Yamaha Warrior Won't Start
This is a discussion on Yamaha Warrior Won't Start within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; So basically, I bought a 1999 Yamaha Warrior for $700 the other day and I was told it has a "bad ground." Well so far ...
Old 02-23-2011, 08:30 AM   #1
View raptorrider424's Photo Gallery(0)
Default Yamaha Warrior Won't Start
So basically, I bought a 1999 Yamaha Warrior for $700 the other day and I was told it has a "bad ground." Well so far I have cleaned her up a lot and I went out and got a new battery, spark plug and cleaned up the wires a bit. So yesterday, I charged the battery and put it in, but when I go to start, it makes a clicking noise. I'm guessing it's the solenoid. Please help me out here!
1999 Yamaha Warrior 350: FMF MegaMax 2 Slip On, ProTaper Handlebars, Renthal Grips, DG Bumper.
raptorrider424 is offline   Reply With Quote
Old 02-23-2011, 11:06 AM   #2
take the seat off and on the rear left side fender is the soleniod. the positive battery wire goes to it. take a screwdriver and jump the 2 post on it with the key on and switch in the run position. If it starts I would change the soleniod. also while your by the soleniod there is a fuse down there, you should check that and make sure it's good.
Old 02-23-2011, 08:41 PM   #3
I got it to push start with no battery hooked up, but when I put it on, it just clicks. What happens if it doesn't start by doing the screwdriver thing?
Old 02-23-2011, 09:50 PM   #4
then test your starter by running a hot wire directly to it, (jumper cable works good) if that doesn't work starter is most likely bad.
Old 02-24-2011, 08:18 AM   #5
Yeah thanks I'll try that, I'm thinking the starter has oil or mud in it.
Old 02-25-2011, 08:08 AM   #6
Well I'm sending the quad to a buddy of mine to get it checked out, anyway, when I have it running, the choke is pulled out and it causes a lot of smoke. When I push it in, the engine stalls. What do you suggest this is?
Old 02-25-2011, 09:12 AM   #7
View ziemer's Photo Gallery(0)
Rebuild the carb. If it was sitting for any amount of time, the carb is probably gummed up. This ethanol bs is a bitch for carbureted motors, especially small ones.
ziemer is offline   Reply With Quote
Old 02-25-2011, 02:39 PM   #8
Thanks, I'm going to guess that's what it is because the guy I got it off of had it sitting for 3 years because he joined the Air Force, so he had no time for anything.
Old 02-25-2011, 10:19 PM   #9
View flridda's Photo Gallery(0)
i bought a 93 warrior 350 it ran good for a while and the first day i took it out on the trails and opened it up it went fine till top of 5th gear into 6th then shut down now it wont start it turns over ,,, i replaced the starter and batt and the relays cleaned carbs dunno plz help
flridda is offline   Reply With Quote
Old 02-26-2011, 08:59 AM   #10
View gy67's Photo Gallery(0)
flridda.....Do you have spark? If you're not sure check for that first if not then it sounds like to me you have the same problem I just got done fixing on my 2000 Warrior. Your gonna need a multimeter to ohm out the leads coming from the stator. Take off the rear plastic and clip a couple zip straps to make it easier. There will be a bundle of wires under the left side of the plastic. One plastic plug I believe has 3 white wires coming & going out of, don't worry about those. The other two plugs have 2 wires coming in and going out. I don't remember the color combo but they are the only ones with 2 wires going in and out so it's not hard to figure out. Unplug the wires and ohm out the leads that go back to the stator. If you get zero or open on your meter you have a bad stator and no matter what you do you won't have spark to fire. It's not bad to replace if you are good with tools you'll be fine. If not find someone who is to help you and you'll be fine. I did mine in around 3 hours but would have been done sooner if I would have sprayed the bolts with PB Blaster the night before. There is also a video on youtube that shows how to do it and also gives you the ohm readings you should be getting if the stator is good. It's what made me decide to do it myself instead of calling in favors from my other quad riding buddies.
gy67 is offline   Reply With Quote
Old 02-28-2011, 04:24 PM   #11
Okay so in my case, I can get it started, but if I brake, it stalls and shuts off.
Old 11-26-2012, 09:32 AM   #12
View austin88warrior's Photo Gallery(0)
Alright I just traded my YZ125 that needed a top end for this 88 warrior, def. Needed a starter so bought one of eBay it came with a new solenoid as well put em on hoping it'd fire right up, nope, it just keeps cranking and cranking, checked timing its dead on, haven't adjusted valves yet don't have feeler gauges, has spark, but kinda weak? So got a new spark plug last night so it might work haven't tried? But hoping its something easy and stupid, could the motor not be getting gas? Carb def. Is pulled the gas line to it and there's gas going in? Kinda stumped
austin88warrior is offline   Reply With Quote
Old 11-28-2012, 07:29 AM   #13
View camper4lyfe's Photo Gallery(0)
It's entirely possible that the carb is plugged. Pull it and clean it.
camper4lyfe is offline   Reply With Quote
Old 11-29-2012, 04:36 PM   #14
View Jwhite12's Photo Gallery(0)
On my warrior, I just rebuilt the top end and had the same problem you did raptor rider. I replaced the relay and the starter and it fired right up, my question to all of you is that I had a rip in the carb boot, so it wouldn't start. Then I taped over it just to make it home, and now the hole is bigger and it won't start. I haven't touched anything, so my only guess is that it's the reason, but it struggled to turn over when all the air is coming in, then when I put my hand over the hole, it turned over fine but didnt start. Is it possible it is actually the rip in the carb boot??
Jwhite12 is offline   Reply With Quote
Old 12-21-2012, 06:34 PM   #15
View doerrbd's Photo Gallery(0)
I have a 1990 warrior that turns over by push button but wont start. It will start by poping the clutch. I had the carb rebuilt the timing checked valves checked and all computers tested. Got it stared after that and runs great. It starts when wormed up but not when its cold. Any suggestions?
doerrbd is offline   Reply With Quote
Old 12-21-2012, 06:42 PM   #16
I hope you didn't pay for a shop to check the computers...there aren't any.
Old 12-21-2012, 06:48 PM   #17
Sorry the cdi box silinoids and relays.
Old 12-22-2012, 12:10 PM   #18
joshkenney's Avatar
View joshkenney's Photo Gallery(0)
please help! i got a 1997 yamaha warrior and when i go to start it, it makes a clicking noise. how do i know if its the solenoid or the starter? the odd time it will start up from the electric start but now most of the time it just clicks. please help, i dont know which part to buy :(
joshkenney is offline   Reply With Quote
Old 01-20-2013, 04:02 PM   #19
View VJR021's Photo Gallery(0)
I am having a similar issue... BUT If I remove the starter it will spin.
If it is put back, it just clicks.
Could it be the starter gearing, or you think the engine is locked up?
VJR021 is offline   Reply With Quote
Tags
1999, 350, engine, warrior, yamaha
yamaha warrior wont start
yamaha warrior wont start just clicks
yamaha warrior no start
yamaha warrior won't start
bad crank 350 yamaha warrior you tube
yamaha warrior that will not start
97 350 yamaha warrior wont start
yamaha warrior that wont start
yamaha warrior wont crank
yamaha warrior clicks but wont start
warrior wont start
yamaha atv won't start
Yamaha 450 won't start hammerhead Yamaha YFZ450/450R (2004-Present) 3 09-24-2010 01:09 PM
'89 Yamaha Moto 4 250 won't start... cableguy256 Other Models/Brands 4 05-21-2010 10:31 PM
Yamaha Blaster Wont start any ideas miller6951 Other Models/Brands 4 02-20-2010 05:33 PM
1997 yamaha warrior electric start reverse quad228 ATVs for Sale 1 04-28-2008 10:56 AM
Kick start issue on the honda. heads up for yamaha. Aussiequadrider Yamaha YFZ450/450R (2004-Present) 26 03-09-2004 11:37 PM
