350 warrior idles great but backfire when throttling up - Yamaha ATV Forum
This is a discussion on 350 warrior idles great but backfire when throttling up within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; Ok all about ready to use a stick of dynomite on this thing. I have a98 350 warrior and started with no spark and now ...
Old 05-27-2011, 11:39 PM   #1
View bfm20012003's Photo Gallery(0)
Default 350 warrior idles great but backfire when throttling up
I have a98 350 warrior and started with no spark and now have it to running well at idle but as soon as i try to throttle it spit and backfires in muffler. new jets and clean carb7 times timing and valves adjust. was suggested that could be parking brake from dealer and discounted the switch and it still does it then was told it could be the revlimanator discounted it and still having themsame issue.
PLEASE NEED ALL HELP.
bfm20012003 is offline   Reply With Quote
Old 05-28-2011, 07:41 AM   #2
1998yamahawarrior's Avatar
View 1998yamahawarrior's Photo Gallery(3)
Do you have a manual and a multimeter to ohm the coil with? Do you know anyone with a 97-01 so you can swap cdi's to rule that out.? Have you gone over the harness to make sure there are no breaks or shorts in it? Just a few thing that I can think of off the top of my head this early in the morning.
1999 Warrior Lonestar +2 a arms, swinger, Durablue +2+4, Renthal bars,sprockets, ITP beadlocks, Trail Tech lights, DG skids, nerfs, bumper, PRM wide grab, Spider grips, CFM airbox, Uni, clutch cover cooler, Big Gun exhaust, Works Black Widow fronts
1998yamahawarrior is offline   Reply With Quote
Old 05-28-2011, 11:51 AM   #3
Yes have put coil on another running quad and it works fine bought new cdi box and now have 3 of them have gone through wiring harness and all that is good
Old 06-05-2011, 12:26 AM   #4
View 06duramax's Photo Gallery(0)
have u checked for any cracks it the intake boot between carb and motor, also check for exhaust leak right at the motor, and also how does the quad run with the choke on or half way on any change, fuel line in good shape and not clogged, if all is good recheck the timing and valves if thats still good, you may have a valve sticking or even bent valve i got a honda that was doing that and went threw that thing a 1000 times and pulled the head off and exhaust valve was bent and not seating right, but i aint a mechanic so dont trust my word on any thing just suggestions
06duramax is offline   Reply With Quote
yamaha wolverine 350 backfiring when give gas
atv backfires when i give it throttle
if you clein carb of 350 warrior and still backfire what to do
yamaha wolverine 350 backfires
yamaha 350 atv pops and backfires when giving gas at half throttle
warrior 350 backfire
1998 yamaha warrior 350 backfires
dr350 popping
yamaha warrior 350 high rev backfire
what causes 2000 yamaha warrior 350 to rev when gas
98 yamaha big bear idels with choke on
yamaha warrior 350 popping while revving up
warrior idles then dies as soon as you give it throttle yamahablaster8230 Yamaha YFM350 Raptor/Warrior ('87-Present) 16 05-30-2015 03:15 AM
99 Warrior starts, idles, then dies madfish Yamaha YFM350 Raptor/Warrior ('87-Present) 26 05-24-2013 08:57 PM
2002 Kodiak 400 Idles Great - Dies/Bogs with any throttle Roy Yates Other Models/Brands 3 04-06-2011 09:34 PM
warrior idles but thats it need suggestions wildboy Yamaha YFM350 Raptor/Warrior ('87-Present) 15 09-12-2010 12:28 AM
Idles slow ,Idles fast, Just right ? Big Windy Yamaha YFM660R Raptor (2001-2005) 2 03-16-2004 10:56 PM
