No Spark but will bump start - Yamaha ATV Forum
This is a discussion on No Spark but will bump start within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; as title says i got an 04 war needed a motor. i put an 01 lower end with a .20 over top end. the bike ...
Old 04-08-2011, 06:25 AM   #1
View thatperson's Photo Gallery(0)
Default No Spark but will bump start
as title says i got an 04 war needed a motor. i put an 01 lower end with a .20 over top end. the bike has no spark when u try to start with button. but if you pop it she runs fine. and thing any1 can think. grnd wire maybe? starter clutch? how many grounds does the bike have? any info would be great would like to get it running under its own power today ty.
thatperson is offline   Reply With Quote
Old 04-08-2011, 06:54 AM   #2
View jgray44's Photo Gallery(0)
i think there is 4 grounds to the bike, dont konw where all four are though! just go through your wires and find all the grounds, take them off and clean them. test your stator and see what it ohms out at
jgray44 is offline   Reply With Quote
Old 04-08-2011, 08:22 AM   #3
1998yamahawarrior's Avatar
View 1998yamahawarrior's Photo Gallery(3)
only being able to pop start it is usually a sign that the pickup coil is out of the stator. If your trying to fix it on the cheap you can just replace that, but I recommend just replacing the whole stator.
1999 Warrior Lonestar +2 a arms, swinger, Durablue +2+4, Renthal bars,sprockets, ITP beadlocks, Trail Tech lights, DG skids, nerfs, bumper, PRM wide grab, Spider grips, CFM airbox, Uni, clutch cover cooler, Big Gun exhaust, Works Black Widow fronts
1998yamahawarrior is offline   Reply With Quote
Old 04-08-2011, 12:19 PM   #4
7 grounds total, test your stator like 98 said. If it's good then start clean grounnds and checking wires
Old 04-08-2011, 09:52 PM   #5
View thriller's Photo Gallery(0)
so does anyone know where all the grounds are?
thriller is offline   Reply With Quote
Old 04-08-2011, 10:06 PM   #6
two grounds off the - battery with one of them going to the frame. one for the starter, one for the lever switch, one that comes off the cdi,one for the neutral switch, one for the reverse switch
Old 04-09-2011, 06:38 PM   #7
ok found the spark issue (i think) my coil had a big crack in it (so i borrowed my friends from his 01). but still wouldnt start. so i took the stator cover and stator out to find it all oil soaked. is that normal? i cleaned it all out and dried it up and the bike tryed to start but still no start. took it up the hill and it popstarted. it dosnt get a constant spark either like 5sec after u hit switch it stops, and then sparks again just as u let off the button.
Old 04-09-2011, 07:02 PM   #8
Yes it is supposed to be oil soaked.
Old 04-10-2011, 06:17 PM   #9
At this point you really need to test the stator. How you say it will start pretty much any time you bump start it, thats almost a perfect indication that the pick up coil is shot on the stator.
Old 08-15-2011, 02:35 PM   #10
View atvredefined's Photo Gallery(0)
i have the same problem with an 01 except when its hot itl fire with the starter if its cold no spark unless bump started. idk if that happens to you or anyone?
atvredefined is offline   Reply With Quote
Old 08-15-2011, 02:36 PM   #11
or happened. didnt realize how old this was.
Old 09-11-2011, 08:14 PM   #12
sry no reply in awhile been working got it figured out. the guy i bought lower end from lied said it was an 01. musta been first gen cause flywheel pick up spot was wayyyyy smaller than the 04 pick up spot. runs great now minus an accel pump issue wich imma change the spring.
Old 10-18-2011, 10:07 AM   #13
View STR8OUT's Photo Gallery(0)
Sorry to bring up and old thread but I am having the exact same issue with my bike.
I just swapped in a new starter clutch / flywheel already assembled and now my bike wont start. It wont spark when pressing the push button but if I put the rear wheels in the air and put the bike in second gear and spin the wheels by hand (push starting essentially) it will spark. I notice when I spin the rear wheels by hand, the crank spins faster than when the starter spins the motor. It shouldn't affect the sparking though.
STR8OUT is offline   Reply With Quote
Old 10-21-2011, 11:53 AM   #14
all i can say is check to make sure the pick-up spots on the flywheels are the same size and in same spot. the problem i had was the 1st gen has 2 little pick-ups on flywheel as my 04 has a very long 1.
engine will not get spark unless you bump start it
1999 yamaha warrior 350 no spark
can you roll start an atv with a bad stator
if my warrior haves no spark will it still run
raptor 660 will only bump start
raptor 660 wont start but will pull start
warrior will bump start but wont start with starter
how to pop start a raptor 660
can you bump start motorcycle with bad stator
warrior 350 bump start gear
1998 yanaha warrior will start on a pop start but will not turn at all using the push button
yamaha warrior 350 no pull start
93 kodiak pull=spark, elect. start= no spark Help kbs@color-country.net Other Models/Brands 0 11-30-2010 03:00 PM
98 350 Wolverine won't start. No spark. Help! TyrantFuryre Yamaha Wolverine 350 / 450 7 11-29-2010 06:29 PM
Air+fuel+spark= no start. HELP. ChewyR Yamaha YFM350 Raptor/Warrior ('87-Present) 6 05-08-2010 06:53 PM
Bump Start FMF FRE┼K Yamaha YFM660R Raptor (2001-2005) 7 10-13-2004 11:43 PM
