Tired of the starter clutch issue - Yamaha ATV Forum
This is a discussion on Tired of the starter clutch issue within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; can anyone tell me what on my 01 warrior 350 i would have to do to put a pull starter on do i leave the ...
Old 05-02-2010, 08:21 PM   #1
View ericsloan's Photo Gallery(0)
Default Tired of the starter clutch issue
can anyone tell me what on my 01 warrior 350 i would have to do to put a pull starter on do i leave the worn clutch on and use the pull rope untill i can afford a new clutch just want the peace of mind of a back up
ericsloan is offline   Reply With Quote
Old 05-03-2010, 08:30 AM   #2
youll have a hell of time pull starting a 2001 warrior with just the rope... see in 97 and 88 the head a compression release that allowed you to pull the SOB over... the 01 head doesnt have that... what i did with my 94 (also no release) when i got it was, i borrowed a buddies pullstart and would hit the start button and pull at the same time... the starter was still doing most of the work but if it slipped, the rope would keep things going... a major PITA and it didnt last very long until my starter clutch completely locked and caused problems.... if you want to do it youll need the pull starter and also the "cup" from the crank that it catches
Old 05-03-2010, 08:50 PM   #3
View mike75925's Photo Gallery(0)
bomber, do you mean the ones had a manual decomp, or auto?
mike75925 is offline   Reply With Quote
Old 05-04-2010, 08:27 AM   #4
mmmm good question im not sure if you had to manually flip the lever or if it did it on its own... im thinking it was auto, but dont qoute me
Old 05-04-2010, 04:43 PM   #5
GREASY's Avatar
View GREASY's Photo Gallery(0)
Default RECOIL STARTER
Hi Guys: Heres the way that works ,on the right side of the head theres a lever and you push it down or pull it up I can't remmember, then pull on the cord. ITS NOT AUTOMATIC !, BUT SIMPLE. As for changeing your motor over you will need the recoil starter cover and change out the spacer on your motor to the one with lugs so it will engage with the recoil rope. GOOD LUCK....GREASY.
GREASY is offline   Reply With Quote
Old 05-13-2010, 03:28 PM   #6
so it was a manual greasy? thanks.
Old 05-13-2010, 08:10 PM   #7
View bigdad390's Photo Gallery(0)
I just got in from riding my 87 Warrior and yes I used the pull start. Seams the battery died over the winter and I have not yet replaced it. On the right side of the cylinder head, near the exaust outlet, there is a lever you flip upward. This manual compression release keeps the exhuast valve open partialy during the compression stoke. If the engine does not start the lever resets and you have to flip it again for each following pull. Without a compression release head, you would never be able to pull start it.
bigdad390 is offline   Reply With Quote
yamaha warrior 350 starter clutch
yamaha timberwolf starter clutch
yamaha warrior compression release
yamaha warrior starter clutch
yamaha warrior starter clutch problem
yamaha warrior starter clutch removal
how to put a recoil on yamaha timberwolf
yamaha warrior 350 starter clutch installation
yamaha warrior 350 what does a starter clutch do
03 yamaha warrior stater cluch problems
Clutch cable issue Running 100 Yamaha YFM350 Raptor/Warrior ('87-Present) 5 11-30-2009 03:43 PM
clutch issue warriorman2003 Yamaha YFM350 Raptor/Warrior ('87-Present) 2 02-04-2009 08:52 AM
Starter issue beanbread Yamaha YFM660R Raptor (2001-2005) 3 04-24-2007 12:12 AM
Clutch issue bakerboy90660 Yamaha YFM660R Raptor (2001-2005) 6 11-02-2003 01:54 PM
Clutch Adjustment Issue/Question nickthompson77 Yamaha YFZ350 Banshee (1987-Present) 7 10-08-2003 06:18 PM
