1997 yamaha warrior 350 will not turn over at all
This is a discussion on 1997 yamaha warrior 350 will not turn over at all within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; OK..so here is the deal..when I was riding out in the woods...everything was running fine..all the sudden it bogged down like I had lost all ...
Old 04-06-2011, 09:02 PM   #1
View firemedic373's Photo Gallery(0)
Default 1997 yamaha warrior 350 will not turn over at all
OK..so here is the deal..when I was riding out in the woods...everything was running fine..all the sudden it bogged down like I had lost all power and died...after repeated attempts to restart the bike...absolutely nothing..the only sound it made was the starter spinning...no muffler noise or even a puff of life
so I was towed back to the house..and have literally been over every inch of this bike..here is the things that I have checked:
-spark plug replaced- good blue spark when grounded to motor
-spark plug cap (tested at 0 ohm..replaced with brand new one)
-every wire gone over and checked and dielectric applied after cleaning
-brand new battery fully charged
-crankcase taken off and flywheel, idler gear..etc checked visually...no obvious signs of damage or metal shavings in the oil or case)
-stator tested (276 and 506 ohm)
-starter relay bypassed and still nothing
-ignition coil primary and secondary tested within limits per manual
-starter spins fast..no clunking or other sounds
-valves-intake/exhaust were both gapped at the proper specs in the manual
I have run out of ideas..if anyone out there has had a similar experience or has any ideas about possible causes...please..any advice would be great
thanks in advance
firemedic373 is offline   Reply With Quote
Old 04-06-2011, 09:29 PM   #2
View jgray44's Photo Gallery(0)
do you have any compression?
jgray44 is offline   Reply With Quote
Old 04-07-2011, 07:44 AM   #3
View camper4lyfe's Photo Gallery(0)
So it does turn over, as you can test for spark. The engine itself is free to turn, correct? It just doesn't attempt to fire.
Have you checked your carb? Seems you're looking for something in the engine, but may have gotten a bit of crud in your carb and it's plugged up.
camper4lyfe is offline   Reply With Quote
Old 04-07-2011, 11:54 AM   #4
will it bump start?
Old 04-07-2011, 05:28 PM   #5
it will not bump start..tried that when it first happened when i was being towed
compression checks out fine per manual specs
correct it does not seem to want to fire..starter button works every time..the engine does turn freely without any rough or metal noises..the carb is certainly worth a second look..but I didn't find anything wrong the first time I went through it...but at this point I am at a loss and I am willing to try anything
ill give the carb another going over this weekend...but other then that I am truly confused...I don't want to give up..but it may be time for an expensive trip to the shop
thanks for all the advice..if anyone can think of anything else..please dont hesitate to offer your opinion
Old 04-07-2011, 05:49 PM   #6
hit it with some starting fluild in the plug hole, if it's not getting gas it should fire up for a sec.
Old 04-07-2011, 07:52 PM   #7
well..the carb was cleaned better then a babies ass...I even gave this wench a full tank of super unleaded and still absolutely no change
I am seriously starting to think it is the starter clutch..I know warriors have a horrible history with them going out all the time
but does a bad starter clutch actually make a 4 wheeler just all the sudden lose all power and shut down?or could it more likely be a cdi?
either way probably just gonna take the cdi to the shop and have them test it for me to verify that it is good or bad...other then that the beer is no longer working and my frustration is about to boil over and she is about to take a trip over a cliff
thanks again for the advice..never hurts to double check anything
Old 04-07-2011, 08:00 PM   #8
Have you checked your fuel line? Maybe the petcock got plugged with something? What you've said just doesn't add up. You've got spark and compression. The next step is fuel. Try some starting fluid in the plug hole and see if it'll try to fire. If it does, you've definitely got a fuel delivery problem.
Old 04-07-2011, 08:21 PM   #9
I checked and blew the lines out...if it was a fuel problem then I wouldn't think that the carb bowel would have fuel in it if it was a fuel issue...am I wrong?
either way Ill check and post my results
Old 04-07-2011, 08:22 PM   #10
Never hurts to double check.
Old 04-07-2011, 08:39 PM   #11
so..I went out and checked the petcock..other then a couple specks...clean as a whistle
I am honestly not thinking this is a fuel issue...it just didn't act like a fuel problem when it literally just acted like either a dead battery or an electrical failure
the bad thing is the kid who owned this bike before me..has more spliced wires on this bike then I have ever seen...but they all seem to be testing good on the open end
I have no idea..is this bike even worth running all new wires? I know its gonna be a personal opinion..but cash wise...is it going to be worth it?
anybody wanna trade a wave runner for it..lol..I love toys but this is b.s...with a capital B
Old 04-07-2011, 08:50 PM   #12
If it was the starter clutch, it would bump start. you can pick up a good wiring harness on ebay if you think that's the problem. I am pretty sure to test the cdi you have to test every other electrical conponite 1st then its when that's all that is left replace it. Here is a link to a pdf manual start on page 290 it will walk you through testing all elecrical. An easier way is if you know someone with a warrior swap cdi to see if that is what is wrong. 1997-2001 have the same cdi http://dl.dropbox.com/u/2919391/warrior.pdf
Old 04-08-2011, 10:41 AM   #13
unfortunately I don't know of anyone around here who has another warrior in that year range
I found a new wire harness assembly from cheapcyleparts.com for $160..seems pretty reasonable price compared to other online shops
even if it doesn't turn out to be a wiring problem at least I will have good power all over the bike and not have to worry about that "mystery wire" that always seems to spring up when you are on the trails running hard
thanks so much everybody for all the great advice..if anyone can think of anything else I could check..please don't hesitate to drop a line and give your opinion
Old 04-08-2011, 03:24 PM   #14
$nowman's Avatar
View $nowman's Photo Gallery(0)
I had a similiar problem with mine where i thought it was the CDI or the carb, i Pulled the cdi out cleaned the connections inspected for any cracks or damage, took it in the house out of the cold for a couple days plugged it in and hooked up a tm36 pumper carb and low and behold it puffed back to life after 5 months and 2 mechanics later... if you have access to another carb try it.
$nowman is offline   Reply With Quote
yamaha warrior wont turn over
yamaha warrior 350 will not start
350 warrior wont turn over
yamaha warrior won't turn over
2001 warrior starter runs but does not turn motor over
yamaha 350 raptor will not turn over
raptor 350 will not turn over
97 350 warrior will not start
89 yahmaha warrior turns over but wont startwith electric starter
warrior atv will not turn over
what would cause a yamaha warrior not to have any power to start
1997 Yamaha Warrior Base Gasket Twinkies1 Yamaha YFM350 Raptor/Warrior ('87-Present) 5 08-30-2009 09:36 PM
1997 yamaha warrior 350 spark plug gap ???? 350rider09 Yamaha YFM350 Raptor/Warrior ('87-Present) 2 06-30-2009 02:22 PM
1997 yamaha warrior electric start reverse quad228 ATVs for Sale 1 04-28-2008 10:56 AM
Recall:Yamaha warrior 1997-1998 Bluetraxx_member Yamaha YFM660R Raptor (2001-2005) 2 07-24-2002 10:14 PM
