87 warrior-gas coming out the breather tube??...PLEASE HELP!!
This is a discussion on 87 warrior-gas coming out the breather tube??...PLEASE HELP!! within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; hey guys hope you can help me on this one...i started her up and couldnt figure out where the leak was coming from and turned ...
Old 03-18-2010, 09:18 PM   #1
View Datjerzeerider's Photo Gallery(0)
Default 87 warrior-gas coming out the breather tube??...PLEASE HELP!!
hey guys hope you can help me on this one...i started her up and couldnt figure out where the leak was coming from and turned out to be the breather tube. This is the tube that is left once you take the top of the airbox. i noticed that gas was pouring out of it and i heard i might have a blown engine? is this true? what does that mean? which part is bad? Thanks for any help guys..love my warrior!!!
Datjerzeerider is offline   Reply With Quote
Old 03-19-2010, 01:20 AM   #2
View Simtech's Photo Gallery(0)
I dont see how that can happen. It would have to be oily gas then. Check your oil and see if the oil is runny with a gas smell. If so then you are getting gas past your piston which would be bad rings or cylinder.
-2007 Honda 400ex (Hmf slip on, jet kit, K&N)
-1999 Yamaha warrior (stock)
Simtech is offline   Reply With Quote
Old 03-19-2010, 08:17 AM   #3
Don't ride it like that, pull the carb and clean it, your float needle is sticking.
Old 03-19-2010, 08:33 AM   #4
yeah something is not right here... i highly doubt there is gas coming from that crankcase breather tube?????? i mean seriously your hole gas tank would almost have to be in the bottom end, and the airbox would be completly full before it would run out the breather tube.... im lost here..... its probably a combination of bad float needle and seat and miss identification of where the gas is coming from
Old 03-20-2010, 01:44 PM   #5
ok i cleaned the carb FULLY and put it back in and started ot up and gas came out the tube again. Ok if i am sitting on the quad, the 1/2 tube from the engine on the left side is what i am referring to. I hope that clears it up. PLEASE HELP!
Old 03-20-2010, 01:46 PM   #6
it is attached to the "bottom" portion of the engine - 1/2inch tube that connected to the air box top.
Old 03-22-2010, 04:20 AM   #7
Did you check your oil? Take your fuel tank off and do a compression check. I find it odd that fuel would be getting to the lower part of the engine. Maybe it is back flowing from the carb into yout airbox and going down that tube. HHmm....IDK those are just my thoughts! Are you sure your floats are free?
Old 03-22-2010, 07:46 AM   #8
dude, i dont know what going be going on here...... in order for gas to get in your motor like that it needs to get around the piston rings... which is entirely possible... but your talking about 2 or more gallons needed to fill up the motor and run out the breather hose.... also going the other direction... if gas ran into your airbox it would take at least 1/2 a gallon it fill it and your air filter would be completley SUBMERGED in gas and which would get sucked straight into the engine when you hit the button...
if there is gas in your bottom end you MUST MUST MUST change the oil and figure out how it go there before you run it again
Old 03-31-2010, 08:58 PM   #9
thanks for the help guys, i put it in the shop and turns out the piston rings were SHOT!!
Old 04-01-2010, 08:37 AM   #10
any they put new rings in it? and that fixed it?
Visitors found this page by searching for these keywords:
fuel coming out of my ktm breather hose
leaking fuel atv breather
why does my quad pour out gas when i turn the gas on
yamaha gas leak throught tube in crankcase
Blaster Crankcase Breather Tube issues..... v10viper04 Yamaha YFS200 Blaster ('88-Present) 1 05-19-2009 08:57 AM
Oil coming from breather vent blaster91 Yamaha YFZ450/450R (2004-Present) 10 08-13-2005 10:15 PM
crankcase breather tube filter? kawabunga Yamaha YFM660R Raptor (2001-2005) 14 12-04-2004 01:02 AM
question about breather tube/filter Yama-bro Yamaha YFM660R Raptor (2001-2005) 4 04-08-2004 06:07 PM
Crank case breather tube spit a little oil ? fisher1648 Yamaha YFM660R Raptor (2001-2005) 3 12-13-2002 11:22 PM
