Putting piston back in cylinder... - Yamaha ATV Forum
This is a discussion on Putting piston back in cylinder... within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; Do I need to use a piston ring compressor, or will I be able to just slide it in the head/jug/cylinder? Going to get the ...
Old 09-09-2010, 11:08 AM   #1
xJoey Dubsx's Avatar
View xJoey Dubsx's Photo Gallery(0)
Default Putting piston back in cylinder...
Going to get the red and white quad back together tonight, and need to know..
thanks guys.
| 00 Warrior 350 | Blue & Black |DG Bumper | MSR Gear | K&N Filters |
| 00 Warrior 350 | Red & White | Custom Diamond Plate | Freshly Rebuilt |
xJoey Dubsx is offline   Reply With Quote
Old 09-09-2010, 12:07 PM   #2
View mike75925's Photo Gallery(0)
if you have a good bore/piston/rings it will not slide together. you can use a ring compressor, a larger hose clamp (provided it's wide enough to cover all the rings) or you can use a popcicle stick to push the rings in. pushing the rings in can be a pain if you don't orient your mind to it. at the ring gap, hold one side in. with your free hand, start walking that hand away from the other one, gently pushing the ring in and pushing gently down on the piston/cylinder. depending on how tight your parts are, i suggest installing the piston into the cylinder before installing the piston on the rod. i leave the wrist pin fully accessible. i've had bore jobs come back where the piston will not simply slide through the cylinder. on those, i definitely load the piston into the cylinder first.
mike75925 is offline   Reply With Quote
Old 09-10-2010, 09:02 AM   #3
im confused on how the hell you guys are doing what you say... you must have the motor completelty out of the fourwheeler??
anytime i have every done this sort of thing on a fourwheeler i couldnt use a ring compresser because you have to slide the cylinder onto the piston not the piston DOWN into the cylinder
Old 09-10-2010, 10:01 AM   #4
bomber, i load the piston into the bottom of the cylinder. granted pulling the engine on most atvs is fairly simple and straight forward, it normally isn't so on a motorcycle.
Old 09-10-2010, 04:53 PM   #5
right so if your sliding the piston into the cylinder from the bottom you cant use a ring compresser... or at least not one that i have every seen
Old 09-10-2010, 05:21 PM   #6
bomber, i take the piston in hand and load it into the cylinder. i could use a compressor if i wanted, but my fingernails work pretty good on the rings. i take the piston/cylinder assembly and slip it in over the block, locate the rod to piston and start pushing in the piston pin. slip the circlip in place and seat the cylinder. on a honda goldwing, a conventional ring compressor will not work as you will not be able to get it out afterwards. a hose clamp of corresponding size works great and is small enough to retrieve once undone.
Old 09-10-2010, 07:48 PM   #7
yeah ok i see what your doing... thats just not the exact way i do it... guess it doesnt matter which way you do it..
Old 09-10-2010, 11:56 PM   #8
LBJAMM's Avatar
View LBJAMM's Photo Gallery(0)
I made a wooden block out of a small piece of plywood in a u shape and put it around the rod under the piston and use my finger to compress the rings while sliding the cylinder down. It holds the piston real well. Just my .02 cents.
'99 Warrior,JE 366 10.5:1,Full Flight +2 a-arms,Tusk +4 axle,Webcams .390,CFM w/ K&N,Edelbrock,Yoshimura RS3 Full system,YZ250 shifter,PRM nerfs,Pro-taper SE,ITP Bajas, GBC XC Masters,p&p,skids,Motion Pro,Spider grips,and lots of MONSTER...
'06 YFZ450..too much to list
LBJAMM is offline   Reply With Quote
Old 09-11-2010, 09:51 AM   #9
the repair manual also recomends the u shaped block trick. seems pretty simple.
Old 09-11-2010, 10:00 AM   #10
LB, do you have yours on a lift when you do a top end? it would make it easier to see where the ring is sticking out. i install the way i do, mainly because my dad showed me the way you guys are talking. when you have to bend over, crane your neck and/or walk from this side to that of the atv to find the hangup, it is far simpler to pre load the piston. eliminates say 2/10 minutes of work time depending on how tight the bore is.
Old 09-13-2010, 09:54 AM   #11
We were going to use a Hose Clamp, but realized we didnt need to.
Old 09-19-2010, 04:51 PM   #12
LBJAMM's Avatar
No, I don't even own a lift, but my knees get sore sometimes lol
atv piston ring compressor
kx250 putting a piston back together images
putting head on piston
how to put piston in cylinder raptor 660
do i have to replace cylinders when placing new oul rings on rolair compressor
ymf 350 piston installation
tricks to fit rings back in cylider
how to get piston in the jug
how to install yamaha jog pistion picture
how to put piston into atv cylinder
how to compress rings polaris mono jug
how can i put a cylinder in a 350 polaris 4 wheeler without pulling the engine
Piston/Cylinder Clearance? tylerqew Yamaha YFM350 Raptor/Warrior ('87-Present) 18 09-13-2009 04:23 PM
Piston and cylinder prices??? 93pile Yamaha YFZ450/450R (2004-Present) 4 08-05-2007 10:51 AM
piston to cylinder clearance? hillbilly686 Yamaha YFM660R Raptor (2001-2005) 3 12-04-2004 10:08 AM
What all should be done when putting in a piston? weasle Yamaha YFM660R Raptor (2001-2005) 4 01-22-2003 09:42 PM
