Help with stator check. Will it run?
This is a discussion on Help with stator check. Will it run? within the Yamaha YFM350 Raptor/Warrior ('87-Present) forums, part of the Performance /Technical category; I have spark on my machine, but it won't start. I replaced the CDI box to no avail. I checked the ohms of the stator ...
Old 03-18-2010, 06:21 AM   #1
View tyhoppy's Photo Gallery(0)
Default Help with stator check. Will it run?
I have spark on my machine, but it won't start. I replaced the CDI box to no avail. I checked the ohms of the stator and I'm leaning towards the pickup coil. Tell me what you think.
The source coil spec should be between 270 - 330 ohms. I got 250. I'm guessing that 250 would still run because it is less resistance than spec. But I'm not positive.
I do know that my pickup coil is bad because I get 350 ohms and spec is 171 - 209.
So, will the ATV run with the source coil at 250 if I replace just the pickup coil? Or should I replace the entire stator?
Thanks.
tyhoppy is offline   Reply With Quote
Old 03-18-2010, 08:03 AM   #2
Sometimes the stator will test a little different warm.
You can change just the pickup coil, but if the source coil is bad I am not sure you can buy a stator without a pickup coil.
SPEED SENSOR FIX DONE CHECK IT OUT NO CHECK ENGINE EASY oversize Yamaha YFM700R Raptor (2006-Present) 5 09-02-2007 01:05 AM
200watt stator question,is resistance less on a stock stator rob the painter Yamaha YFZ350 Banshee (1987-Present) 5 04-13-2007 08:28 PM
How to check stator? WarriorRacer Yamaha YFM350 Raptor/Warrior ('87-Present) 1 07-17-2004 12:23 PM
