slipping clutch? - Yamaha ATV Forum
post #1 of 7 Old 09-06-2010, 06:55 PM Thread Starter
slipping clutch?
I've had a problem with running along in 4th 5th and 6th gear and all of the sudden the rpms go up like its in nuetral let off and get back on it does ok then starts it again. went riding today it starting doing it in every gear and when i was climbing hills had to stop half way up twice because it wont pull. check the oil level and its below minimum. anyone know the oil capacity?
GM_tc is offline
post #2 of 7 Old 09-06-2010, 07:06 PM
Flux's Avatar
2.5 quarts, did mine yesterday.
Hopefully adding some helps, but slipping is usually from too much or the wrong oil, no?
Flux is offline
post #3 of 7 Old 09-06-2010, 07:34 PM Thread Starter
well with a wet clutch, at least if its anything like a automatic transmisson, the oil is used in conjunction with the friction plates to help create a better bite on the steel plates, when i rode it after i let it sit awhile it wasnt slipping like it was but id rather know for sure what it is before i get stuck on another hill, do u run yamalube?
GM_tc is offline
post #4 of 7 Old 09-06-2010, 09:29 PM
Flux's Avatar
From what i hear usually when a clutch starts to slip its time to replace, because its always going to slip from now on...
but you could try adjust the cable, theres an adjuster by the handle and one right before it goes into the engine, it should be mostly tight but leave just a bit of slack.
If thats doesent work maybe try a new cable...
I bought mine used and they were using Castrol 4t 10w-40 and it seems to be working fine...
There are clutch kits on ebay for about $45 shipped
Yamaha WARRIOR 350 Clutch Kit With Heavy Duty Springs: eBay Motors (item 230513948149 end time Sep-19-10 08:33:40 PDT)
And also some stock replacement, pre assembled clutch's for $150
YAMAHA RAPTOR WARRIOR 350 CLUTCH WITH HOUSING BASKET: eBay Motors (item 280556585381 end time Oct-01-10 11:44:15 PDT)
If it comes to that, look around, might find a good deal somewhere...
Flux is offline
post #5 of 7 Old 09-06-2010, 09:43 PM Thread Starter
i think im going to go ahead and replace the clutch in it, im pretty confident thats what it is, thanks for the help
GM_tc is offline
post #6 of 7 Old 09-07-2010, 08:33 AM
mine slips in about 3rd through 5th when putting load on the engine. only when its warm though. when its cold it does completely fine.
'99 Warrior - 366
'03 Blaster - ???
blkblzr01 is offline
post #7 of 7 Old 09-07-2010, 10:06 AM
The warrior clutch basket is shallow, if there is a little wear the pressure plate bottoms out and lets the clutch slip.
Save one of the steels out of your old clutch and put an extra steel in the middle of the new clutch pack and you will have a firmer clutch.
Clutch slipping Nick000 Yamaha YFM660R Raptor (2001-2005) 1 07-14-2005 11:18 PM
Slipping clutch? 2001Toomey Yamaha YFS200 Blaster ('88-Present) 3 03-22-2005 10:48 AM
clutch slipping... Badass GT stang Yamaha YFM350 Raptor/Warrior ('87-Present) 4 09-09-2003 08:34 PM
New clutch. Still slipping. 00banshee00 Yamaha YFZ350 Banshee (1987-Present) 6 04-08-2003 04:33 PM
clutch slipping 2000yamahawarrio Yamaha YFM350 Raptor/Warrior ('87-Present) 5 02-22-2003 11:24 AM
