High RPM idle - Yamaha ATV Forum
High RPM idle
This is a discussion on High RPM idle within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; Hey guys I finally got the beast to run! But the idle RPMs are pretty high. - First thing I tried was the idle screw ...
Old 11-05-2010, 08:34 PM   #1
View david6789's Photo Gallery(0)
Default High RPM idle
- First thing I tried was the idle screw (duh). It idled higher when in but never went down to normal when I screwed it out.
- Tried the Air screw, same result tried it all the way in and came out 1 turn at a time and no change to RPMs (or very minor changes)
- Checked for air leaks. Screwed down Filter box top, still high RPMs
P.S. I rebuilt the carb and it has a brand new idle and main jet. EVERYTHING is STOCK on the bike.
Suggestions?
1996 Yamaha Warrior (currently being rebuilt)
BMS 150cc Quad (Son's)
SSR 110cc Dirt Bike (Son's)
david6789 is offline   Reply With Quote
Old 11-05-2010, 09:50 PM   #2
View 06vmax's Photo Gallery(0)
Make sure the choke plunger is seated. Also check the throttle cable to make sure you have slack, and its not holding open slightly.
06vmax is offline   Reply With Quote
Old 11-06-2010, 02:18 AM   #3
I am not sure what you mean. It seems like its pushed in all the way. In or out the high RPMs seem to be the same.
Old 11-06-2010, 01:11 PM   #4
Just make sure its not hanging up and holding open. If it makes no difference when in or out, then some things not right with the carb.
Old 11-06-2010, 02:08 PM   #5
Yah thats mine thinking too now.
There is no change to RPMs when I pull the choke out or push it in.
I let it run for 2 mins and then shut it off, and it backfired. Scared the s#@t out of me.
Old 11-06-2010, 04:30 PM   #6
I have yet to put an air filter in. But the box is hooked up to the carb and the box lid is on tight.
Would the lack of a filter cause high RPM idle?
Old 11-07-2010, 08:30 AM   #7
Well the previous owner has apparently Debaffled the muffler and I am running rich. My Spark Plug is Black and sooty.
Suggestions on what jets to put in (currently stock jets are in)??
Old 11-07-2010, 10:26 AM   #8
U gotta run an air filter for correct operation and so you don't suck any crap in and destroy the engine. The baffle missing will also make it run like crap, unless you re-jet. You probably need the baffle installed seeing that you live in Cali.
Old 11-08-2010, 06:35 PM   #9
baffle removed=lean , air filter out= lean , plug is sooty=rich????? choke having no effect most likely is stuck in on position, enriching fuel mix.
they will run just fine with the baffle out, but lean.
Old 11-09-2010, 02:25 PM   #10
I removed the choke and cleaned the hell out of it, all seals look pretty good. But still not effect when I open and close it.
I did notice the "boot" (small black condom looking thing) on the fuel accelerator pump is torn and stretched out.
Old 11-10-2010, 07:27 AM   #11
The boot just keeps the dirt out and should be replaced, but doesn't effect performance. Check the intake manifold for cracks and make sure its screws are tight. The choke plunger should have a drastic effect if working correctly on a clean carb.. Are you sure you have slack in the throttle cable, and its not holding open??
Old 11-11-2010, 04:04 PM   #12
Yah the throttle cable is fine.
Old 11-11-2010, 04:06 PM   #13
Is there a way to determine if the choke is stuck in on the position?
yamaha warrior 350 high idle
yamaha warrior high idle
yamaha warrior idle too high
raptor 350 high idle
yamaha blaster high idle
1996 warrior 350?high idle
warrior 350 rpm runs upa and down during idle
2005 yamaha grizzly idle too high
yamaha yarrior 350 idle down
how to tell if atv choke plunger is completely seated in the off position
warrior want idle when choke pushed in
atv idles at high rpm
Idle to high mikentiff Yamaha YFM350 Raptor/Warrior ('87-Present) 5 09-01-2010 05:14 PM
high idle Shaun Yamaha YFM660R Raptor (2001-2005) 6 01-07-2009 12:26 AM
High Idle Jbud Yamaha YFM660R Raptor (2001-2005) 4 01-07-2005 12:06 AM
high idle 32blaster Yamaha YFS200 Blaster ('88-Present) 10 04-20-2004 03:25 AM
how high should it idle? DOM420247 Yamaha YFM660R Raptor (2001-2005) 4 08-05-2002 05:25 PM
