ450/450R (2004-Present) 5 08-01-2004 05:31 PM
coil help GETBENTFREERIDERS Yamaha YFZ350 Banshee (1987-Present) 2 08-05-2003 05:44 PM
Coil kingraptor Yamaha YFM660R Raptor (2001-2005) 2 06-06-2003 09:44 AM
