how do i test the orange wire??? - Yamaha ATV Forum
This is a discussion on how do i test the orange wire??? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I have a 96 warrior, it will turn over but it's not getting spark. I tested the coil2plug boot and it was 6.55o so its ...
Old 12-07-2010, 11:36 AM   #1
View firechicken93's Photo Gallery(0)
Default how do i test the orange wire???
I have a 96 warrior, it will turn over but it's not getting spark. I tested the coil2plug boot and it was 6.55o so its good. How do i test the orange wire that connects to the coil? should it have current when I'm trying to start it? maybe a pulsing current? I tested it with a pocket tester and it reads 0.0 ohms all the time??? I tested it both while connected to and when not connected to the coil. oh and the cdi definitely has juice from three of the wires when I push the start button, & stator is good. anyone warrior savvy out there that could give me some advice?
thanks,
-calvin
firechicken93 is offline   Reply With Quote
Old 12-08-2010, 09:21 AM   #2
I think it is tested to ground or to the plug wire.
Test the stator again.
Old 12-09-2010, 09:14 AM   #3
AWK08's Avatar
View AWK08's Photo Gallery(0)
heres some blaster electrical tests, maybe some of it will help you out ??? copy and pasted from another site/thread.........
Your intermittent spark problem is quite likely due to a bad ignition coil. Many times, the high-tension lead (heavy wire that goes from the coil to the spark plug) develops an internal break. Coils can also develop an internal short or open circuit. Either of these faults will result in an intermittent spark at the plug. The coil only fires when the bad connection happens to be made. Which isn't very often, as I'm sure your exhausted right leg can attest.
Do this: Turn the keyed ignition switch (if used) and handlebar switches 'ON'. Unhook the spark plug wire from the plug and remove the spark plug from the engine. Next, find that one-and-only orange wire that attaches to the coil. Unplug it, and go get your 12V test light. (You can buy one for about $ 15.00 at the local auto parts store, or Sears, or....).
Stab the plug on the orange coil wire with the pointed end of your test light. Ground the other end of the test light (with the wire/clamp) out against the engine. Be sure you have a SECURE connection. Now, kick the engine over and watch the test light. The bulb in the test light should blink once for every revolution the engine makes. In other words, the light should flash 'in sync' with the rotations of the crankshaft. This test will tell you whether or not you're getting the required 12 volt 'signal' from the CDI box to the coil every time the piston reaches TDC. If the light blinks steadily, replace your coil. It is defective. The CDI box is sending its 12V pulse to the coil, as it should, but the coil is unable to properly transform it.
Nothing, or an inconsistent blink of the test light, indicates that your ignition coil is not recieving its proper trigger pulse from the other components of the bike's ignition system. Time to pull out the ohm meter and do some resistance checks on the exciter and trigger coils. I'd also test the ignition coil for good measure, just to be sure that it is indeed still good. If these coils test OK (see a Clymer manual for the resistence specs), all connections are clean/tight, and you can't find any bare wires that are accidentally touching the frame, replace your CDI box. It can be ruled faulty if everything else in the ignition system tests good.
you want the best motor work, sevice, and deals around, just click this link......
http://www.kenoconnorracing.com/
AWK08 is offline   Reply With Quote
yamaha blaster cdi test
yamaha blaster ignition coil test
how to check cdi box on a blaster
yamaha badger cdi box
what if the orange wire to the ignition coil on a banshee blinks and beeps instead of a pulse
yamaha blaster cdi box
how to test voltage on blaster
yamaha 2005 blaster ignition test
how to test coil 93 blaster
jianmor cdi orange wire
blaster cdi work on pw80 yamaha
yamaha blaster headlight switch testing
orange pipe daddio Yamaha YFZ450/450R (2004-Present) 6 11-12-2003 04:24 PM
